Question about Ryobi Garden
My Ryobi power unit runs very slow...All the attachments run slow.....is there some way to get the gas engine to speed up?
  • 2,100 Answers
There should be a couple of screws on the side that have icons or letters, one is for slow or low speed jet and the other is for fast or high speed jet, take a little screw driver and open up the high speed jet with it running, till it gets going, if it slows down, you are going the wrong way. Sometimes it will say something like 1 1/4, that means that the starting point is 1 1/4 turns out from closed. Try it, hope this helps.
Posted on May 03, 2010
Small gas engine dies when choke full open
I have attached a diagnostic sheet to help you determine what is wrong.
Jan 21, 2014 | Weedeater 2 Speed Gas Blower FL1500LE ()
New Ryobi trimmer putters out at full throttle
Absolutely it can. Weight can slow it down, Friction can slow it down,. There are many things that will do exactly what you are talking but the #1 thing would be a Gummed up Carburator. EVERYONE is having the same problems right now.
Apr 07, 2013 | Ryobi 2-Cycle 26 cc Curved Shaft Gas...
Turns over slow, backfires , then starts.replaced battery, starter is ok. replaced plugs. what else?
If the unit runs normally after it starts it is probably a defective coil that isnt changing timing relative to crank speed. It is running advanced even at slow speeds and that is the backfire. You could also have a slightly bent flywheel key. This is what sets the primary timing so it is always a good idea to check it when you have the engine cover off!
Jan 25, 2013 | kawasaki Garden
The owners manual for my Ryobi 210 describes carburetor adjustment but the photos do not show which screw is the idle mixture adjuster.
The Low speed adjustment screw is the one marked as "L" and would be adjusted during:
1. Idle - to insure running smoothly, and
2. Acceleration - to transition from Idle to High Speed.
The High speed adjustment screw is the one marked as "H" and would be adjusted during:
1. High speed or Wide Open Throttle. Turn about 1/8 either way to gain top RPM's and then back off slightly.
The final screw is an Idle Set screw. This screw sets the actual speed of the Idle and is the screw attached to the end of the throttle cable as it terminates at the carburetor. Turning it:
1. Clockwise - increases RPM's (speeds up motor)
2. Counter Clockwise - reduces RPM's (slows down the motor)
Sep 28, 2010 | Ryobi Garden
Carnt keep ryobi pcn 4545 running when i increse the power
How do you increase the power to an electric saw? By your question, I'm assuming a fueled engine model. Check the fuel filter, air filter, and muffler for any plugging. Check condition of fuel lines and tightness of carburetor fasteners. If no help, turn the H jet needle CCW about 1/4 turn--which should result in the engine 4-stroking. Will the engine now run at speed (but not as fast as before)? If ok, warm the engine up, open the throttle and adjust H CW until the engine speeds up somewhat, but still 4-stroking. Proper adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. This produces best power and least heat! Hope this helps!
Apr 26, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Ryobi lawn trimmer keeps stalling out. I have
If it is a relatively new unit it should have the carburetor adjusted after the first few hours of use. If it stalls upon accelleration the low speed adjustment on the carb needs to be opened a little bit. If it runs a few minutes and then stalls it could be the high speed jet needs to be opened or the fuel filter is clogged.
Sep 16, 2009 | Ryobi Garden
My Ryobi weed eater loses power at working speed after 5 minutes.
you need to replace fuel filter inside the fuel tank . fish it out with and empty tank using a coat hanger and a small hood bent on the end.filters are around $9.00
Aug 21, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 540A need manual runs slow/ chain too tight?
Actually, I own one of these battery operated Ryobi chain saws too. It is normal for the saw to run slow. Remember it is battery powered, not gas, so its not going to be a high rpm saw. Be patient whit it, and you'll get about 4-6 cuts per battery. I take mine camping. It sure is nice not having to listen to a two-stroke while relaxing in the woods! Dont plan on cutting lots of stuff, either, or you'll burn up the motor. This thing works great for very mild workloads.
Aug 14, 2009 | Ryobi Factory Reconditioned 10-Inch 18...
Ryobi RLT30HT hard to start, won't tick over
Hi
On the rotochoke scale, between the run and half choke position there is a hole and in it there is a screw. This adjusts the idle. Turn clockwise to speed up, anticlockwise to slow down
Jun 11, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
141 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
