Question about ViewSonic VX900 19" Flat Panel LCD Monitor
My vx900 won't let me open the main menu by pressing the 1 button, so I'm unable to switch the inputs from digital to analog. Does anyone know if there's a manual way to do this, or a way to get the menu to open?
    Scholar:
  • 103 Answers
Some LCD's can have a menu lock. Try pressing on of the bottom for few seconds. One at a time.
Posted on May 03, 2010
I have managed to switch my LCD Philips TV from analog mode into digital mode. As I pressed the menu button it has gone into start up mode. Does anyone know how to get it back into analog mode without a...
You need a remote with the i+ button. Go into the service mode by pressing 062596i+ and put the set into factory mode and then select STORE. After a reset of the power the tv will be in the normal analog mode.
Do NOT change anything else in the servcie manu, it ruins your television!!
Feb 26, 2015 | Philips Televison & Video
How to switch from analog to digital mode
Any contemporary monitor is able to switch analog/digital mode automatically if connection from signal source to monitor is set up properly.
Connect digital output from your graphic card to DVI input of the monitor. Disconnect any other signal cables from monitor and switch on both devices (PC & monitor). Wait a while. Monitor checks its inputs and a activates digital DVI, because it is only one active input on it.
If none picture excluding error message of monitor is displayed, go through these steps:
1) Check whether your monitor is set for automatic input selection. If monitor buttons have no response try to use analog input to activate screen (any picture, desktop background...) and then get monitor menu access by pressing menu button.
2) Find out what connector type has your graphics card in PC. Possibilities are: DVI, HDMI, DisplayPort and some their options. See Wikipedia for connector look if you are not sure.
Remember that blue D-SUB (VGA) connectors are analogue and you cannot activate digital mode through analog VGA cable.
3) Use appropriate cable to connect monitor to PC.
Example: Your PC has HDMI output. Use HDMi-to-DVI cable. Your monitor input is DVI and common DVI-DVI cable is not suitable in case you have PC with the HDMI.
Note that DVI-to-DVI, DisplayPort-to-DVI etc. cables are available. You must buy right one.
Be aware that "Auto" button is inactive in digital mode of monitor.
Nov 18, 2013 | Belinea 1930 S1 Monitor
I need to set digital channels on my Sony Trinitron system. It will not auto-program on digital on analog. model KD-27FS170
You need to switch the TV to digital mode before you run the auto-program. Press the "DIGITAL/ANALOG" button on your remote before you run the scan. After switching to digital mode please complete the following steps to run the auto-program:
1. Press the "MENU" button on the remote
2. Press the right arrow ">" button on the remote once to highlight "CH" (looks like 3 boxes)
3. Press the "+" button (in the center of the arrow keys) to select.
You will now be in the "Digital Channels" menu. If you are in a menu called "Channel Setup", you are in the wrong mode. You should exit the menu, press the "DIGITAL/ANALOG" button on your remote and start again at step 1.
4. Press the down arrow on the remote to highlight "AUTO PROGRAM"
5. Press the "+" button (in the center of the arrow keys) to select.
The auto program will now run. This could take a while to complete but a progress bar is displayed so you can see how far it has gone.
If you can't get this to work or need further assistance, please post back.
Regards,
BElectric
Dec 09, 2010 | Sony Televison & Video
How do you get the world clock setting off of your lg env touch
To change the clock format
1. Open the flip, then press OK [MENU] - Down button - OK - 4 - 6
2. Press 1 for Main Clock or 2 for Front Clock.
3. Select Normal / Analog / Digital / Dual (Set City in
World Clock) then press OK
Hope this helps. Remember to rate my answer. Thanks
Jul 23, 2009 | Cell Phones
Denon AVR-1403 receiver switched from digital to analogue.
There are three modes (Auto, DTM, and PCM) on the input mode switch, on the main unit, selected by repeatedly pressing the input mode switch.
However, if you have already depressed the Analog button in, on the main unit you have predetermined the mode as analog.
On the remote, the INPUT MODE switch combines toggles for 5 choices, [Auto, PCM, DTS, Analog,
Ext. input]
My guess is that either the input mode switch on the main unit and/or the remote are toggled to analog.
Apr 11, 2009 | Denon AVR-1403 Receiver
Monitor switchs between digital and analog
I had a similar problem, the monitor was going blank once in a while (since I don't have a VGA input), so I switched the Auto Source feature to "Manual" and so far it's working fine for the past 2 days, if I run into the problem again I'll update this message.
On the side panel of your monitor, press the top button to access the menu, scroll down to the setup menu (by pressing the 3rd button down on the panel), press the 4th button down to enter the setup menu, scroll down to "Auto Source", use the 4th button to select, "Auto" & "Manual" are your choices.. press the 2nd button down to select "Manual" then the top button to exit the menu(s).
This monitor is set up to be able to do multi display with the software included. Utilizing both Digital and Analog signals. I'm not using this feature so I'm not sure how switching the Auto Source off will affect the performance of this feature.
Aug 18, 2008 | Computers & Internet
Green Plaid then Vertical Lines, Failure of hard controls, Analog Board?
You are absolutely correct, When anyone complains of vertical lines or bars, the next step is to see if it happens on only digital inputs ( digital board ) , only analog inputs ( analog board ) , or both ( DMD board ) .
Analog board can be purchased at www.partstore.com ,
Jun 04, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
DVD Recorder Is Unable To Find Digital Channels
Try resetting it here is the procedure
1. open thr front lid
2. press and hold for 5 sec. the up and down buttons.
this will reset the clock and the channel settings
Ihope this helps
Jan 22, 2008 | Panasonic DMREZ27 DVD Recorder
Switch from Analog to Digital
To move to Digital (you need to have a DVI cable for this)
I'm using the monitor now and typing these instructions Mine is a HW191D Silver:
Button Layout:
(1) Menu
(2) Auto Adjust (does nothing when in digital mode)
(3) Move up in menus
(4) Move down in menus
(5) Power
Press the Top (1) button to display the OSD Main Menu
The Press the button Next to the Bottom (4) twice (Input Setting should be highlighted)
Press the Top button (1) once to allow you to select between Analog and Digital (use the button next to the bottom (4) to select between the two)
Press the Top button (1) and it will change to the input that you selected.
If you selected Digital and you don't have a DVI cable connected, the display will go black and then return to Analog (VGA)
(1)(4)(4)(1)(4)(1)
I hope that helps
toypaj
Mar 18, 2007 | Matrix HANNSFREE 19 Analog and Digital...
Computers & Internet Logo
154 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
