Question about Hitachi EC12 Portable Electric 2hp Air Compressor, Oil Lubricated
Hitachi EC12 won't refill air after initial startup
When I initially start up my EC12 compressor it fills up just fine based on the PSI I set. When it senses it needs to start back up I here a humming sound and then it usually trips the breaker. I checked the oil and it seems fine, but just wondering what else it might be. I have an opportunity to buy a used DeWalt compressor, but I would rather fix mine if possible
  • 374 Answers
of course comparative cost buying and repairing make a cost reduction.if your compressor run smooth but tripping,make sure where on the right path of diagnosing of your compressor,we can check if the motor or compressor is shutting off the unit.disconnect the belt from pulley of the motor to compressor,run the motor if still tripping w/o load its better if you have calmp ammeter test,to check the current rating,if it is tripping motor is deffective replace the bearing.f motor is fine sr till tripping check the compressor also the crankcase bearing,replace worn out bearing.have a nice day dont forget to fix my rate.thanks a lot.
Posted on May 08, 2010
Air compressor will not restart after it builds pressure and pressure drops to 80 psi
Make sure the power cord is plugged into an adequate extension cord if one must be used. Never less than 12 gauge wire.
The start/run capacitor may need to be replaced.. If there are any ball check type valves, make sure they are not worn or sticking. they would be on the output of the compressor head itself.
Dec 13, 2011 | Hitachi EC12 Portable Electric 2hp Air...
How much oil in an ec12 hitachi air compressor..... brand new. no oil. no manual.....
DO NOT FILL to the plug threads on this compressor!!! The dipstick has a mark and it is very near the end of the stick. Any more questions please email or repost.
Tim
Sep 22, 2011 | Hitachi EC12 Portable Electric 2hp Air...
What type oil does the Hitachi EC 12 use? Ray
SAE 5W50 and if available use full synthetic.
This link will take you to the EC12 owners manual if you would like.
http://www.hitachipowertools.com/product/files/pneumatics/compressors/EC12__OM.pdf
Oct 28, 2010 | Hitachi EC12 Portable Electric 2hp Air...
EC12 that fills fine, pressure switch kicks off, but then seems t
I have the same compressor with the same problem. I have temporarily eliminated the thermal reset with a piece of 12 gauge hard wire and it runs just fine. However, I do want to replace it before the warm weather come to the north. I tested the draw at 15.5 amps and the reset was a 17 amp. I am told by someone with superior electrical background that I need to install a 20 amp thermal reset in it's place. I have found that mine runs best when plugged directly into a 20 amp circuit and when using an extention cord I have a 10 guage cord that will carry the load needed to run the EC12.
Mar 15, 2010 | Hitachi EC12 Portable Electric 2hp Air...
Compressor fills,drains off a little but won't
sounds like the pressure switch is fused shut, more than likely it needs to be replaced, most single stage pumps should shut off at 125 psi max.
Jan 21, 2010 | Hitachi EC12 Portable Electric 2hp Air...
My hitachi EC12 compressor starts up and fills the two tanks. When I connect my hose, the pressure in one tank drops to zero, then goes back up to about 60 psi, then very slowly builds back up to max...
how do you know one tank drops to zero unless you have a pressure gauge on both tanks sounds unlikely unless you are looking at the gauge on the pressure regulator
Nov 18, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Hitachi EC 12 Air Compressor does not keep pressure
to repair this problem (a) the pressure switch is not working,(b) check valve or non return valve sticking(stripe down repair and refit)
Sep 28, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Hitachi ec12 motor hums after drop in pressue
There should be a pressure switch adjustment under the cover of the switch remove the cover and reset.
Feb 03, 2009 | Hitachi EC12 Portable Electric 2hp Air...
My EC12 builds up pressure, but then releases all but about 10 psi.
The non-return valve is sticking and it's an easy fix. First, for safety, unplug the electric power to the unit and release any pressure in the tanks. Then unscrew the cap of the non-return valve (between the compressor and the tanks). Inside you should find a tapered rubber plug which is probably sticking in the valve housing. Sand down the diameter of the large end of the plug, being careful not to damage the flat face at the narrow end (which is the sealing surface). For sanding try 400 or 600 grade wet-or-dry paper and sand until the plug just moves freely in the housing. Reassemble and the compressor should work. Incidentally it's an oil-type unit, and quite durable. Make sure it has enough oil.
Sep 23, 2008 | Hitachi EC12 Portable Electric 2hp Air...
Hitachi EC12 Portable Electric 2hp Air Compressor, Oil Lubricated Logo
209 people viewed this question
Top Hitachi Air Tools & Compressors Experts
John Trevino
Jim Thurston
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Hitachi Air Tool and Compressor Expert? Answer questions, earn points and help others
