Question about Hunter Fan Company 7-day programmable thermostat
The Honeywell LR69071 (old) has 7 wires connected labeled (X W2 R O Y G E) The Hunter 44860 (new) has wire connections for ( Y1 Y2 W2 G RH RC/R B W1 E O C L) What connects with what? There is also a jumper wire on new one. Do I need to use it? If so, which two? Thanks
  • 98 Answers
Wiring on the old one, "X", probably a brown wire will not be used on the new stat. If it's a blue wire, this may be your common. "E" and "W2" probably wired together with a white wire, this controls electric heat. "R" with a red wire, this is 24 volt power. "O" is an orange wire, this is the reversing valve. "Y" is a yellow wire, this is the contactor. "G" is a green wire, this is the blower. This pretty accurate? On the new stat, the jumper should be connecting "RH" to "RC/R", leave it in and wire the "R" from your old one to either terminal. White from the old one will go to the "E" of the new one. If your electric heat doesn't work after the install, you may need to jumper the "W1" and "W2" with the "E". "O" wires to "O". "Y" from the old one wires to the "Y1" of the new. "G" wires to "G". "C" on the new one is common. Usually a blue wire goes here. If "X" on the old one was blue, plug it into the "C". If it was brown, I'd suggest not using a common, and installing batteries. Hope this helps.
Posted on May 09, 2010
I have an old thermostat -- 7 wire -- LR69071 but could not find
how to hook it up to a new 5 wire -- 44200a digital
Is it possible that this new thermostat not compatible with the old one.
Posted on Apr 12, 2011
CAN YOU PLEASE GIVE ME A LINK THAT HAS A PICTURE OF THE COLOR EACH WIRE REPRESENTS AND HOW IT CORRESPONDS WITH THE CODES. Y1 W/B Y/0 RH RC G
R Red 24 volts coming from equipment to stat
W White First stage heat (could be W1)
W2 Second stage heat
Y Yellow First stage cooling (could be Y1 on your stat)
Y2 Second stage cooling
G Green Blower
C Common (Neutral)
B Reversing valve for heat pump
O Reversing valve for heat pump
If you have singles transformer system. Rc and Rh will be connected.
If you have 2 separate systems. i.e. Boiler heat and Central Air. Boiler Red to Rh and C.A. red to Rc.
Jan 18, 2011 | Hunter Heating & Cooling
I have an old Bryant heat pump. I got a Hunter 44860 2 stage heat/2 stage cool but I am having problems with the wires. These is the Bryant set up (the wire colors do not match)...
This should help you. You need to know if your thermostat is powered by the unit or independently and which way your reversing valve switches (I,m not sure on a Bryant, but probably Your old O wire goes to your new O terminal. They should pretty much match up, the new stat just has more options. Thermostat wiring
Jun 09, 2017 | Hunter Fan Company 5/1/1 Programmable...
We have Fedders model cnx 110 t3b. we are trying to change to new thermostat. Can you tell us what these wires go to... W1, X, Y2, Y1, G, Rc and Rh. They don't even have these on the new one, just a...
W1 IS HEAT ON WHITE WIRE X IS COMMON NOT USED Y2 IS SECOND STAGE COOLING ,NOT USED Y1 IS COOLING YELLOW WIRE TO AC G IS GREEN WIRE FOR FAN RC-RH GETS JUMPED AND CONNECTS RED WIRE.
RED WIRE AND WHITE WIRE TURNS HEAT ON RED AND YELLOW TURNS ON AC RED AND GREEN TURNS ON FAN AC MODE CONNECTS YELLOW RED GREEN
Apr 11, 2010 | Honeywell Electronic Programmable...
Im replacing my honeywell with a hunter 44110 the honeywell has 6 wires w1 to white, w2 to blk, G to green, RH to Red, Y2 to yellow and Y1 to orange, the hunter only has G RH RC Y W
I hate to tell you this but that thermostat will not work with your system.
The system you have is a 2 stage system and the thermostat you got will only do one stage.
You will need to get a thermostat theat is compatible with stage heating and cooling.
The W1 is the first stage heating, the W2 is second heating. The same is true for Y1 and Y2 on cooling
You could double them up, but it would defeat the encomoy reasons for having a 2 stage unit.
Wish I could give you better news..
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 05, 2009 | Hunter Fan Company 5/1/1 Programmable...
The thermostat on my coleman heat pump has 7 wires labled:g,y1,w1,x,w2,a,r. but the hunter replacement thermostat i purchaced does not have the same labeling it has rc/r,c,y1,y2,w2,e,o,b,g,l.i need to know...
here is some info may help you
coleman = Hunter
g   =  g
y1 =  y1
     =  y2 (second stage you don't have it on your system)
r    =  rc/r (leave the jumper bewteen rc/r)
x   =  c
w1 =  w1
w2 =  w2
a   =  o
     =  b
the "b" terminal is to energized the revensing valve on heat mode
the "o" terminal is to energized the reversing valve on cool mode
Oct 09, 2009 | Heating & Cooling
I am replacingh my thermostat. it's a honeywell xt302c. im replacing it with a hunter 44660. the wires are different letters. here's what's hooked up on the honeywell and available on the hunter: Honeywell...
Thanks for your Question,
B- is your common leg,
RH- is your hot to heating
RC1- you will not need
RC- you can use if you remove the jumper for cooling
Y1- you will not need
G- is your fan
O is not needed, wires should be hooked in as follows,
RH- red wire, heating
RC- Yellow wire, Cooling
G- Green wire, Fan
B- Blue wire, for common leg, this one might be a different color so make sure at the furnace which T-Stat wire is connected to Common, you should check all the wiring at the furnace to make sure this pattern of wiring is followed, it should be standard practice to hook them up this way, but not all installers do it, thanks again, please rate this,
mr.grzz
Jan 25, 2009 | Heating & Cooling
Thermostat Wiring: W2? E? Where to connect?
You have a heat pump. You need a thermostat for "Heat pump with Electric back-up heat". Make sure the 'stat has either an "aux" (auxilliary heat) or an "E"(Emergency heat) terminal. The wiring instructions will be provided with the thermostat.
Dec 15, 2008 | Honeywell Electronic Programmable...
Hunter Fan Company 7-day programmable thermostat Logo
2,670 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
