Question about Miele 24 in. G638 Plus Free-standing Dishwasher
Dishwasher repair problem Miele G368SCI plus
The pump shaft seal on model G368SCI plus has perished How can I repair this without buying the whole pump
  • 11,896 Answers
You can buy the seal at partselect website.
Posted on May 03, 2010
Miele dishwasher G646 SC plus water pump
I would suggest any appliance repair shop or appliance retail store should be able to order one in for you
Sep 06, 2012 | Miele Dishwashers
Hello, My dishwasher isn't draining the water away, it is approx 13 years old but not used to much in that time; Do you think I should buy a new one or get it fixed: it could be only a small problem: ...
On the whole dishwashers are simple devices.
A controller tells a pump what to do - push water around the machine or push water into the drain.
Miele machines have a very good record for lasting over 20 years.
If you are a "handy person" you could try checking the hose to the drain is clear - blocked hose won't drain.
Have you checked the filter system inside the machine - at the bottom of the d/washer under the bottom spinning arm? If this is blocked - no drain - so clean it well.
If little checks like this are all OK well its up to you - repairs could cost £60 - £80 a new Miele would be nearer £400.
Try to get it fixed its kinder to the planet - and your pocket.
Good Luck.
Mar 25, 2011 | Miele Premier-Plus Built-in Dishwasher
F14 problem with miele dishwasher model G2270SCVI WOULD be grateful for your assistance asap as nothing in manual explains what to do. many thanks
Hi F14 is when the pump pressure switch does not operate. This can be caused by several things. Circulation motor blocked or defective. Insufficient quantity of water in appliance.Most commonly it is debris in circulation pump.This will require motor to be removed and cleaned.appliance will have to be un-installed
Jun 17, 2010 | Miele Premier-Plus Built-in Dishwasher
Dishwasher stops after 10 minutes inlet/drain light flashing
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
May 31, 2009 | Miele 24 in. G646SC Plus Free-Standing...
Miele G841 Built in. Intake/Drain light on/flashing and the dishwasher just shuts down.
I had a similar problem with a different Miele. I found that under the door, there is a removable trim panel (may not be one on yours). Under the trim panel was an acoustically sealed metal plate held by a couple of screws. i switched off and disconnected the electrity, then removed the plate. The bottom tray was filled with a big puddle. I cleaned that up and put the machine back together and it ran fine. Accordingly, I'm getting some replacement shaft seals for the thing as it looks like its worth fixing. Good luck with yours. rupertvdP
May 31, 2009 | Miele 23 in. Novotronic G841 Built-In...
Change miele dishwasher door seal
http://www.partstap.com/ please go to this site for diagram please rate me thank you for useing fixya
Feb 25, 2009 | Miele Dishwashers
Inlet/drain light has come on on Miele G892 SCU plus dishwasher how do I sort it without an engineer
I haven't worked on your model. However in general you first need to go through the user manual checks to make certain you've not got a silly. Follow their safety instructions. Manuals are available on their websites e.g. http://www.miele.com/manuals/display_manuals.aspx?bhcp=1
Check the drain pump and non return valve are OK and not blocked.
Check the inlet pipe strainer is clear, and if necessary clean it and descale it.
Check you've got water coming out of the outlet on the wall (carefully, its wet - make certain it doesn't go on the electrics)
Test the fixed drain and hose if the machine is empty by putting some water in it and then turning it on - it should drain in my experience.
If all the above is OK, its possible that the machine has leaked into the bottom tray. You'd need to shut off and disconnect the electricity then open up the bottom compartment of the machine - often a plate on the front behind the kickboard trim. If it has got water in, I'd mop it out and then put it back together. i'd then try running the machine. If it worked in that state I'd bother to replace the leaking seals e.g. on a pump shaft.
rupertvdP,
Dec 14, 2008 | Miele 24 in. G892SCU Plus Built-in...
G843SCVI Dishwasher
I am a authorized Miele Service tech - we can supply you with any parts you need - just give us a description and your model number / serial number
Thanks
mpservices@cox.net
Oct 26, 2008 | Miele 24 in. Incognito G843SCVi Built-In...
GE Dishwasher Leaks
You can easily screw up the drain diverter arm trying to replace that seal. Repair is difficult. Pump assembly is rather expensive. (especially considering this was not a top of the line model) You would be much better off replacing the dishwasher. The new GE models are much quieter and have eliminated the center tower in almost all models.
Sep 02, 2008 | Dishwashers
Miele 24 in. G638 Plus Free-standing Dishwasher Logo
273 people viewed this question
Top Miele Dishwashers Experts
Mike
shaun taylor
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
