Question about Frigidaire ATF6000ES Front Load Washer
Won't spin out on normal wash cycle
My front load washer won't complete the whole cycle. only the majority of the water drains out and i does not spin out unless you move dial to rince and spin. Any solutions?
  • 1 more comment
  • dorcaslb Mar 27, 2008
    Had a repairman in - twice. Ran a load on hot water with bleach. Tried all the different settings. Tried washing loads with only like fabrics (i.e. only towels). I have to end every load (which now takes an hour) by switching to the final spin setting. It does the fast spin there no problem. Frigidaire customer support is not very supportive. They really do have a problem with this machine but they don't seem willing to admit it or deal with it.
  • kierapeters Mar 29, 2008
    Same problem, except my washer wil stop and show error code "E20". Only way to stop 2hr washing is to place on "spin only" and then cycle will end asfter about 30 minutes. Any help would be much appreciated:)
  • Anonymous Jan 12, 2009
    I have to individually change my setting from wash to rinse and then to spin. When the spin is complete my clothes still don't feel as dry as they use too.
  • 3 Answers
I think I figured this one out. I think it means that the washer is not able to drain, therefore it won't spin either. Underneath the washer is a series of outlet hoses and within one of them is a filter. When I finally found the filter it was clogged up with lint, fibers from a pillow and coins. You have to dig the filter out and then clean the filter and rehook up the hoses, this was relatively simple even for me. The washer works perfectly now.
Posted on Apr 07, 2008
Water will not drain out of the washing machine and won't complete cycle.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 10, 2011 | Kenmore Washing Machines
Ge washer won't let water spin out
heatman101
Aug 11, 2011 | GE 3.2 Cu. Ft. 6-Cycle Super Capacity...
My washer will not empty all of the water out on the spin cycle, it does not matter which wash cycle I have put it on. I have even tried the Drain and Spin cycle. I have even taken all of the clothes out...
heatman101
Apr 15, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Door will not close
Make sure you are allowing the washer to completely finish its cycle before opening the door. It is normal for the door to lock at the end of a cycle. The locking mechanism keeps owners from opening the door before all of the water has been drained. If the door on the washer is locked, select the "Drain" or "Spin" options on the front-load washer. This will completely drain the water from the system and unlock the door, allowing you to open it.
Thank you !!
Jul 09, 2010 | Frigidaire ATF6000ES Front Load Washer
Can't get the door open
Thank you !!
Jul 06, 2010 | Frigidaire ATF6000ES Front Load Washer
Standing water in the washer hours after wash cycle completes
YES..I think drain hose @ sink too low Waste water from sink entering machine...Raise pipe....tie up ....
Apr 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Our hoover ultra care 1300 large load washing machine spin fault
The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
If this is not the case please post back for further assistance.
Jan 21, 2009 | Hoover UltraCare HC6 130M Front Load...
Washer won't drain and clothes stay soaked
Can you give me a model and brand name. Does the washer drain at any time during the wash cycle?
Will it go into a spin at all in any setting? heavy duty, normal and delicate cycle? is water not draining?
Jan 11, 2009 | Frigidaire ATF6000ES Front Load Washer
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Frigidaire ATF6000ES Front Load Washer Logo
254 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
