Question about Whirlpool Duet GHW9150P Front Load Washer
F11 flashing? We get an F11 light flashing.
  • 11,896 Answers
F11 is:
Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Check for:
Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
Check the Drive system for any worn or failed components
Check MCU
Check CCU
Check Motor
Check Wire Harness
If all the connections look fine , then its possible the CCU is reading wrong and will need to be changed.
Posted on May 03, 2010
Just new out of the box. Will wash ok but won,t release water, then error code F11 appears with all lights flashing.
F11 - No hot fill.The ambient temperature is likely to be below freezing possibly due to the pipes being frozen. Also check that the taps are on or if the drain hoses are kinked.
Dec 31, 2010 | Indesit Washing Machines
My Hotpoint Aquarius WF430 1300 doesn't complete its cycle, it stops after the wash & doesn't go on to the rinse & final spin. It seems to "freeze" after the wash is finished as the lights remain...
If your lights are flashing, use these codes to pinpoint the error.
These codes are reading from the top neon down.
F01....OFF, OFF, OFF, Flash, OFF.
F02....OFF, OFF, Flash, OFF, OFF.
F03....OFF, OFF, Flash, Flash, OFF.
F04....OFF, Flash, OFF, OFF, OFF.
F05....OFF, Flash, OFF, Flash, OFF.
F06....OFF, Flash, Flash, OFF, OFF.
F07....OFF, Flash, Flash, Flash, OFF.
F08....Flash, OFF, OFF, OFF, OFF.
F09....Flash, OFF, OFF, Flash, OFF.
F10....Flash, OFF, Flash, OFF, OFF.
F11....Flash, OFF, Flash, Flash, OFF.
F12....Flash, Flash, OFF, OFF, OFF.
F13....Flash, Flash, OFF, Flash, OFF.
F14....Flash, Flash, Flash, OFF, OFF.
F15....Flash, Flash, Flash, Flash, OFF.
f16....OFF, OFF, OFF, OFF, Flash.
F17....OFF, OFF, OFF, Flash, Flash.
F18....OFF, OFF, ON, OFF, OFF. Fault on control board, check Eeprom.
these are the codes and this is what they mean
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
also try checking this manual
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/WFseries_19504110305_Jan05_book.pdf
Mar 05, 2010 | Washing Machines
F11 error lights flash then stops at last spin . I did clean the filter and took some coins out Whirlpool AWM8163 washer
The F11 fault is the motor. I have had this issue myself and found that replacing the contact brushes solved this. The brushes on most electric motors are made from carbon, and wear down with use. They are spring loaded but have a limited life span. These are also cheap to purchase.
Jan 23, 2010 | Whirlpool AWM8163 Front Load Washer
Code F11 & FDL
WHAT BRAND M#/S# ?NEED INFO
Aug 19, 2009 | Washing Machines
The washer beeps and flases f dl
it probably flashes also f11....to correct that problem , you must replace CCU board (upper board) and latch assembly...
F11: CCU board
FDL: latch problem
Jul 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Flashing F11
rmove top and ck connectors to rear mounted main control module f11 is code for communication problem between upper main control and lower motor control..most likely upper control problem tech sheet behind lower panel
Nov 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Hotpoint ultima wt741
f11 keeps flashing door won't open
Sep 01, 2008 | Hotpoint Ultima WF860 Front Load Washer
Beginner with Studio Lights
will need more information, but the basic idea is to connect the trigger on top of your camera's hotshoe, and then connect the receiver to the flash.
Feb 11, 2008 | Cameras
Whirlpool Duet GHW9150P Front Load Washer Logo
115 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
