Question about Microsoft Windows? Vista Home Basic Edition Full Version for PC (882224181112)
Error message 2032....contact program administrator
  • jabwemet5 May 11, 2010
    Find Your solution Direct from Microsoft Support website
    www.microsoft.com/support/?sr=showthr774
    a
Having trouble with king games on Facebook
https://care.king.com/en/candy-crush-saga/e-error-error-1034-ccs-error-message-something-went-wrong-after-a-saga-api-call-https-candy watch the video
Jul 16, 2016 | Apple iMac 24" Desktop
Candy Crush Saga "got this error message "[IO-Error= [IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2032"]]"
[IO-Error= [IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2032"]][CCS error message: A saga api call went wrong.]
Candy Crush Saga on Facebook Facebook
Aug 08, 2013 | King.com Facebook Apps
Error 554
Your email server is not properly identifying itself when connecting.
You will need to contact your email administrator or service provider and have your Reverse DNS configured properly. When contacting the administrator, be sure to include your error message-it may include information that will be needed to resolve the issue.
Hope that helps!
Jan 28, 2013 | Computers & Internet
Windows Live Sign-in Assistant is not working. When I click on it, I get a message prompt that windows live messenger stopped working and I get this following after.. .....C:\Program Files\Windows...
Try installing the program again using the original installation media or contact your system administrator or software vendor for support.
Jul 09, 2017 | Computers & Internet
I'm having problems connecting. I ran the initial CD setup and everything seemed to run fine but when I try to access the 10.0.0.253 I receive an error message. The camera is set to wired and is...
"I receive an error message" (sic) What is it exactly, what happens? Also Install everything as Administrator, ALSO set the setup/install program's .exe in, Compatibility Mode for XP SP2. and Run the actual program's .exe as Administrator, too. Ensure all network settings are correct too.
Feb 22, 2010 | Panasonic BL-C131 Network Camera
Adobe digital edition is not opening due to an error message: Error activating 'E_ADEPT_IO ActivationService Info Error%20#2032
The issue is related the activation of the digital edition.It seems like you have firewall is causing the problem so you have to turn off the firewall and then try to activate or if it doesn't work you have to contact to adobe inorder to activate the software there number will be 800-642-3623
Regards,
Om
Oct 13, 2009 | Computers & Internet
Hi I have Ricoh Alficio 2032 copier. There is C545 error message
I'm assuming it's SC545. It pertains to temp not being correct in the fuser. Possibly a thermistor, thermal fuse or lamps are bad. It's one of the codes that need to be troubleshot and replace whatever is needed before clearing the code. This is to prevent further damage to the machine. Thanks Colin
Jun 28, 2009 | Ricoh Office Equipment & Supplies
Control panel not responding
I asume you are getting this error "This Operation Has Been Cancelled Due to Restrictions in Effect on This Computer" http://support.microsoft.com/kb/278839 This is cause when your computer administrator is trying to keep you out of certain areas of the computer, in your case the control panel. "If you are an administrator, you can verify the policies that are enabled. To do this, click User Configuration, click Administrative Templates, and then click System. "
Jun 08, 2009 | Compaq Computers & Internet
Unable to update or sychronize with time.windows.com
you need admin\administrator rights to change anything on vista. it is suppose to be more secured than Windows XP.
administrator /user is power user rights, which don't have rights to change system setting, but you do have rights to install certain program.
login into the machine as administrator and provide the corect password.
Apr 28, 2009 | Microsoft Windows XP Home Edition
Can not add or remove a program from my computer.
Log off and Log back on as an administrator. You are most likely logged on as a user with limited privilages.
Feb 27, 2008 | Computers & Internet
Microsoft Windows? Vista Home Basic Edition Full Version for PC (882224181112) Logo
19 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
