Question about Dryers
Sears Kenmore gas dryer not heating up
I have a Sears Kenmore gas dryer, model 110.70912990. it runs but the heater doesn't come on. i replaced the ignitor and it didn't make a difference. one forum online talked about the thermal fuse and said to take leads off and tape them together (bypass the thermal fuse) and if it heated, the thermal fuse was the problem. it didn't heat up then either. what's the next thing to check?
  • 10,319 Answers
Remove all duct work and inspect for lint trapped inside. If you get a very good handful the moister sensor shuts down the burner automaticlly until the vents are cleaned thoroughly
Posted on May 03, 2010
Sears kenmore elite oasis dryer 110 67032600 check lint screen flashes doesn t heat
Check the vent on the back. This is indicating a air flow issue. If the vent is clear ohm the heater out check it for continuity.
You can watch a video that explains how to complete this repair on your sears Kenmore Elite clothes dryer at the link below.
Sear Kenmore Dryer Video
Mar 11, 2011 | Kenmore Elite Oasis ST 6807 Dryer
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
How do you replace the thermal fuse?
The kenmore fuse mounts on the dryer blower housing.On a gas model this fuse when blown will allow the dryer to run however on an electric model this fuse will kill the dryer. The maytag fuse mounts on the right hand side of the heater. Note: the 2 fuses that come in the kit are rated for gas or electric dryers. When this fuse blows the dryer will be dead. The GE fuse mounts in the rear on the heater element pan. When this fuse blows the dryer will continue to run but their will be no heat. Dryer duct fuses are used on various brands of dryers as a back up they usually come in pairs with one mounted on the heater and another near the blower. The kenmore hi limit will kill the heater element but not kill the machine, it mounts on top of the heater housing. The bottom limit comes with it, always replace them both when repairing the dryer.
Dec 22, 2009 | Dryers
My kenmore dryer model 86873100 will not heat
gas or electric? if it runs, check the heating element for a break. make sure the dryer venting is cleaned or the safety on the heater element will shut off the heat to prevent a fire. you may also need a thermal cut out kit which is mounted on the heater assembly.
Oct 11, 2009 | Kenmore 62602 Electric Dryer
Kenmore Model 110.76912691 gas dryer that heats intermitently
Replace the solenoids on the gas valve. These are often intermittent befor total failure. Hope this helps!
Feb 26, 2009 | Kenmore 63942 Dryer
Dryer not getting hot
fist make sure the fuses are good.. unit will run on 110 but not heat.. check connectores and cables or pigtail. it not.. then check heater coils and or thermostat...
Jun 13, 2008 | Kenmore Dryers
I need a schematic for Kenmore dryer number 417.93052201
sears.com enter your model theyll have a wiring diagram there for you
Mar 06, 2008 | Kenmore 74602 Gas Dryer
Dryers Logo
167 people viewed this question
Top Dryers Experts
