Question about Linksys Wireless-G Broadband Router
I cant get my router to connect with my new at&t modem
  • 2,260 Answers
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Posted on May 03, 2010
I reset my modem and now i cant get my wifi back on
If your modem pulled a new or different ip address and you did not reset your router it could be trying to use the old IP address and there would be a conflict. IP addresses usually have a lease of 24 hours, S if your IP was refreshed at noon and you reset your mdem and for sopme reason it obtained a new ip address the router would not be able to connect until noon the following day when it tried to refresh. Rebooting the router should cause it to sync back up with the modem and pull the correct IP address. You may need to log into your router and manually release and renew the IP address even after rebooting your router, I have seen a few routers that would still not pull the new address unless this was done.
My preferred method is to unplug power from the router, then reboot the modem. Only after the modem is synced back up do I plug power back into the router, so far this has seemed to work the best.
Jan 30, 2013 | Smcd3gn-res Wireless Router Cable Modem...
I have my router hooked to my cable modem. Its been working great. Then all of a sudden i have no wireless, then no cable modem. The router an orange or red color. When i unhook the router my cable modem...
Hi Jason
To get the connection back all you need to do is just connect the modem to the router to the yello port & computer to any gray port on the router.
& unplugg the power from the router first & then from the cable modem. Wait 30sec & plug the power to the cable modem first & then once the modem is on completly plug the power to the belkin router.
The light will turn green & start working.
This is an intermittent connection.
To avoid this happening over & over kindly update the firmware in the router.
you can login to the belkin.com/support web site to download & know the procedures to update the firmware in the router.
Thanks
Dec 28, 2010 | Belkin Connect N150 Wireless Router...
No internet connection when router is connected
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
then you need to connect the computer to the router and the modem to the router.
Apr 23, 2010 | Linksys Wireless-G Broadband Router
My router cant connect to the internet through the modem and i cant acces my rfouter setting cause cant install it
How to quickly install and use your Belkin wireless G router 1. Step 1
Position your Belkin wireless G router.
Place your wireless G router in a wide open and central location. Don't connect the power plug into the router, yet. Make sure your computer is turned off.
2. Step 2
Connect all the devices.
Find the Ethernet cable that connects your PC to the modem. Unplug the Ethernet cable from your PC and insert it into the wireless G router's WAN port. You should have an additional Ethernet cable that came with your router. Take this cable and plug one end into one of the LAN ports on the router. Then connect the other end to your PC's Ethernet port.
3. Step 3
Turn on your modem, router, and PC.
Plug the power plug adapter into the modem. Turn on the modem. It'll take approximately 30 seconds for the modem to boot up. Connect the power plug adapter to the router and the other end into a power strip or outlet. Like the modem, it'll take about 30 seconds for the router to boot. Turn on your PC.
4. Step 4
Verify lights are on for your devices.
Make sure the following lights are on for your router: power, WAN, and LAN light. If you don't see any of them lit, confirm these devices are turned on. Make sure the Ethernet cable connections are installed correctly.
5. Step 5
Install and configure software.
Use the setup wizard application to configure your Belkin wireless G router. Set up features, such as creating your password and setting up your time zone. Continue to follow the setup wizard so you can configure  other settings.
or folow the link you will get all your solution
http://www.google.co.in/images?hl=en&rlz=1R2SKPB_en&q=linksys+router+setup&um=1&ie=UTF-8&source=univ&ei=PzPPS_e-I4a1rAeYxryFAQ&sa=X&oi=image_result_group&ct=title&resnum=4&ved=0CCEQsAQwAw
Apr 21, 2010 | Linksys WRT300N Wireless Router
We had to replace our modem & our wireless router isn't working
You have got a new modem. You will need to change the settings of the router according to the new modem.
First make sure that your computer is able to go online when connected directly to the modem. If that works then connect the computer to the router and the modem to the router.
open the set up page of the router and set up the router.
Click here for more info
Nov 28, 2009 | Dynex Wireless-G Broadband Router
DLink wireless router will not connect to internet we have a new modem, tried connecting through a cable, and wireless, tried new cables, rebooting, resetting and all standard procedures. Is there...
It's the modem, not the wireless router that is the problem.
The modem must have the proper account name & password for it to work.
Test:
Connect a computer directly into the modem (without router). The modem has an Ethernet connector. If you can't get Internet by connecting a computer directly to the modem, then you will never get the router to work.
Contact your ISP. They may not give you the account name / password, but instead do a service call to your location.
Oct 06, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Belkin N wireless modem router cant connect
http://en-us-support.belkin.com/app/answers/detail/a_id/534/kw/7001/r_id/166
go this website select your version and model number download the drivers and install
go to ->run>services.msc
select wireless zero configuration -.>right click and start it
Jul 17, 2009 | Belkin (F5D7001) 802.11g/b Wireless...
Buffalo wireless g router wont connect to old speedtouch modem
To fix this issue all you have to do is,
Confirm the model number & version of your router and check for firmware update
A It may be quiet difficult for you to do all this.please call toll free number"belkin"
.........Hope this is help full for you............
Apr 29, 2009 | Belkin (F5D7230-4) Router (587009)
Trying to set my ps3 up with the motorola sb5100i
i dont know baby. try it yourself. dont give it up darling.....................
Jan 10, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Linksys Wireless-G Broadband Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
