Question about Vizio L32 32 in. LCD HDTV
No Power My Vizio L32 is a referbished and out of warrentee. The first time my TV turned itself off was Febuary 2008. Call Vizio and the tech said unplug the unit at the back of the set, wait 3 to 5 minutes and plug it back in..... Whoo Hoo! Fixed. Last night 3/24/05, TV shuts itself off 2:00 am.. I do the unplug and replug and whalla it works. 2:30 am TV shuts itself off - do the unplug and replug - nothing, just a flicker of the power light. I have plugged from my power strip to a different source, NOTHING! Vizio gives me an 800 number for repair and they qoute minum $300.00, Trust me, if I had that kind of money for repair, I'd buy a new unit for $500.00 Can you help me? Thanks, Shirley in Sun City, AZ
  • 2 more comments
  • emazana Mar 28, 2008
    no power
  • grego15 May 07, 2008
    my vizion l37 turns off by itself also but it does it when first turned on and then as I keep turning it back on the frequency gets less and less to the point by the afternoon it will stay on for the most part...terribly annoying in the middle of an online racing game tho.
  • Anonymous May 12, 2008
    The Vizio is powered on, but no screen image. Like the many of other Vizio 32-inch HDTV owners with the same problem, we called Vizio and of course, the TV is just past the warranty date. Vizio says their repair representative can fix it for $350. Why bother? What happens when it goes out again? Obviously Vizio doesn't stand by the quality of their product. We won't be buying another Vizio.
  • 777king May 13, 2008
    My 37" Vizio is shutting off with increasing frequency. At first I thought that it was the cable box so I disconnected that completely. Then I took the tv out of the cabinet to see if heat was an issue. The tv now shuts off after just a few minutes of operation.
    Thanks
    Genius:
  • Vizio Master
  • 1,691 Answers
It appears that the power supply is starting to fail. It is also possible that there is another board in the set that is over-loading the supply.
The nature of the fault indicates the strong possibility that there are some parts that have become thermo sensitive. This is not a reset problem going by your description. Unplugging the set, is allowing the boards to cool down, and therefore they will work for a while until the thermo sensitive parts heat up again.
Jerry G.
Posted on May 07, 2008
SOURCE:
My tv dont want to turn on
Check power connections. Try different power outlet.
If it simply wont do anything,. you will need to contact Vizio. It is possible the tv has simply fried itself.
Jan 25, 2011 | Vizio L32 32 in. LCD HDTV
Tv turns on by itself
Unusual. most likely reason is a failure of the standby management chip which is a component of the sets power supply board, they usually blow up rather than initiate uncalled starts though. This needs examining by someone who has experience with flat screens. If you were to look at vizio l32 psu on google, you'd see why.
Jan 13, 2011 | Vizio L32 32 in. LCD HDTV
My vizio vp322hdtv10A just quit working
2008?. Well anyway, Do you have a power light, if flashing... panel needs replacing...if no light...power board needs replacing
Jan 14, 2018 | Vizio L32 32 in. LCD HDTV
Vizio TV wont turn on after three weeks no use
My vizio recently did the same exact thing. Vizio sent an HDTV tech out to fix it and it was the power board. He put a new board in (took 15 min) and the tv works like new.
Jan 05, 2010 | Vizio L32 32 in. LCD HDTV
My Vizio L32 periodically turns itself off, multiple time a day.
My 42" and 32" started doing that, I bought it form Costco, they set me up with Vizio under warrarnty. A tech came out and changed out the circuit boards, but the problem persisted, they are now going to send me a reburbished replacement. I'm not Happy, they should send me a new non defective one(actually 2). I will not be buying any more Vizios!
Aug 08, 2009 | Vizio L32 32 in. LCD HDTV
I have a vizio L32 manufactured in 2005 - Won't turn on
Most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20. And most cases the new part cost less than $15.
I hope I shed some light on the subject for you.
Jul 05, 2009 | Vizio L32 32 in. LCD HDTV
No power! It was working fine then it would cut on off
That problem is related to the mainboard, if your tv is under warranty just call vizio and they will send you a tech, if not, just take a look at ebay or any online tv parts store to find out the price.
You will need the product code and model number, look in the back of the tv next to the serial number.
Jun 18, 2009 | Vizio L32 32 in. LCD HDTV
Vizio L32 HDTV 10A - Won't Turn On
Bad capacitors in the power supply. Open it up and look for swollen electrolytics.
Sep 22, 2008 | Vizio L32 32 in. LCD HDTV
Vizio L32
Replacing the main board or power board should resolve this problem.
Sep 03, 2008 | Vizio L32 32 in. LCD HDTV
Visio l32 hdtv
I took mine back to the store and got an updated one. They knew about the problem. All better now.
Dec 08, 2007 | Vizio L32 32 in. LCD HDTV
Vizio L32 32 in. LCD HDTV Logo
377 people viewed this question
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Steve Allison
Steve Allison
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
