Question about Akai LCT3201AD 32 in. LCD Television
Wont turn on, red light just blinks. prior to this, it was getting hot, and shut off. put a small fan behind it, worked fine for about 3 months, now nothing. I have the base off already how can you help?
  • bandit33hg May 03, 2010
    no i reject this solution
  • 712 Answers
Try having a look at the t.v transformer. If its damaged you can feel this thing. That is as soon as you switch the t.v on it goes off. The time taken to go off reduces as days passes. If it is so, don't hesitate to get it replaced. It is small and cheap and is readily available in the market. Go for the best one or else the new one too can go out soon.
Posted on May 03, 2010
  • 11,896 Answers
Most likely a capacitor or power supply is faulty. You can test power supply with a voltmeter. If it turns out ok, then get a analog meter and ohmmeter and test your capacitors.
Check for any swollen cpacitors and resistors and look for any burn marks on the board.
My ps3 turns off a couple of seconds after it is turned on then the red power light blinks
If your PS3 console attempts to turn on, then beeps and a yellow light comes on and then your Sony PlayStation 3 shuts down or does not power on at all or shows no video means YLOD or Yellow Light Of death has occurred! A guy had same problem with His console 6 months back, He was able to fix it for 15 bucks ! without sending it to Sony for costly repair.
Jun 07, 2012 | Sony Playstation 3 (PS3) Console
We just bought a house and the living room has a light fixture and there is a dimmer switch that controls it. I removed the light fixture and installed a ceiling fan but the fan barely moves and the light...
You're correct. The dimmer switch was not made for that fan.
The Green is ground > so you're right there too. I assume other plugs nearby are working when dimmer is on. Check that to make sure.
By your description, I assume there is NOT another switch or dimmer that connects to same light. If so, you need a 3-way switch and the following instructions are void.
I suspect when you wired the new fan, that you saw the red and small black wires in the ceiling box. Did you connect the fan and light to those wires? If so, the following information will help you wire the switch.
Your incoming Hot line is probably the larger black wire that connects to Dimmer black >>> this wire will connect to either screw on the new switch
To test Hot wire for sure: Take out dimmer and mark wires for identification. Separate wires. Turn on power and test each wire to bare ground. Tape tester leads to wood sticks so hands are away from power. You'll be fine. Tester lights up on Hot wire.
Next: The smaller black and a red wires are a toss up.
Here's how I would proceed. Connect the black Hot to either screw on switch. Connect red wire to other screw. Put wire nut over small black. Turn on power. Flip switch. Check both lights and fan to see which works with red wire.
Next reverse the toss up wires. Put wire nut over red. Connect small black to switch. Check both lights and fan.
If red and small black control the light & fan, then connect them together on the same screw, and you're done.
If you want to control the fan and light separately, buy double switch, and then Hot connects to dark-colored screw on one side of switch, and red and small black connect to two different screws on opposite side of switch.
Oct 04, 2010 | Solar 10 Eagle Almond Commercial Double...
My playstation just shut off an the red light flashes
do you get a yellow light? i bet you do..
1)Turn off your playstation 3. If you think your ps3 has been caught by the heat, then wait at least 20 minutes and put it back on again
2) Check if there's any loose cable.
3) Try to put out your playstation's hard-drive, and put it back in. You might want to repeat this 2-3 times for better results.
If this did not work
Send your playstation back to Sony
May 09, 2010 | Sony Playstation 3 (PS3) Console
61" samsung DLP 3 years old. Keeps turning off by itself.
Get a small but powerful used computer fan and place it in the TV to replace the defective old fan.That's the best way.The factory fans in these TVs don't last.
Sep 09, 2009 | Samsung DLP HL-P5663W 56" TV
My ps2 runs for ten mins then shuts off
Feel it and see if it's hot, It may be overheating. If so they have small fans that you plug into the usb port in the front.
Jun 26, 2009 | Sony PlayStation 2 (PS2) Console
My ps3 wont turn on
Hi There,
Your Processor needs reflowing (re soldering on the board) as the system over heated, it caused stress on the solder joints underneath.
Sony charge £150 and give a month warranty to repair it.
We charge £60.00 and give a 6 month warranty.
FixMyConsole
Jun 16, 2009 | Sony Playstation 3 (PS3) Console
My ps3 wont turn on
HI, the power supply is unstable or weak. you will need to replace this failing power supply soon. it is damaged.
KDS R60XBR1 Red Light blinks 3 times when turning
on my xbr tv there is a little *** that sticks out on the lamp cover. the wrapped and it wont work light flashed 3 time with a new cover it worked fine. there was a t. s. b. for an over heat problem new fan and sensor and door. go to sony.com its there
Mar 22, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Akai LCT3201AD 32 in. LCD Television Logo
115 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
