Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
No signal None of the input jacks seem to work- Is there a setup button to activate? My Aunt who had it last said she pressed a button and it no longer got a signal...Thanks!
  • Scarlett1108 Apr 21, 2008
    Hi tvpaul,
    Thanks for looking into my tv problem. I tried to enter the inputs again, however, it only allows you to relabel what is connected (i.e. DVD, sattelite, vhs, cablebox, etc). The tv still does not recognize anything connected to the tv through any of the inputs, even when labeled correctly. Any other ideas? I'd be happy to answer any questions. Thanks!
    -Scarlett
  • Scarlett1108 Apr 22, 2008
    Tried it...no luck- very odd- still says "no signal" on all inputs.
  • 116 Answers
Select menu, go to set up or video and enter the inputs again. Any problems-just contact me again.
Posted on Apr 17, 2008
  • Paul Buscema Apr 22, 2008
    Try getting into the menu again and opening parental control. Once there, turn off parental control.
How do I turn off pscan on a rca dro2oon DVD player
IMPORTANT:
If you don't have a Progressive Scan TV or you don't have the DVD player connected to the correct Input Jacks, and you activate Progressive Scan in the DVD player you won't see a picture! Don't panic-try the following:
First, press the PREV/VIDEO button on the front of the DVD player (it will go to the next video output option, which is an interlace output so a picture should appear on the TV screen). If that doesn't work, press and hold PREV/VIDEO button on the front of the DVD player for 3 seconds. Now, press the PREV/VIDEO button again (it will go to the next video output option, which is an interlace output so a picture should appear on the TV screen). If you still don't see a picture on your TV screen, make sure the yellow cable (provided) that is attached to white and red cable (called audio/video cables) is connected to the DVD player's PREV/VIDEO jack and the TV's Video Input jack. Change your TV channel to your TV's Video Input
channel that activates the TV's VIdeo Input jack where you have connected the yellow cable (page 9 of your manual has more information).This PREV/VIDEO jack on the DVD player always outputs interlace video, so you should see a picture on the TV screen.
As a last resort, you can reset the DVD player to the factory default settings:
Press and hold the STOP button on the remote control and the NEXT button on the front of the player at the same time - wait at least 5 seconds before you release both buttons
Sep 25, 2016 | RCA Televison & Video
None of my inputs work on the TV, including the Ethernet connection
test with your cell phone directly then reconnect the modem last reset tv to do so in main menu
Sep 15, 2015 | Sony BRAVIA KDL-55EX710 55" LED TV...
Not detecting devices
test this steps and fix it. God bless you
    • 1
      Check the back of your Sharp TV for the HDMI input. These will be long, thin rectangular jacks labeled "HDMI." Most Sharp TVs will include another label on those jacks with an input number ("Input 5," "Input 6" or the like). Remember that number. It will have a bearing when you turn on the TV.
    • 2
      Connect one end of an HDMI cable to the input jack on the Sharp TV and the other end to a compatible component such as an HD DVR from your cable/satellite company or a Blu-Ray disc player. The TV won't broadcast in HD if you can't connect these devices with an HDMI cable (though it will still broadcast in standard definition using RCA cables or S-video cables).
    • Sponsored Links
    • 3
      Turn on the TV and the requisite component (Blu-Ray, DVR).
    • 4
      Press the "Input" button on your remote. A list of signal sources will appear on your screen ("Input 1," Input 2," etc.). Use the cursor to maneuver down to the input number corresponding to the HDMI outlet you just hooked up and press the "Input" button again.
    • 5
      Press the "Menu" button and maneuver the cursor to select "Option." Go to "HDMI Setup" and press "Enter." Move the cursor up or down to the desired item and hit "Enter" again. Then move the cursor from side-to-side to select the proper setting. Hit "Enable" to allow the Sharp TV to automatically recognize the HDMI signal and "Digital" to get the proper audio signal from the HDMI cable. Then hit "Enter" again.
