Question about Vacuums
The tool doesn't work. No sucking power. However the vacuum works.
  • 43,501 Answers
Check the hose...they plug up and then everything stops...
Here is a tip that I wrote after having the same issues with my Bissell...
http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not
heatman101
Posted on May 03, 2010
Sucking and blowing
Shop-Vac® Brand. The Original Wet/Dry Vac™
https://www.shopvac.com/
Shop-Vac® is proud to be an American-based company. ... When we say the Shop-Vac® is powerful, we're talking debris cleaning, leaf-blowing, heavy-duty, wet or ... Many of our vacs are backed with a 3 to 5 year warranty, but we've seen ... I had just gotten back from work, so my arm was hurting, and I really didn't want to ...
My ShopVac Blows - WOOD Community
community.woodmagazine.com > Forums > Tools and Tool Buying
Nov 23, 2009 - My ShopVac suddenly started blowing dust out the exhaust ports. I don't mean a little dust, it blows almost as much dust as it sucks in!!!! ... ... I'd look it over very carefully looking for tears or splits. Might be a good idea just .... A few months ago I purchased a Dust Deputy and hooked it up to my shop vacuum.
10 Shop-Vac Vacuum Hacks For Around The House - Thrillist
https://www.thrillist.com/.../10-shop-vac-vacuum-hacks-for-around-the-...
Sep 14, 2015 - Simply flip the switch from suck to blow and blow leaves to your heart's... you really need to get your act together if you're using a Shop-Vac for ...
Shop Vacs...and dust control? - Home Forums - GardenWeb
ths.gardenweb.com > Home Forums > Cleaning Tips
Jan 09, 2016 | Shop Vac Vacuums
Can not get my steam vac to suck up water everything else works.done half floor empty water to do other half of floor and it just stopped sucking up water
  • There a twist lever on the side to change from floor to tools. If "everything else works" then you have it on tools. Twist it back to floor and it will work.
Sep 11, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
Trying to use the hardfloor cleaning tool. a) it keeps falling off, and b) It doesn't seem to be sucking up the water/solution. Grateful your help with this thanks Maggie
I had a similar problem with the attachments falling off, the answer is quite simple, rub the end of the tube with candle wax, it really grips well.
May 09, 2011 | Vacuums
The cleaning tool hose is plugged how do i fix it
Can you remove the hose?-- and reverse it-- so that the vacuum SUCKS on the end where the attachments usual go?-- Often this will pull the obstruction back out, the way it came in.
If that doesn't work, can you unbend a coat hanger, and leave a hook on one end?-- and insert it into the hose (attachment end first, preferred..) -- Can you feel the obstuction, and can you get past it, and twist the hook to catch it and withdraw it?
If none of that works-- Most Vacuum cleaner shop will have a good strong vacuum just for sucking out the obstructions, and probably won't charge you for clearing it-- As long as you listen to their sales pitch on a new machine! :-)
Mack B
Jan 10, 2011 | Hoover Vacuums
My bissell power force bagless model 6594-w vaccuum is not sucking up when vaccuuming but if i use the hose it works
Remove the bottom plate that covers the brush assembly and check the air passage that goes out where the vacuum is jointed between the vertical parts and the sweeper head. Look for any clog in that area. A bent hook on the end of a piece of coat hanger wire is a good tool for cleaning clogs. Hope this helps!
Dec 10, 2010 | Bissell 6594 PowerForce Bagless Upright...
Bissell powersteamer model 1693 not sucking up water
I have the bissel power steamer / powerbrush # on front at bottom 310-3150 bought in october used it 2 times 3rd time it started acting up as follows
cleaned all parts. the spin dial wont spin. the switches on both steamer and hand wand won't spray. Sometimes works then stops. Water comes out the bottom when sitting. All parts look fine no damages.
Jan 10, 2009 | Bissell 1693 PowerSteamer Upright Vacuum
Hoover U5435 900. user manual for tools
Try Googling (hoover)(U5435-900)(manual) without parens.
Aug 07, 2017 | Hoover Plus U5435-900 Bagged Upright...
Vacuums Logo
32 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
