Question about GE Security Simon 3 Wireless Home Security System
I have a simon 3 alarm system and I wanna know if it is possible to effectively connect 2 main control panels in series
    New Friend:
  • 74 Answers
It is not possible.
AlarmProfessor.net
Posted on Aug 23, 2010
Hello. there seems to be a beeping noise coming from the control box itself and it says to check status, but i'm afraid to push anything. thank you
Troubleshooting a GE Simon XT: Clear Errors and Alerts ...
? 3:06
https://www.youtube.com/watch?v=AtOCuthlsTo
Oct 3, 2011 - Uploaded by LiveWatch Security
Troubleshooting a GE Simon XT: Clear Errors and Alerts -Wireless Home Security ... Many times the Simon XT panel willbeep to indicate there is something ... How do you turn off the warning beep when you turn on alarm? I find it very useless and annoying. Can't seem to find a way to turn that feature off.
My Simon XT is beeping every 4 hours. How can I stop it ...
help.livewatch.com/.../20399861-My-Simon-XT-is-beeping-every-4-ho...
Aug 28, 2011 - If your panel has been beeping throughout the day and you want to turn off ... Scroll down on the Simon XT until you see "System Programming".Missing: control ‎hello ‎control ‎box
Jan 11, 2016 | GE Security Simon Xt Wireless Control...
I have a adt simon 2 alarm system which is no longer monitored by adt. I accidently pressed the phone test button twice and now it continually beeps. How can i cancel the phone test, I've tried...
Get the front cover open by pushing the tab at the top of the panel down while pulling on it. When the cover is down enter the 4 digit master code using the red numbered keys. On the left you will fine a small menu that list different "options". You want to turn "option 1 off." To turn off option 1: Hit the delete key then the option button one time for option one finally push the bigger button in the left bottom corner. I think it's labeled enter or something to that effect. You can listen to the prompting of the panel to know exactly which one to push. After that close the front flap and no more beeping will happen. You will still get the siren in the event of an alarm but trouble conditions and entry exit beeps will be no more. I hope that helps!
Jun 19, 2014 | GE Security Simon 3 Wireless Home Security...
I have a GE Simon Security System with a GE Simon 3- X10 Line Carrier Transformer that powers a siren. Since the X10 transformer was installed, I constantly get sensor 'failures.' Although the panel...
X10 is a signal format transmitted over the power lines, there is no special X10 wiring in the house as such. The siren and your outside lights are X10 receivers which are sent a signal from the X10 transformer connected to the alarm panel. The alarm panel sends the codes which are transmitted as X10 to the X10 external devices. Most houses now days have at least two 120 volt feeds coming into the main power panel, this provides the 240 volt required for electric stoves and dryers. Because of the two separate feeds split at the panel, the 60 cycles is usually out of phase with each other. To get X10 to work and stay in phase on each side of the panel you need to have wired a passive coupler across both 120 volt inputs. This coupler keeps both 120 inputs in phase with each other and provides a clear X10 transmit across the house wiring.
Dec 19, 2010 | GE Security Simon 3 Wireless Home Security...
Don't know access code. Bought used control panel
2. Unplug the transformer and disconnect the battery.
3. Simultaneously press and hold Cancel, Clock Set, and
Minutes +.
4. Restore power to the panel with either the battery or the
transformer while pressing these three buttons. The
panel announces “Hello. System XX OK.” Release the
buttons.
5. Connect the remaining power source to the panel.
- AlarmProfessor.net
Jul 16, 2010 | GE Security Simon 3 Wireless Home Security...
SIMON 3 panel acknowledge code?
Check and make sure they did not put a secondary number in Option 5. also I would delete the account# in Option 7.
AlarmProfessor.net
May 05, 2010 | GE Security Simon 3 Wireless Home Security...
GE Simon 3 Installation Transformer vs. GFI...Need Help!!!
I have been installing alarm systems for over 30 years. A GFI circuit's main purpose is to kick the breaker to prevent electrical shock. You will most likely find these in kitchens, bathrooms, outdoors and basements. The reason most alarm manufacturers do not want you plugging into one of these is they are sensitive to humidity and are more suseptical to cutting off electric power to the outlet. Therefore they are less reliable in providing power to your alarm system. Over the years there have been situations where I had no other choice but to plug into a GFI circuit. Doing this will not harm the system but it will increse your chances of losing power to the system.
Nov 24, 2009 | GE Security Simon 3 Wireless Home Security...
I have ge simon 3 which suddenly says phone not
you may have had a lighting strike to the phone line causing a surg to your unit. it may be fried. try completly powering down the system and powering it back up, then try to send a signal to your monitoring station. also you my have your monitorimg station try and connect to your system and check the programing it may have been scrambled.
mj
Apr 02, 2009 | GE Security Simon 3 Wireless Home Security...
Westinghouse Security System beeping
Hot is ok in an alarm box, especially inside where you see your finned heatsink and capacitors, if it beeps it might be because you have a communication problem, a weak backup battery or else. Check if you have any codes being displayed on your LCD or LED and check in the signification in your user manual if any. If you are connected to an alarm central they should be able to tell you what is the problem by connecting remotelly to your system. If not, well I need more details.!
Thanks,
Lucucs123
Nov 28, 2008 | GE Security Simon 3 Wireless Home Security...
DTIM with digial phone service
I install these types of alarms.
First, What is usuallly plugged into the cables main box? Usually it is a jack. This would run to the main phone lines in the house, and allow you to have service at alll the jacks in the house. If this was not the case, then you usually just plug your phone in directly. Either way, the tel #1/2 on the main box is the same principal as the two main lines comming in off the street with the phone company. If there is a jack, get another and a peice of 2/4 strand wire. (If you have a 8 pin bell jack let me know if not follow.) connect the red and green at the main jack to the red and green of the new jack. Plug in the DTIM and go. If it is just a plug in the phone directly then i suggest getting three jacks. plug a regular phone cable from tel 1/2 into the first jack. Then connect the red and green to the next red and green. this is the DTIM jack. Then do the same to connect a phone jack for your phone. I have installed lots of simon 3 systems but never with a DTIM> I also install alot of GE Allegro panels and they come with the DTIMs. Are you having it learn in properly? It should be group 39 on the system. At least it is on the other panels.
Good luck.
Sep 08, 2007 | GE Security Simon 3 Wireless Home Security...
Using DTIM with digital phone service
It turns out that because Comcast uses VoIP, the Simon can't use it to call in reports. I ended up having to switch monitoring companies to one that specifically uses internet monitoring. The solution was to buy/install a wireless g bridge into the phone output on the alarm panel, and then connect it (wirelessly) to my home network. No major problems since then.
GE Security Simon 3 Wireless Home Security System Logo
37 people viewed this question
Top GE Home Security Experts
Michael Galve
Michael Galve
Are you a GE Home Security Expert? Answer questions, earn points and help others
