Question about Linksys WRT120N Router
Cannot get NAT from scrict to open for xbox live
Cannot get NAT from scrict to open, went through Xbox customer support for a whole hour on the phone who couldn't resolve the problem, i've been through the ports, plug n play enable/disable, the whole nine yards with 'applications and gaming' tab admin tab the lot i'm at my wits end with this router
  • 71 Answers
Open your router's setup page ( 192.168.1.1 ). On the initial page which is the Basic Setup , change the MTU to manual then set the size to from 1500 to 1365. Click on save settings then hit continue.
Posted on Jun 14, 2010
How do I get open nat settings for xbox live gaming? I have enabled the Xbox Live Games in the custom services but my nat setting is still strict!
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And also make sure that UPnP is Enabled
Jun 19, 2010 | Netopia (3347NWG-VGX) Wireless Router...
Xbox Console: when i sign into xbox live to play cod mw2 when ...
you NAT type is most likely not open.
Without and open NAT, you xbox live connection will not be as efficient.
I have a tip on my page with detailed instructions on how to open you NAT.
May 18, 2010 | Microsoft Xbox Console
XBOX 360 strict NAT problem
Make sure you also open the ports on your router. IF you have all the appropriate ports open and still have strict NAT, it's more than likely your ISP and you should give them a call.
Jan 07, 2010 | Microsoft Xbox 360 Elite Console - Black
Xbox 360 not connecting to online parties or games
If there is a firewall or a router between the Xbox console and the networking hardware, and the Xbox LIVE test reports a NAT problem, you may have to make configuration changes to enable communication on the specific network ports that are required by Xbox LIVE. This will not guarantee that this will give you an "open" NAT status, but it may help.
If you are using an Xbox LIVE-compatible or Windows Vista-compatible device with the correct firmware installed, you do not have to manually open any ports. For a device to gain "compatible" status, the device and the firmware must perform specific functions with Xbox LIVE. These functions include (but are not limited to) setting NAT to "Open" and having the ability to connect multiple consoles to a single router. For more information about how to find out if your networking hardware is compatible with Xbox LIVE, click the following article number to view the article in the Microsoft Knowledge Base: 944293 (http://support.microsoft.com/kb/944293/ ) How to find out if your networking hardware is compatible with the Xbox LIVE Service If your device is not on the compatible list, you can try opening the following ports:
  • TCP 80
  • UDP 88
  • UDP 3074
  • TCP 3074
  • UDP 53
  • TCP 53
For information about how to configure port settings on a firewall, a router, or a gateway, please see the documentation that was included with that device or contact your network administrator or local technical support for help. You can also check the xbox.com official forums to see if other users have the same problem.
If you use a Windows Vista-certified or Xbox LIVE-certified device and the NAT status in the Network Status area of the Dashboard is "moderate" or "strict," verify that the device has the current firmware. For information about Xbox LIVE-certified devices, such as the correct firmware version for the device, please visit the following Xbox Web site: http://winqual.microsoft.com/HCL/ProductList.aspx?m=v&cid=712&g=d
Mar 25, 2009 | Microsoft Xbox 360 Console
Change NAT to open
First make sure your security type on the router is WEP-Personal. You may need to get the port range for that game or manufacturer. Then enter them in to the gaming tab. This will keep ports open all the time. NAT 2 is acceptable but you want NAT 1. Some internet connections cannot get NAT1.reply if you need further assistance
Mar 13, 2009 | Dynex DX-E401 Router
Switching from moderate NAT connection to an open NAT connection
yo tengo problema co el asistente de conexion del linksys
Feb 10, 2009 | Linksys WRT160N Wireless Router
Change NAT to open
You need to open all the ports for the xbox live. The NAT of that router model cannot be configured to open. Its just a simple NAT for internet connection.
Feb 09, 2009 | Linksys WRT160N Wireless Router
How to fix nat on xbox live
type "msconfig" in run
then startup then disable all.
then aply ok
then restrt .
thats it.
Nov 15, 2008 | Zyxel P660HW-D1 Router
NAT set to strict, can not play on xbox live. How do I set it to open?
Reinstalled software that came withrouter and went thourgh the reconnection steps.
Now the NAT is set to open.
Mar 27, 2008 | NetGear RangeMax WPN824 Router
Strict NAT
Ok this is how its done. Open your DMZ on your router interface click enable. The IP address you'll have to enter the last digit. This IP address digit is found on your xbox, look under your xbox network setting an get the last digit of IP address an this will only set your xbox to open. bang thats how u fix it. Very simple. any Q's am @ murdock_theory@yahoo.com
Nov 30, 2007 | Belkin (F5D8231-4) Wireless Router...
Linksys WRT120N Router Logo
414 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
