Question about Delstar DS 31024 MP3 Player
Headphone jack is missing
Can i send i back
  • 21 Answers
There are two jacks on this model......
Posted on Apr 29, 2008
Pioneer VSX-456 headphone jack problem
No the headphone jack doesn't disable the speakers. There are two switches in the lower middle of the receiver that are labeled speaker A and B. Pushing one of these should disconnect the speakers from the receiver.
Feb 16, 2014 | Audio Players & Recorders
Same problem as below, I have the Denon AVR 790 and the sound keeps switching to headphones. Blowing into the socket did not help. Both unpluging the AV and putting the headphones in and out fix's the...
The unit thinks there are headphone plugged in even when there are not. You need to have the headphone jack replaced. This is a common problem with this model. Another way to fix it if you don't plan on using the headphone jack is to unplug the cable going to the headphone jack board. This will disable the headphone jack, and stop it from sending an erroneous signal to the micro.
Jan 31, 2014 | Denon Avr-790 - 7.1 Channel Home Theatre...
Sony stereo mhc-gx9900 audio doesnt come out of speaker thou all lights show its playing
There is a intermittent problem on the main board, or the headphone jack is dirty or worn contacts, buy electronic cleaner, spray into headphone jack or earphone jack, slide headphone jack in and out as you spray the contact cleaner, do this several times in a attempt to restore audio.
Apr 06, 2012 | Sony MHC-GX9900 Shelf System
Yamaha CP 300 broken headphone jack
Some keyboards use the amp output sockets for headphone use.
You might need some adapters for your headphones.
If it fell in, you would see an empty hole. This would be unlikely because it is held on by two screws. If all fails, buy an amp with a headphone jack input. Plug the keyboard into the amp and use the amps jack.
Dec 15, 2011 | Yamaha CP300 Stage Digital Piano...
My acer laptop 5728Z headphone jack is not working. when i plug in the headphones no sound comes through them.. however the main speakers work. can you please help me.
this happen to me too, i had to send it back to acer under warrenty and they replaced the headphone jack :) some of them are having issues
Dec 14, 2010 | Acer (54.AA806.001) Sound Card
I am having the same problem with a twist, sound works from the fm and headphone but only from the right side no left audio. I have the 760 and it only has one speaker and my guess it that it gets its feed...
If you use the headphone jack a lot and your missing the audio from the speaker and one channel from the headphone jack, then it's possible that some of the headphone jack connections have broken off of the PC board. The audio goes to the speaker through the headphone jack.
Please see this link for more info and read the section about the headphone jack.
http://www.sharc.net/gps_audio_repair.htm
- Jim
Dec 19, 2009 | Garmin Nuvi 760 Car GPS Receiver
Soundcard problem on D530 SFF
Sounds like the audio return wires aren't connected. On the motherboard, there is a sound jack on the back left side of the mobo. The jacks from the front audio panel connects to it. Both the Left and Right channel have an out and an in connector. These send the signal to the headphone jack on the front panel and return the signal to the rear output jack if a headphone is not connected. Look for looe or broken wires. The other spot to check is the front headphone jack. If a headphone plug was pulled out or pulled sideways, it could break the solder joint on the PCB panel or break the shunt feeding the singal to the rear jacks. Hope this helps.
Ron
Apr 13, 2008 | HP Compaq Business d530 PC Desktop
Garmin GPS - suddenly has no sound - it just cut out
1. Are you sure the volume setting is all the way up?
2. Are you sure the sound isn't muted?
3. Have you tried a pair of headphones in the headphone jack? If the headphones have sound, your internal speaker is bad. If you don't feel like sending it back for repair, you can purchase a FM transmitter like those used on IPODs and CDplayers and plug into your GPS's headphone jack and play the audio through your car's FM stereo.
4. If you don't hear sound from the headphone jack, most likely the audio output section is defective and you'll need to send it back to Garmin to be repaired.
Please let me know if I can be of further assistance to you.
- Jim
Mar 17, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi
3. Have you tried a pair of headphones in the headphone jack? If the headphones have sound, your internal speaker is bad. If you don't feel like sending it back for repair, you can purchase a FM transmitter like those used on IPODs and CD players and plug into your GPS's headphone jack and play the audio through your car's FM stereo.
- Jim
Feb 13, 2008 | Garmin Nuvi 660 GPS Receiver
Delstar DS 31024 MP3 Player Logo
18 people viewed this question
Top Delstar Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Delstar Audio Player and Recorder Expert? Answer questions, earn points and help others
