Question about HP Officejet 5610 All-In-One InkJet Printer
My printer is ofline and it want print
I am trying to print and it is not printing , the printer is offline
  • anaistrudel May 11, 2010
    I right clicked the little printer icon and I don't see anything that gives the option to make the computer online. And what is the control panel?
  • Anonymous Mar 20, 2014
    Printer offline after completing cold start
    Scholar:
  • 103 Answers
Make sure the physical connections are correct.Then go to control panel and right click the printer and make it online
Posted on May 03, 2010
HOW TO FIX...PRINTER IS OFFLINE BUT IT IS ON...WE ARE UNABLE TO PRINT.
If you are getting a status message as the printer is offline on your pc,and afterward you can't ready to print the reports.
Steps to Resolve the Printer Offline Issue:
Step 1:
At first, you need to check your network through the HP Scan Doctor which encourages you to discover and fix the printing issues.
Steps To Run the HP Scan Doctor
    •Open the HP Scan Doctor tool by double tapping the symbol.
    •Start- - >Select your printer- - > Fix Printing
    •Then the list of issues displayed on the screen as result.
    •If the tool shows the white checkmarks at that point there is no issue.
    •If the tool shows the white wrench then the issues are found and repaired
    •If the tool shows the yellow shout point then the issues are found however that can't be solved or skipped.
    •If the device shows the red stamp then you have to take after the on-screen guidelines to determine the issues.
    Step 2:
      Set Your Printer as Default Printer
      •Search your gadget on your PC and select your printer and uncheck the Pause Printing and Use Printer Offline
    •If you can capable print implies your printer is online.
    Officejet 4650 keeps going offline then proceeds with following step Step 3:
    Check Whether You Connect With Correct Port
      •Go to printer- - > Printer Properties - >Port
      •For USB association utilize USB or DOT4
      •For Network Connection use WSD, organize, Standard TCP/IP Port Step 4:
      •Update the printer firmware which may resolve your issues
      Step 5:
      •Manually connect the wired or wireless connection
      Step 6:
        •For network connection just you have to add the second printer to your Windows.
        •Select your printer - > Properties - >Add Port - > Standard TCP/IP Port - > Next port
        •Now you can ready to print implies stop the troubleshooting. Still get the same issue mean you need to connect the printer customer support via +1-800-836-3987
Jan 08, 2016 | Office Equipment & Supplies
Printer offline
try to go in and mark the printer as online and the printer should come up as in ready state
Mar 16, 2014 | Epson NX625 AllInOne InkJet Printer
Prints a test page...but nothing else..says is offline
try on the print menu open file and you will see offline click on it to change to online and let me know again if we can try another solution
Apr 17, 2012 | Canon PIXMA MP210 Photo All-In-One Printer
It says it's ofline
Once you have added either a USB or networked printer to your PC or Mac computer, you can begin sending documents to print. However, on occasion, a print command will create an error on the printer and take it offline, which will prevent all future jobs from printing. To resolve this issue, you will need to change your printer settings from offline to online.PC Instructions
Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer.Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open.Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.
May 23, 2011 | Office Equipment & Supplies
Just moved. New laptop. Computer says 2 pending printing jobs but wont print. Message from printer: "ofline" Help
You may try the following suggestions:
  • While it says offline, right click the printer icon and cancel print jobs.
  • Right click the icon again, then 'Set Printer Online'.
  • Power cycle the printer. Just turn it off and then turn it back.
  • Reinstall the printer by running the 'Add Printer Wizard' and let it automatically find your printer to be reinstalled.
Nov 02, 2009 | HP Officejet 4110 All-In-One InkJet...
Trying to print 'offline'. Computer recognises it is offline but will not print. Error message says 'Printer is offline' which is as it should be. Printer is HP photosmart C4580.
So, if you want to print, the printer must be online. Offline method doesn't work to print. When the computer sayst that the printer is offline, it means ypur printer is turned off or you don't connected the printer to PC.
As in conclusion, if you want to print set the printer online.
Oct 05, 2009 | HP Photosmart C4580 All-in-One InkJet...
Printer won't print says it's offline
hi friend
this is very common problem for f300 series PSC
just delete the printer from printers and faxes and reboot the machine it will install printer again
there is funny thing abt this series it is saying offline when powered on and connected but when you disconnect iit will say "offline-use printer offline"
please try my solution and rate it
thanks
Apr 04, 2009 | HP Deskjet F340 All-In-One Printer
Lexmark x63
there are lines in the photos that i print why is that?
Apr 12, 2008 | Lexmark X63 InkJet Printer
Printing letters etc.
Delete all your printers. Unplug the printer. Download the newest driver from HP. Run the driver and connect the printer only when the program asks you to.
Jan 17, 2008 | HP Photosmart C4180 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
149 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
