Question about Maytag 30 in. CSE9000 Electric Cooktop
Maytag cse9000ade cooktop. Does anyone have
Maytag cse9000ade cooktop. Does anyone have wiring instructions for this? I had to disconnect, when i went back to reconnect, from the cooktop there is two black (which abviously go to black), one red (which goes to red), one white) which goes to white, a ground, and a yellow wire!! Is this to be connected to the neutral or to the red? I have it to the neutral and the right side burners do not heat up fully...? running off of 110v?
Thanks Greg
  • Maytag Master
  • 3,740 Answers
Hi Greg. Welcome to FixYa. I am Kelly. I have been looking into this for several hours now. Even service manual(s). The only thing I can find is the yellow wire goes from the infinite switch to the right side elements. I don't see a blow on your model so the wiring diagram should be on the bottom of the pan cover. The bad news is I can not tell if it is actually on the bottom or inside the bottom. From everything I can see it appears that the yellow wire would be attached to L1 vs where you currently have it connected i.e neutral. I can not come up with the wiring diagram that is part of your cooktop but all of the other Electric Maytag and Jenn-Aire models show the same thing. Yellow wire from the infinite switch and L1. Take a look at your wiring diagram if you can find it and see if you come up with the same conclusion.
This became one of those solve the mystery questions for me and I literally have been looking at it for about 3 hours now. trying to get something I can safely pass to you that will not damage your unit.
With the yellow wire on neutral currently it would be operating on 110V and have low heat. Placing the yellow wire on L1 (Left) should get 208V to the right side burners. Again.. take a look at the schematic / wiring diagram that is attached to your unit.
This is the best I can do from here. The users manuals I have found for your cooktop are in several languages. ENGLISH is not one of them :(
Kelly
Posted on May 05, 2010
My maytag freestanding stove won't turn on. The clock works but the stove or oven won't turn on.
Need more in fo-gas or electric: If electric,I have seen problem in electrical box over time the screws where wires are connected over heat and get loose or break check both ends and disconnected electrical cord before doing this.Check all wires.
Sep 15, 2012 | Maytag Stove / Oven / Range Cooktop -...
Indicator light on my maytag electric smoothtop range will not shut off even though the indicators are off?
One of the high heat sensors has failed on one of the burners under the glass. Disconnect one sensor at a time to find out which one, then replace that burner assembly.
Feb 19, 2011 | Maytag MEC5430BDS Electric Cooktop
I have a Jenn-Air CCE3401 Electric Cooktop I want to remove. How do I disconnect the wires from the cooktop? In other words, how do you get inside the cooktop to disconnect the wires? Disconnecting...
Firstly turn the power off. Lift the cooktop out from the benchtop and lean it against the wall. There will be a small panel where the wiring terminates into the cooktop. Remove the panel and disconnect the wiring to the cooktop. Ensure that you insulate all wires properly. You can then turn the power back on if you need to.
Feb 12, 2011 | Jenn-Air 30 in. CCE3401 Electric Cooktop
How do you wire the cooktop to the main power source. There are bare wires coming out of the cooktop..red black white and ground.
The wire coming in should have the same colors, just match up the wire colors and wire nut them together with large wire nuts ad them tape them. ground the green wire to the ground screw.
That's all there is to it!
heatman101
Aug 19, 2010 | Maytag MEC5430BDS Electric Cooktop
Gas Range Error Code F1-7.
Hi
Thanks for using FixYa. Error F 1-7 in your Maytag indicates keypad disconnected. To start with check the wiring between the keypad and Electronic Range control (ERC), if still the issue is not resolved then you’ll have to replace the keypad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 02, 2010 | Maytag Cooktops
Cooktop - maytag cse9000 - wiring
white goes to neutral, bare copper to ground, red and yellow to one phase ( red L1 wire) and the black and blue to the other phase ( black L2 wire)
Dec 20, 2009 | Maytag 30 in. CSE9000 Electric Cooktop
My jenn air cooktop only gets warm and only has 110 volts?
how old is the cooktop? may have a broken or disconnected wire in it.
Oct 26, 2008 | Jenn-Air JED8430 Electric Cooktop
Frigidaire electric glass cooktop wiring problem
HEllo
I have the following manuals in PDF format,
I will gladly email them to you.
Model: GLEC30S8ESB Owner Guide(English): 318200612en Wiring Diagram: 318046807 Installation Instructions: 318201426 Parts Manual: 5995479655
Eddie Rentas
Tupper Lake NY
Jul 21, 2008 | Frigidaire 31 in. GLEC30S8 Electric...
(2) front Burner igniters on my new Matag 30" Cooktop continue to click
Sounds like water got into one of the switches. This usually happens when you wash the knobs. Water stays in the holes and runs down the shaft when replaced. Maytag has issued a recall on some stoves because this can be a fire hazard. UNPLUG THE COOKTOP UNTIL THIS IS FIXED!!!!!!!!! This has happened to me with a whirlpool unit and it tripped a breaker and shot sparks across the kitchen. First go to Maytags web site and see if yours has a recall. If so Maytag will fix it free. While you are waiting leave stove unplugged and light with a match. If you need to fix this yourself disconnect the wires from the two switches this should stop the sparking. Connect one switch at a time and see which switch is bad. Most of the time the electric part of the gas valve can be replaced seperately. and you can do this yourself. If you must actually disconnect a gas pipe unless you really know what you are doing call for service.
May 15, 2008 | Maytag 30" Built-In Gas Cooktop - White
Cooktops Logo
238 people viewed this question
Top Maytag Cooktops Experts
paulcarew
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
