TV TURNS ON EITHER FROM FRONT PANEL OR FROM REMOTE BUT ONLY STAYS ON 2-3 SECONDS AND SHUTS OFF
  • dric467171 May 03, 2010
    Mitsubishi WS-65807
    Problem is still there, will contact a repairman.
    Thanks
  • 10,594 Answers
Let me know model number and brand of your tv to determine what would be cause of this problem.
Thanks.
Posted on May 03, 2010
  • Shahid Electronics
    Shahid Electronics May 03, 2010
    Mitsubishi WS-65807
    Unplug tv from wall socket for couple of minutes, replug back in and turn tv On, if that does not fix the issue then possible cause is deflection circuit, specially horizontal deflection section and most probably horizontal output transistor need to be replaced.
    It is qualified tv repairman job to replace defective parts in tv circuit board, please check with local tv repair shop for an estimate of repair.
    Thanks.
My TV remote comtrol will not work when I try. I need the code.
Hi.
Manual Programming:
1. Turn on the device with which you want to use the remote control.
2. Locate a 3-digit code for your device.
3. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) for approximately three seconds unitl the POWER INDICATOR illuminates.
4. Enter the 3-digit code for your device within 30 seconds. The POWER INDICATOR shuts off.
5. Press power button to verify correct code entry. If the device shuts off, the code was entered correctly. If the device does not shut off, repeat steps 3-4, using a different code.
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control(TV, VCR, SAT, DVD, CAB or AUD) until the POWER INDICATOR illuminates. The remote control is in programming mode.
3.Press and release power button. The POWER INDICATOR flashes once and stays on
indicating the unit is in Power Scan mode.
3. Press CHANNEL UP or CHANNEL DOWN repeatedly until the device turns on.
4. When the device turns on, press OK to store the code.
5. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Codes for orion TV are
096,10,146
Thanx
Jul 27, 2010 | Brookstone 538744 Remote Control
Olevia 332h comes on for a few minutes then turns off
I have the same problem with my Olevia 332h. The TV shuts off after 10 seconds. I decided to wedge a desk fan in between the wall and the back of the TV. It worked! The TV doesnt shut off anymore. This problem is obviously heat related. I hope this information helps you.
Jun 03, 2009 | Olevia LT23HVX 23 in. LCD Television
TV turns on than shuts off right away
Try blowing the dust off mother board. Remove back. Unplug first. Then post problem again
Apr 09, 2009 | Televison & Video
Samsung dlp turns on for few seconds and shuts off
lamp shuts off first..with sound still on and black screen.then turns off and has three blinking lights on front panel.
Jan 10, 2009 | Samsung DLP HL-P5663W 56" TV
On off switch
clean front panel contact switches on/off vol- vol+ use contact cleaner .
Dec 03, 2008 | RCA D52W19 52" Rear Projection Television
Sylvania 6419TC
My Sylvania T.V. turns on and then it turns off by itself. It only stays on for onr minute.
Aug 10, 2008 | Sylvania 6419TC 19" TV
36 magnavox tv shuts off by itself
MAGNAVOX TV ONLY. 5-10 SECONDS AFTER TURN ON AUTO TURNS OFF-NO LIGHT STAYS ON-I AM FRUSTRATED BUT IT SEEMS LIKE THE OFF ON SWITCH JUST CLICKS BACK TO OFF-ALSO DOES SAME THING BY REMOTE
Jan 16, 2008 | Philips Magnavox MS3652S 36" TV
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
