Question about Kenmore 62622 Microwave Oven
How to remove a knmore microwave oven above the stove top
  • Kenmore Master
  • 9,098 Answers
You will probably be able to download the installation instructions from the Sears parts site.
Just enter your model number there.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
On the resulting page, look to the right for the blue "View manuals" button. Click there.
how to remove a knmore microwave oven above the - view_manuals_button.jpgview_manuals_bhow to remove a knmore microwave oven above the - view_manuals_button.jpg /><img src=88fae26.jpg
That Sears-related site has many free manuals. While the manuals they list there are all free, they will ask you to register.
Many times, the owner's manual will also have the installation instructions inside.
If yours is not listed there for free, you would have to order it through the
Sears parts site.
For repair service on Kenmore appliances, see Sears Service.
Posted on May 05, 2010
Installing a microwave / convection oven above a stovetop
Needs to be properly vented to outside the house. Only install a microwave that's designed for over-stove use in this space.
Aug 25, 2014 | Microwave Ovens
How do I remove over-the-stove Amana microwave?
open the cabinet above the microwave there should be 2-3 screws going into the top of the microwave remove those and the microwave should drop down. but put something underneath they can drop fast so be careful
Jul 24, 2012 | Amana Microwave Ovens
How do I attach a microwave model #721.80413 to the wallI
if this is a above stove brand.. you have to open the top cabinet right on front lip of cabinet are three screws going into microwave... support unit and remove the screws that hold unit
May 26, 2012 | Kenmore 63662 / 63664 / 63669 Microwave...
Is there a way to clear grease, etc that has accumulated above the sealed microwave oven? I clean the filters above the stove top, but unable to clear the material above.
Hey, there is a product by simple green called Simple Green BBQ & Microwave Cleaner & Degreaser, shouldn't cost you more than 7 dollars.optimuskem.jpg
May 06, 2011 | Sanyo EM-S9000 Microwave Oven
Can you put and over-the-counter microwave over a stove?
Yes, that is what they are made for, As long as it has a vent that can be used to vent the smoke from cooking it can be mounted over the stove. Normally the bottom of the microwave should be mounted 16" to 19" above the stove top. The microwave must have a vent with a blower motor in order to be used above a stove top. Most have a thermal switch that will turn the microwave vent on once the temperature reaches a set point.
Jun 12, 2010 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
I have bought a whirlpool microwave wmh1163xvs. where does the power cord exit the oven and where should the plug in be located?
Typically the power cord on above the stove microwaves exit from the top of the oven. That way the oven can be mounted to the wall and the power cord can be routed up to an outlet in the cabinet above the microwave.
May 02, 2010 | Whirlpool MH7140XF Microwave Oven
Remove a whirlpool over the range microwave oven
Jim here. In cabinet above microwave, locate 2 mounting bolts.
Place a box on the stove top to support the microwave once the mounting bolts are removed (you may wish to cover the box with a thick towel or small throw rug).
Procedure:
1. Unplug microwave.
2. Remove both mounting bolts from top of microwave (they secure it to the overhead cabinet).
3. With microwave front angled down onto box, pull some of power cord out of hole (to provide some moving space).
4. With microwave hand supported, remove box from stove top (a second set of hands would be helpful here).
5. HARD PART- detach top of microwave back from wall mounting plate by placing a hand under the bottom rear of the microwave and pushing up. (Wall mounting plate is screwed into the wall behind the microwave and provides both top and bottom support to the back of the microwave.)
6. Lower front of microwave until you can see about a 1-inch clearance between the top-rear of the microwave and the cabinet above it.
7. Firmly lift the microwave straight up and then bring forward. It should be free of the wall mounting plate.
Sep 30, 2009 | Maytag MMV4205 Microwave Oven
How do you remove a microwave above the stove
Take the glass tray out and unplug it. Remove the 2 or three phillips screws in the top of the cabinet going into the micro. They should be towards the front. Hold up on it while removing screws. When all screws are out, let it tilt forward and lift it up off of the hooks. Some require help, so be carefull and put blankets on your stove to set it on when it first comes out.
Apr 10, 2009 | Kenmore 63762 Microwave Oven
Does stove-top need downdraft if microwave has oven-hood combo?
We have a stove with no downdraft, and a microwave with a hood above it. It works just fine. I expect you could keep your downdraft and put a microwave without a hood above it, and that would also work. I don't think, however, you can buy an above the range mocrowave oven, that slides in on brackets, which will not have a hood.
Jan 08, 2009 | Microwave Ovens
Kenmore 62622 Microwave Oven Logo
233 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
