Question about Hunter 27187 Remote Control
Hunter ceiling fan
How do you connect the universal hunter ceiling fan to the house wiring we are having problems with the wiring
    Guru:
  • 351 Answers
The usual house wiring for a ceiling fan with two wall switches , is white to white, black to black, and red to the other wire, usually blue or black striped with blue. If this fan has a remote , then it usually only requires one power wire, black and the white neutral.
Posted on May 06, 2010
Install a hunter highland remote in a prewired house that has 2 lights on the same main switch
Prewired for ceiling fan (colors, installing, bedroom, lights ...
www.city-data.com > City-Data Forum > General Forums > House
Jan 29, 2009 - 10 posts - ‎3 authors
In my new house, there's 2 switches so I can do them separately. ... is there anything else I can do with that switch since the fan has a remote and I won't be using it much? TIA. .... Those same wires should be in that switch box.
Wiring on ceiling/fan light combo with remote and ... - Bob Vila
www.bobvila.com/.../82070-wiring-on-ceiling-fan-light-combo-with-re...
Oct 3, 2007 - I can have installed the fan/light (a Hampton Bay Veranda) without the ...My house wiring has a green ground and two black and two white wires. ... Fortunately I found a universal/all brand fan speed control wall switch made by Hunter. ... i havethe same problem . so you just did not used your remote?
Jan 19, 2016 | Hunter Dryers
How can I replace the receiver on hunter tribeca ceiling fan
The black & white on one end go to the house wiring. The other three go to the fan wiring. Black to black, white to white & connect last two wires together.
Aug 17, 2014 | Hunter 52" Ceiling Fan With Light And...
Lights come on at random .has a remote how to fix ?
The fan remote control receiver used in the Hunter 25730 model fan (see picture) is not available from Hunter. Remove the fan from the ceiling. Remove the receiver and take it to recycling. It can be replaced using a readily available and inexpensive replacement universal remote and receiver controller. There are limitations though. The Hunter receiver provided fan reversing functions. The universal controllers do not. You therefore have two options.
Option 1: The universal receiver can be installed such that the fan direction is fixed, either up or down, all other functions operate normally.
Option 2: A reversing switch can be purchased from Radio Shack for about $4 and installed in the fan. This does require cutting a square hole and drilling two bolt or rivet holes in the side of the cylindrical housing which previously housed the Hunter receiver. I'd suggest the Radio Shack DPDT slide switch part number 275-403.
Refer to the wiring diagrams and connector pinout diagram for connections. Please note that the connector pinout diagram is the connector that is soldered to the circuit board as shown in the photo of the Hunter receiver. If your motor wire colors are different then with the connector unplugged from the receiver use a multimeter to probe all the motor wires in order to identify two pairs of wires that indicate approximately 70 ohms each pair. These will be the motor windings. 6b0a1409-5a20-4efe-a059-c600652e9512.jpg 5da8e4ef-1b54-40d0-a8a4-21d4608b1d23.jpg 9fc8772d-3ac3-41b7-aa55-78ccc6e5ea00.jpg 0759e340-6464-4c4b-90f5-6d9926e74e42.jpg
Jan 23, 2014 | Hunter Ceiling Fan Light Remote Control
We have a hunter ceiling fan with light kit. When we turn on the light all light blink. What could be causing this?
a lose wire in the fan/light housing. the motion of the fan is moving it creating a short. I wouldnt us it till it gets repaired. Its a pretty basic unit, kill the power, and drop the light housing and check all connections. If not in housing, check connection in the ceiling, you got a lose wire somewhere.
Mar 12, 2011 | Hunter Ceiling Fan Control Switch
Hello, I have to install a Hunter universal remote receiver, Model 27185 toa Hampton Bay ceiling fan w. light, Model 468-282 today. The receiver has 5 wires, red to light, black to fan, a live black to...
Red from receiver to blue light feed. Black from receiver to black feed to fan. White common from receiver to ground.(bare copper)
Black from receiver (hot) live in, to black from household wiring switch. Common in from receiver to neutral (white ) from house (switch.)
Sep 26, 2010 | Hunter Ceiling Fan Remote Receiver...
Installing a universal remote on a ceiling fan.
your remote modual should have two or three wires coming from the unit on one side to go to the fixture and three on the other to hook it to power , the three should be to connect to the black (power), the white (Neutral) and green (ground), now the unit has power. The two or three coming from the other side should be a white and two other colors or two the same , black, red, or blue, The white connects to the fan white and the other two go to, one the fan and two the light. Any questions E-mail me...hwyhmmr hotmail
Oct 22, 2008 | Hunter 52" Ceiling Fan With Light And...
Ceinlg fan
If your house has only a black and white wire, than you need to tie the black, balack and white striped wire to the black of the hous. You than have to use the pull chains on the fan when the switch is on, to turn the fan or the fan light on or off. If youre house had a red wire than that would be tied in with the black and white striped wire and you would have two swithes on the wall to control the fan and light instead of having to use the pull chains.
Sep 27, 2008 | Hunter 23852 Classic Original Ceiling Fan
Wiring connection ceiling fan
copper to green , white to white , seperate the black and the black with th white tracer you wired together connect the black to the black and the black with white tracer to the red in ceiling , without looking this is my best advise ,good lk
Mar 24, 2008 | Hunter 20531 Vista Brushed Nickel Ceiling...
Hunter 27187 Remote Control Logo
515 people viewed this question
Top Hunter Televison & Video Experts
pblo
Level 1 Expert
Paul Bade
Jim Goldsmith
Jim Goldsmith
Are you a Hunter Televison and Video Expert? Answer questions, earn points and help others
