Question about Epson Stylus CX3200 All-In-One InkJet Printer
Scanner error see documentation and call service if needed
  • Epson Master
  • 12,061 Answers
Fujitsu fi-5650C Error U1
Hello Ismail,
Error U1 referes to Frequent paper jam in Fujitsu fi-5650c scanner. In order to troubleshoot your scanner issue, you are advised to follow the steps provided below:
1. Do the documents satisfy the paper specification?
2. Have the documents been prepared properly?
- Align the edge of documents for stable paper feeding.
- Remove documents with creases or dog-ear corners.
- Scanning different widths documents may cause skew and result in paper jam.
3. Is the imprinter EXT cable connected to the scanner properly? (only when the imprinter is installed)
4. Clean the Pick roller, the Separation roller, the Brake roller and the Chute roller and see if the error is resolved.
5. Clean the Feed rollers and the Plastic rollers and see if the error is resolved.
6. Replace the Pick roller, the Brake roller and the Chute roller, and see if the error is resolved.
- Check the consumable counter in the software operation panel. When the counter exceeds the values, replace the Pick roller or the Brake roller.
If the above steps do not help, then yuo are recommended to contact the nearest Fujitsu service center for assistance.
Thanks & regads,
ScanCare
Dec 16, 2013 | Fujitsu fi-5750C Flatbed Scanner
Error message 39,003.40
Sounds like you need to replace the document scanner. Here's a video to show you how to replace the it, should only take 5 to 10 min. ">
Nov 19, 2010 | Xerox C2424 Copier
My scanner fails to scan documents. It either generates a "warming-up" message OR "sorry, scanner could not be initialized. (Scanner parameter error.)" message.
there are many users facing this same error message.
there are options to solve the issue.the upper part of the printer is scanner.you have to remove that upper portion by removing the screws and internal locks on its inner layer.then check out if any dust is got collected on the scanner lens.the lens is a thin glass layer in the scanner that reads the document which you place on the glass.if the dust gets collected on the lens it will show this error messages.but if after cleaning it shows same message that means the internal board is got faulty.there is a mini circuit board beside the scanner glass.internally.so the upper scanner assembly needs replacement.in the scanner assembly set you get the new circuit board.scanner assembly means not the upper scanner glass it only includes the inner assembly and the circuit board of scanner assembly.the cost of new assembly is near to $40.you can get this assembly at any local printer repair shop.they have it in spare or they can easily get it from nearest service center of the hp company.
thanks.
Nov 20, 2009 | HP PSC 950 All-In-One InkJet Printer
When I press the scan button, it gives error message about documentation
you should look through the documentation that came with your scanner. The error message is probably telling you to read the documentation for troubleshooting why the scanner isn't working. Most documentation that comes with devices like that has a troubleshooint section that describes common problems.
Aug 10, 2009 | Office Equipment & Supplies
Error F60 call service 50FFB200 on Kodak 1500d scanner
Usuall cause of the problem is that the optics are in need of a very good clean. May also need a new lamp if cleaning does not solve the problem
Jun 17, 2009 | Kodak Office Equipment & Supplies
I have a fujitsu 4120 scanner that will not pull the paper even after i changed the roller and pad.
Does the scanner displays any error message on the scanner panel? Is there any TWAIN error message?
If paper jam occurs, U1 error will be displayed on the scanner panel and TWAIN driver will display " Paper jam the ADF (Code DS32002)" error message.
This error is detected when one of the followings occurs:
1) A document does not reach the TOP sensor while the scanner has transported the document about 250 mm to pick. (The scanner
performs retry operation.)
2) The trailing edge of a document does not reach the TOP sensor after the scanner transports the document by the length (L) below. (The document may have slipped on the rollers) Scan condition Transported length.
In order to assist you with your scanner issue, Please provide the issue details with error message.
If nothing is being displayed, then the issue could be due to failure in Pick Motor function or Pick Sensor malfunction.
Hope the above information is helpful.
Thank you for contacting FixYa.
Regards,
TechSatya
Apr 24, 2009 | Fujitsu fi-4120C Path-Through Scanner
Epson CX5400. I have 2 and both are giving 'error'red light and message 'scanner error' see documentation and caqll service if necessary'. I have rung an Epson Service centre and they say it is not...
Please follow the steps below to resolve your issue.
1. Turn off the printer.
2. Lift the scanner cover.
3. Toggle the transportation lock five times, ensuring that it is in the unlocked position, towards the back of the scanner.
4. Turn on the printer, and the error should be cleared.
Update me if you are still getting the error message.
Apr 28, 2008 | Office Equipment & Supplies
Persistant error: "Document remains in scanner. Open door and remove document."
I get calls about this all the time. The most common reason for this is the shiny reflector for the Ending Sensor is dirty. It is best to clean this with a cotton swab and a few drops of rubbing alcohol.
Although it is possible that one of the sensors has gone bad. The Panasonic User utility is very basic, but if you have access to the Service Utility it will help pin-point which sensor is causing the problem.
Out of all the calls I've taken relating to this same issue, only two or three situations have been resolved by replacing the sensor - all the rest have just been dirty.
Jan 26, 2007 | Panasonic KV S2025C Path-Through Scanner
Epson Stylus CX3200 All-In-One InkJet Printer Logo
175 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
