Question about Life Fitness F3 Folding Treadmill with Advanced Console
Stuck Key Error Message on Life Fitness F3
On trying to start my Life Fitness F3 I have a console display message Stuck Key
    President:
  • Life Fitness Master
  • 832 Answers
Stuck Key means one keys on the function pad assembly has failed and will need to be replaced. Call Life Fitness @ 800-351-3737
Posted on May 05, 2010
What's your problem?I have a life fitness 9100 hr I have a problem how do I clear the message waxer tank empty?
see this step and fix it. God bless you
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or move on to the next step.
  • 2 Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
  • 3 Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
  • 4 Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.
  • Oct 15, 2012 | Life Fitness 9100 Next Generation...
    On trying to start my Life Fitness F3 I have a console display message PUT BACK MAG. Please can you tell me what I nead to do to clear this message and get started? Thank you for your assistance
    First, check and make sure the safety magnet is in the correct place. If not, place magnet. If it is, then the safety magnet sensor, sensor cable, or the console is messing up.
    Mar 18, 2010 | Life Fitness F3 Folding Treadmill with...
    Error 1 message on older life fitness t3 treadmill
    Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
    Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
    Feb 17, 2010 | Life Fitness T3 Treadmill with Advanced...
    Fet error message
    The FET error message is caused by the driver transistor on the motor controller has shorted out. Unfortunately, the fix is replacing the motor controller.
    Oct 13, 2009 | Life Fitness T3 Treadmill with Advanced...
    T3 Treadmill Stuck Key
    The cause of a “STUCK KEY” error message on the Basic or Advanced consoles. A stuck key error is displayed when one or more keys on the console or activity zone remain actuated for more than 45 seconds.
    SOLUTION
    Recycle the power. If the key remains stuck, the console will display “PLEASE WAIT” until the stuck key error is displayed again. Determine the stuck key. Replace the console if the problem is a key on the console. Replace the activity zone membrane keypad or the activity zone circuit board depending on the product if the problem is not in the console.
    Jul 28, 2009 | Life Fitness T3 Treadmill with Advanced...
    Replace Switch error message
    It was the emergency tag that you attached to yourself when you run (in case you fall over - the belt then stops etc). i had not connected it properly
    Jan 25, 2009 | Life Fitness F3 Folding Treadmill with...
    F3 Error Message
    It needs a new key pad it is shorted the ge website has a list of error codes f3 is the keypad
    Jan 31, 2008 | GE Advantium 120 Convection/Microwave Oven
    Life Fitness F3 Folding Treadmill with Advanced Console Logo
    1,777 people viewed this question
    Top Life Fitness Exercise & Fitness Experts
    Howard
    Howard
    Glenn Mayer
    Glenn Mayer
    Craig Butler
    Craig Butler
    Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