    • 6
      Exit the menu and watch TV as normal.
Read more: http://www.ehow.com/how_4840499_turn-hdmi-input-sharp-tv.html#ixzz2a6Xat0JU
Jul 25, 2013 | Seagate 1TB GoFlex Cinema Multimedia Drive...
How to connect Denon avr 1804 connecting to roku hd
I connected by Roku to a Denon 1804 Receiver this way:- I plugged the cable that came with the Roku into VCR2 input jack of the Denon. (I used VCR2 because it was available).- Using the remote from the Denon, I made sure the slide switch was on "Audio." (See page 20 of Denon Manual).- I pressed pressed the System Setup button- *System Setup appears in display of Denon- Using the cursor buttons I scrolled to menu Digital in Assignment- I set Menu item 16 Coaxial to VCR2 since that was the input jack I used for the Roku. - After making the selection press the CH Select Enter button to save- To exit the System Setup press the System Setup button again- When using the Roku, select the input source as VCR2 (or whatever jack you used). You should now have sound through the Denon.The most important step is to read the Denon manual starting on page 20
Dec 08, 2012 | Denon AVR-1804 Receiver
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Sep 26, 2011 | Sanyo DP50747 50 in. Plasma TV
I clicked a button by accident last night and now my Vizio tv reads no signal and a small display in the top right corner reads AV. How can I get my tv to read cable signals again??
What input is the cable connected to? (Coax antenna In, component video, composite video)
Look on the remote or the TV itself for a button marked Source or Input. Press this. For some TVs, use the up/down arrows to select the input to which your cable is connected. (TV = coax) On other models, you may need to press the Source button several times to advance between inputs. (I'm assuming you have a remote that works for this feature on the TV; otherwise, use the TV button.)
I hope this helps.
(common modern TV setup: VCR on AV1, DVD player on Component 1, PC to the HDMI/DVI and coax to the antenna in. The source button is needed.)
Apr 26, 2011 | Televison & Video
My aunt went to turn on her tv and she pressed a random button on a sony remote that the comcast set-up employees told her not to use. the TV says no pc signal on it. she doesnt own a computer. what does...
It sounds like your aunt switched the TV's "input" mode. Look for a button labeled "Input" and press it. She will most likely have to press it a few times as it cycles through the various inputs till she reaches the correct one.
Dec 27, 2010 | LG 37LG30 37 in. LCD HDTV
My SONY KV32FS13 DO NOT HAVE IMAGEN ON THE SCREEN NO GET ANY CHANNEL OF TV OR CABLE ONLY WORK WITH DVD EVERY TIME WHEN TURN ON COME OUT NO SIGNAL.
Try pressing Tv/Video on the remote control and see if it doesn't switch input modes. If it doesn't, follow these steps:
1) Press the menu button
2) Navigate over to Channel Setup
3) Move down to Video Label and select it
4) Make sure none of the video inputs are labeled "SKIP". If so then do the following
5) Highlight the input labeled "SKIP" and select it
6) Use the up and down arrows and you should see a different name for the input. This will enable the selected input to be used.
7) Exit the menu by pushing the menu button on the remote.
8) Press Tv/Video on the remote and you should see the other stuff (cable, vcr, xbox, etc.).
Aug 15, 2010 | Sony KV-32FS13 TV
My compaq M700 has a video output jack, but it doesn't seem to project a signal to an RCA input.
press the "FN" key and the key with the little screen with two bars while cable is plugged in also check under display properties that the monitor is activated :)
Jul 11, 2009 | Compaq Armada M700 Notebook
Audio Output Problem
Select DVD Input source, then press the Setup button on the remote (it's under the DVD control block near Subtitle). Go to the Speaker Setup Page and select LT/RT or Stereo. After I set it up it seems to work for other Input modes also. I have the 27" model.
Dec 04, 2007 | Akai LCT3201TD 32 in. LCD Television
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
42 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
