Question about Garmin nuvi 1350 Car GPS Receiver
My garmin freezes on startup. Can't master reset
My garmin nuvi 1350 freezes on startup and I can't master reset because it freezes right before it loads maps. Can't even plug into computer to update because it freezes on me! How do I fix
  • zhili651983 May 03, 2010
    no it does not work, i have tried to master reset and the navi freezes before i can even get to reset.
  • 54 Answers
You could try pressing and holding the power button for 10 seconds. If that doesn't work, try a master reset by:
Start with the unit off and unplugged from power.
  1. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  2. Continue touching and holding the lower right hand corner of the screen then power the unit on.
  3. Release the power button when the device powers on.
    • You will see a new message: "Do you really want to erase all user data?"
  4. Remove your finger from the touchscreen when this message displays
  5. Touch "Yes"
  6. Restart the unit
Please let me know if it helps.
Thanks
Posted on May 03, 2010
  • Rocky May 03, 2010
    Did you replace the battery?
    .....or restarting with the battery removed?
    President:
  • 1,111 Answers
Connect it to your computer and let it go in to mass storage mode then run the garmin web updater HERE and run the update..if that fails, let me know and ill help you further.
bill
Posted on May 05, 2010
Same frigin problem with mine. Garmins ****!
Posted on Aug 17, 2010
I am having the same problem! I have tried to run the web updater but it won't run it since it is frozen. Any other suggestions?
Posted on Jun 01, 2010
  • dzka Jan 22, 2011
    I am having the same problem. I got it to boot into mass storage mode once but then it hangs after that and I can not get it to move past that screen
3 Suggested Answers
ZJLimited
  • 17970 Answers
SOURCE: My garmin nuvi 1350 freezes
I geard a lot question about Garmin Freezen when updates firmware; if you have firmware v3.1. I suggest you try to install v3.0 instead.
Keep in mind Hard Reset warnings:
* Note that this procedure has been known to delete your favorites so back them up beforehand: From the nuvi drive, copy x:/Garmin/GPX/current.gpx to your backup location. After the hard reset, copy current.gpx back to the same folder on the nuvi but rename it temp.gpx (important). On the next power cycle, the favorites will be read from temp.gpx into the non-user accessible memory area on the nuvi where they are actually stored (current.gpx is only a shadowed backup of your favorites)
* Note that this procedure will clear all user selected settings under Tools>Settings like map view mode, navigational settings, selected vehicle, selected voice, etc. These settings will need to be re-configured afterwards. It will also clear out your Recent Finds so make sure you save these as favorites or archive them in another way. Maps, vehicles, voices and user-loaded custom POI's stored on the unit will not be disturbed.
Hard Reset Procedure: (All except the 8x0/8x5/37xx series units):
1. Power the unit off.
2. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
3. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
4. Press "yes" and the unit will reboot.
Reset all your location settings and user preferences. Also restore your favorites using the method outlined at the beginning of this post.
nuvi 8x0/8x5 series hard reset:
To perform a master reset on a nuvi 800 or 805 series device:
1. Remove battery from n?vi
2. Place battery back into n?vi
3. Touch-and-hold the bottom right corner of the touch screen when a progress bar appears
4. Release the screen when "Do you really want to erase all user data?" appears
5. Touch "Yes"
*Note that a "power-cycle" (or power-on/power off sequence) on the nuvi 8x0/8x5 units consists of removing, then reinserting the battery into the unit -or- sliding the power switch to the ON position and holding it there for ~10 seconds. Using the power switch normally on the unit (slide to ON position and immediately release) to power it off only puts the unit into a "sleep" mode.
nuvi 37xx series hard reset:
1. Power off the unit (press/hold the power button for ~7 seconds)
2. Power on the unit
3. When the Garmin copyright screen is displayed, press & hold the bottom-right corner of the screen
5. Touch "Yes"
Alternate method:
1. With the unit powered on at the map screen, press the bottom-right "Speed" field which will take you to the Trip Computer page
2. Press/hold the area just above the numerical speed on the round speedometer dial (where the compass heading is displayed when moving)
3. After pressing this spot for ~7 seconds, you will enter diagnostics mode
4. Select the first option displayed "Clear all user data", then follow the prompts
If possible after the hard reset (all units), let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire satellite almanac data.
Even you have warranty? Contact Garmin site.
Also, could contact this site poi-factory.com/node/6656
Or this: Repair Freezing On Startup for Garmin Nuvi 1350 LMT
Hop helps.
Posted on Dec 24, 2010
walesarumi
  • 6993 Answers
at this stage, your garmin nuvi is beyond DIY solution. If your computer won't recognize it and it won't master reset, then there is no possible way by which you can fix this problem yourself.
The problem is as a result of software corruption. The start up operating system of your gps is corrupt beyond repairs and needs to be re-installed afresh. This is not something you can do yourself. You need to take it to Garmin for repairs.
Also, an internal memory damage can cause problems like this.
To contact Garmin, fill the form on the below link and they will respond to you through your e-mail as soon as possible.
http://garmin-repair-centre.com/free-quote.html?manufacturer=156&model=2882
Good luck.
Posted on Aug 11, 2011
Tip
Garmin Nuvi 1350 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Does your Garmin Nuvi 1350 Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 1350 series GPS unit.
I hope that helps.
__________________________________________
Garmin Nuvi 1350 Manual Download
Garmin Nuvi 1350 QuickStart Download
Garmin Nuvi 1350 Webupdate
Garmin Nuvi 1350 Favorites Backup
on May 15, 2010 | GPS
Tip
Download Garmin Nuvi 1350 Quickstart Manual
Have you lost your Owner's Quickstart Manual for your Garmin Nuvi 1350 GPS?
Would you like a digital copy of the Garmin Nuvi 1350 Quickstart Users Guide for easy searching of terms and quick reference?
The Nuvi 1350 Quickstart manual is available free in pdf format, just follow the photo link below:
I hope that helps.
________________________________________________
Tip
Download Garmin Nuvi 1350 Manual
Have you lost your Owner's Manual for your Garmin Nuvi 1350 GPS?
Would you like a digital copy of the Garmin Nuvi 1350 Users Guide for easy searching of terms and quick reference?
The Nuvi 1350 manual is available free in pdf format, just follow the photo link below:
I hope that helps.
Tip
Garmin Nuvi 1350 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
I hope that helps.
on May 15, 2010 | Garmin nuvi 1350 Car GPS Receiver
Tip
Garmin Nuvi 1350 Favorites Backup and Restoration Procedure Models: Nuvi 1200,...
Would you like to back up a copy of your Garmin Nuvi 1350 Favorites and Waypoints?
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
I hope that helps.
Tip
Garmin Nuvi 1350 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
Does your Garmin Nuvi 1350 GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
Tip
I hope that helps.
Tip
I hope that helps.
Tip
I hope that helps.
Tip
Garmin Nuvi 1300 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Does your Garmin Nuvi 1300 GPS get stuck or freeze at startup, or when loading maps?
I hope that helps.
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
on May 13, 2010 | GPS
Garmin nuvi 1350 Car GPS Receiver Logo
4,309 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
