Question about Remington 16" Electric Chain Saw
Looking to download manual for Remington 16" 3.5hp chain saw.
    President:
  • 2,220 Answers
Remington.com
http://shoppingcart.msservicecompany.com/Default.aspx
Type "YourModelNumber" into the "Search for your unit by Model:" window, then click search.
Click the “YourModelNumber” - Remington Electric Chain Saw "View Model" link.
Click “View Owners Manual” or "View Illustrated Parts Diagram" link.
Type "YourPartNumber" into the “Search for your parts by Part #:” window, then click search.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 03, 2010
5 Suggested Answers
firesnake09
  • 2923 Answers
SOURCE: Owners Manual for a Remington 2.5 HP 16 '' Chain saw, Model EL-7
Kindly check this link for manual. Please select the correct model:
http://lawnandgarden.owneriq.net/manuals/mfg/remington/remington_chainsaw_product_list.html
Posted on Apr 18, 2009
woobie dog
  • 1273 Answers
SOURCE: replacing Remington Electric chain saw blade
Where the bar meets the body of the saw there is an adjustment lug that will either push the bar outward tightening the chain or may be retracted allowing slack in the chain. When backed off (loosened) sufficiently, the chain may be removed for replacement. In order to use this feature, however, there are two bolts that secure the bar to the body that must be loosened prior to any adjustment and tightened bach up after making adjustments to the chain. The above will be enough to remove and replae the chain. If you are taking off the bar (that the chain runs on), you will need to remove the two bolts that were just loosened for the chain adjustment (above).
Regards! --WoobieDog--
Posted on Jul 07, 2009
  • 699 Answers
SOURCE: lost manual need to know what kind/weight oil does
Any good quality chain saw 'bar' oil is suitable and it does not need to be an expensve brand either: it is highly recommended that you use a specially blended chain saw 'bar' oil but in emergency you can you fresh 'thick' (e.g. older) car engine oil but don't make it a habit as your chain and bar will wear off a lot faster!
Posted on Mar 06, 2010
Testimonial: "Thank you very much. I appreciate the quick response. Nora Herron Tallahassee, Florida"
  • 623 Answers
SOURCE: need the manual for remington 16" electric chain
Here's the link for the saw:
http://www.remingtonpowertools.com/data/manuals/769-05150.pdf
Posted on Jun 22, 2010
The chain came off of my Remington 16" electric saw. How do I put the chain back on?
If the saw was at speed when the chain came off there are probably burrs on the chain drive links (the part that goes in the bar). They often cause binding and in extreme case may cause the chain to ride up and off the bar when operated. Use a file on the drive link flats to remove all burrs.
An Operator Manual far almost all models of RemingtonPower chainsaws can be found here:
Remington.com
http://www.desaparts.com/index.htm
  • Type "YourModelNo" into the "Model #:" window, then click search.
  • Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Breakdown" link.
HTH
Lou
Dec 28, 2009 | Remington 16" Electric Chain Saw
I have a Remington Electric Chain Saw and have lost the manual. Where can I get one? Model No. M15014US 14'' Bar 114731-01S Chain 114735-01S I have tried searching the Web for one and can't get a...
Remington.com
Enter M15014US (your saw) in the “Search for your unit by Model” window. You can find both an Operator's Manual and IPL. I recommend you download both.
Item 4 lists available bars for your saw, a 14" bar for your saw is pn 114731-01S, $17.85 if available.
Item 5 lists available chains for your saw, a 14" chain for your saw is pn 114735-01S updates to M14SC
, $12.95 if available. You can probably take your chain to a neighborhood chainsaw shop and have a replacement made cheaper.
Remington has ceased production and replacement parts are limited to what is on hand. HTH
Lou
Oct 29, 2009 | Remington Electric Chain Saw
I am probably in wrong place, but am looking for owner/operator manual for remington electric chain saw...can you help me? Thanks
Posted by lsg2111 on Jul 13, 2009
What is the model number of your saw. It is located on the saw itself. If you can get me that I can try to see if I have that model available
You must help us if we are to help you!
Jul 10, 2009 | Remington 16" Electric Chain Saw
Apr 18, 2009 | Remington Garden
I need an owner's manual for a remington electric chain saw
Here is the owner's manual for the M30016AW... http://12.153.20.74/manuals/113005-01G.PDF. Here is also the instructions on the installation for the chain that goes on the your saw ... http://12.153.20.74/manuals/113556-01A.pdf. If you are need of a part you can conatct Master Parts at 800-446-1446, they can also help you. I hope this helps!
Apr 10, 2009 | Remington Garden
What type of oil do I use for a Remington Electric Pole Saw?
While Bar Chain oil will probably work, the owners manual (sitting in front of me) on page 9 says to "use SAE #30 motor oil". This is the owners manual for Models: M12510US, M15012US, M15014US, M15014AS, M30016US, M30016AS, M30016AW, M35016UW, M35016AW. Remington Electric Chain Saw
Mar 13, 2009 | Remington 16" Electric Chain Saw
Remington 16 in. electric chain saw
Go to www.masterparts.net Remington chain saws are listed by bar length and model number. There is a parts list with each saw.
Oct 27, 2008 | Remington Electric Chain Saw
Remington 16" Electric Chain Saw Logo
282 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
roeb
Are you a Remington Garden Expert? Answer questions, earn points and help others
