What is the correct path for P. E. plug-ins. I have PE8, need to install a plug in but where
  • vablitz May 03, 2010
    Sorry, I should have saidfor the mac!
    I dont see a plug ins folder, the only thing I show after Adobe Elements is Presets, no plug in folder
  • 249 Answers
Hi!
I believe the path for the plugin is at
C:\Program Files\Common Files\Adobe\Plug-Ins\Elements 8\File Formats\
I hope this helps.
Posted on May 03, 2010
  • 1 more comment
  • Jubert Ledesma
    Jubert Ledesma May 03, 2010
    I see, for the MAC it is at
    /Library/Application Support/Adobe/Plug-Ins/CS3/File Formats
  • Jubert Ledesma
    /Library/Application Support/Adobe/Plug-Ins/Elements 8/File Formats
  • Jubert Ledesma
    You should go into adobe. Just adobe then Plug-Ins. All plugins for adobe software go into the adobe plugin then plug-ins. After that choose the software you want to add the plugin to. Then go into File Formats.
The USB device needs a driver. I have loaded drivers from Dell support. But the USB device find not the correct driver. Who can help me? I have an Laptop from Dell. Its dell vostro 1015.
Usually, Dell directs their driver installs to put their files in the file path C:\DELL\drivers. When installing the driver for the device, select "Browse my computer for driver software" and go to the C:\DELL\drivers\ path then the file name of the driver you downloaded from Dell. This will manually point Windows to the correct driver.
May 23, 2011 | Computers & Internet
I have 7 wired computers operating from a Linksys BEFSR81 Router / 8 port switch. I would like to add a Netgear N150 Wireless Router so my kids can access the internet from their Wii in the basement . Can...
If my memory is correct even though there are 8 ports you can only use 7 of them. take out the 7th one or a couple of them if you can put them into the netgear. basically follow this: modem to linksys to netgear. as long as that path exsits they will all work. make sure to encrypt the wireless so your neighbors dont slow down your network speed or delete any of your files inadvertantly. You need to unplug from the wall electricity and have all computers off when you do this though so that they can all find then new paths. If you happen to have set up network paths with numbers suc as 192.168.123.5 and so on then you will either need to return them all to automatic or recheck these numbers after as both routers will port semi duplicate paths. When pluggin them in you may want to start plug in all the ethernet ports, then, modem, then plug in linksys plug in netgear.
now turn on all computers and printers and they should find the path automatically.
Mar 11, 2011 | NetGear WNR1000 RangeMax 150 Wireless...
Can't get webcam to work on messenger, it used to work, I must be doing something wrong do h I have to download a program
Reinstall you webcam drivers doing the following:
Unplug your webcam from your computer.
  1. Reboot your computer.
  2. Insert your webcam's manufacturer installation CD into the CD-ROM drive and follow the installation prompts.
Note: If the setup program doesn't start automatically within a few seconds, you need to manually start the installation process.
To manually start the installation process:
  1. Click Start from the taskbar in the lower-left corner of your computer screen.
  2. Open the Run window and type d:\setup in the text area.
    Note: The "d" indicates the path to your CD-ROM drive. If your CD-ROM drive is located in a different path, you need to replace the "d" with the correct path.
  3. If you've downloaded the most recent software driver from the webcam manufacturer's website, run that installation program now.
    Note: Most webcam manufacturers maintain the latest webcam software drivers on the download or support areas of their website. Just download it and save it to your computer.
  4. Follow the instructions provided by the webcam setup program.
    Note: Plug in your webcam USB cord only when prompted. (This is usually done after rebooting your computer.)
Sep 09, 2010 | Yahoo Messenger
How to install a zebra 105sl printer
Install? Well that could mean a lot of different things. Just plug it up and run the ribbon and labels through their correct paths. I don't know anything about your network. (If you even need to set it up that way.) You can just connect it to the back of your PC. Follow this link. This will tell you all about the specifications of the 105SL. Not really your connections though....... http://www.intermeccorp.com/pdf/105SLusersguide.pdf
Jul 09, 2010 | Zebra 105SL Thermal Label Printer
JAVAC IS NOT RECOGNIGED AS AN EXTERNAL OR INTERNAL COMMAND OPERABLE PROGRAM OR BATCH FILE''
Your PC - not the calculator - printed this message. It means that the PC tried to execute the Java compiler, but couldn't find the program. Either the Java compiler is not installed, or the PATH environment variable is not set correctly.
To install the Java compiler follow the instructions for installing J2SE at java.sun.com To fix the PATH environment variable: right-click on My Computer, select Properties, select Advanced System settings, select environment variables, edit or create a new variable called PATH in the system or user settings with the path of the javac.exe program. This is often found in c:Program FilesJavain (it's in a java...bin directory somewhere)
Mar 02, 2009 | Texas Instruments TI-83 Plus Calculator
Drivers for STK7700D
dear sir
to install a driver u need drvier cd if u have then open cd and chek drvier folder and select windows xp folder and chek a full path or copy full path ok now do what as i sat when "i plug in the device it is asking for drivers " menu show's u needto chek other location and then find path bar and select brows then gove full path of cd where windows xp drvier located... and go stape by stape it's help u...:)
Thanks
please vote
jo_Chinmay
Jan 05, 2009 | Acer LXA3706003 Notebook
Paper wont feed
It's just one of four things............
1. The paper is not loaded correctly on the correct path.
2. The paper is loaded correctly on the correct path but the "PAPER PATH" selected in the printer driver box or printer preference or application used is not set correctly to grab the paper from the correct path.
3. The paper path sensor is defective which means that the printer needs to be taken to a servicer or you need to contact epson for warranty options
4. The paper being used is too thick for the printer to feed it
Aug 07, 2008 | Epson Stylus Photo R1800 InkJet Printer
Installing java
Do you set the envirorment variables(Java_home), if it is ,check the path is correct or not.
Delete the ClassPath from environment variables, and set class path in command prompt by typing class PATH=%PATH%;path to java(eg:class PATH=%PATH%;C:\Programfiles\jdk1.6\bin) .
Dec 31, 2007 | Computers & Internet
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
