Question about Cycling
Hi- I am just wondering what weight crankcase oil I need for my son's SSR SR 125 pitbike. Is it SAE 30?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,508 Answers
You will need a multi grade four stroke motorcycle engine oil SAE 20-40 or similar, Make certain it says motorcycle oil, as the car oils can cause clutch slippage
Posted on May 03, 2010
Oil is coming out of the vacuum line just above the front sprocket on my Apollo DB 125cc pit bike
Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://www.miniriders.com/chinese-mini-s/35846-apollo-125cc-pitbike.html
new SSR 125 pitbike has oil leaking need help
Apollo DB X7 125cc Manual
http://mypitbike.ru/downloads/OrionAssemblyInstructions.pdf
http://getthemax.com/shop/powersports-products/manuals/apollo-125cc-dirt-bike-owners-manual-pdf
Mar 19, 2016 | Pit Motorcycles
I changed the oil on my sears riding mower and it run fine for over an hour and then started smoking real bad.
What weight of motor oil did you put into the tractor? And how much? The capacity of the crankcase is 1.7L (1.75 qt.). The recommended engine oil is SAE 30. If you put a 10W-30 product into the engine and operated it under heavy load or heat conditions, the oil may not be capable of providing sufficient lubrication.
Aug 05, 2014 | Craftsman Garden
98902-2065-B1 briggs & stratton oil:petrol ratio pls
This is a 4 stroke engine which requires an sae 30 weight oil in the crankcase and straight gasoline (petrol) in the fuel tank
Jan 19, 2013 | Briggs & Stratton Garden
Hi i have a Sym 125 xs motorbike and just wanted to know what sort of oil i need to do an oil change??
SH/CD SAE 10W-30 grade or better engine oil.
Oil Capacity : 0.9 Liter (0.8 liters for routine change), oil filter change: 0.8 liters.
Oct 07, 2012 | 2011 Sym XS125K
2005 Honda XR 125 L fork oil capacity
Front Fork Oil cc (right leg):170
Front Fork Oil cc (left leg):170
Fork oil grade:10w
Valve Clearance Cold - Inlet:0.08
Valve Clearance Cold - Exhaust:0.08
Engine Oil Grade SAE:10w/30
Engine Oil Classification API:sg
Engine Oil quantity with filter (litres):0.9
Idle Speed (rpm):1400 - 1500
Spark Plugs Gap (mm):0.8 - 0.9
2 Stroke Tank - Litres:No
Float Height:14 mm
May 29, 2012 | 2005 Honda XR 125 L
How much oil and what kind of oil should I use in the crankcase
Here is an owners manual for model 316791961 (7.99 mb)
http://www.managemylife.com/mmh/lis_pdf/OWNM/1012092L.pdf
Parts listing 316791961
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Grass-trimmer-weed-wacker-Parts/Model-316791961/0247/1503820?sid=MMLxMerchandizexManualsModelxx316791961
Oil: (SAE 30 3.04 Oz.)
ADDING OiL TO CRANKCASE: iNiTiAL USE
NOTE: This unit is shipped without oil. In order to avoid damage to the
unit, put oil in the crankcase before attempting to start the unit.
The unit is supplied with one 3.04 fluid oz. (90 ml) bottle of SAE 30 SF, SG,
SH oil (Fig. 6).
Thanks for choosing FixYa,
Kelly
Jul 28, 2011 | Craftsman 29cc 4Cycle Straight Shaft...
2 or 4 cycle oil for a Ranch King 6.0 lawn mower? What kind or type of oil should use?
If you mean oil for the crankcase use need 4 cycle oil Ususally 30 weight and don't over fill Most small engine do not even take a quart only about 20 oz.
If you mean to mix with gas ( I doubt this) but then you need 2 cycle oil depending on the mixture usually about 3 oz to a gallon of gas (3.2 oz / gal = 40:1 ratio, 2.5 oz/ =50:1)
May 24, 2011 | Briggs & Stratton Garden
What motor oil is recommended for the 2003 SSR?
Look on the oil fill cap. Write down what it says then call around to find out who has this class of oil.You might even call the Chevy dealer and ask for the service manager, ask him .I like the Castrol Syntec 10w-30 for my 2001 Chevy Monte Carlo.
Oct 27, 2009 | 2003 Chevrolet SSR
Cycling Logo
76 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
