Question about Refrigerators
We have a 2 year old home. One of the GFIs in the garage is not working after a thunder storm. When I push the reset button the green light comes on for only a fraction of a second. Husband is out of town. Help! This is where I plug in my second refrigerator!
  • marilynsechl May 03, 2010
    I was afraid of that. It's strange how it didn't affect the other GFIs in that same garage or on the other side of the wall. But lightening is most likely the problem since it wasn't a problem until then. Thank you very much for your quick reply!
  • Refrigerators Master
  • 12,061 Answers
Ok, the GFI, has failed due to a surge, spike or other anomaly, caused by the storm, most likely from a lightning strike, or similar. Unfortunately, there is NO repairing, this unit. You WILL have to call an Electrician, to replace this GFI. As a workarround, you could try an "Extension" cord, back, to another GFI. Or for a temporary, solution, if possible, you could use, a simple extension cord, plugged into a normal outlet, until you get it fixed properly. But as said, you need an Electrician, to attend to this matter.
Posted on May 03, 2010
HELP! I think my TV got zapped and is ruined from storm!
Check whether the power outlet has power. If it has, I suggest please do not attempt to switch on the TV, unless checked by a qualified service technician.
Aug 16, 2012 | Toshib 46L5200U 46" 1080p LED-LCD TV -...
Our garage door is not opening with the wall unit or remotes. When I push the wall unit I hear a click from the ceiling unit. The door operates fine manually. The green light on the ceiling unit (the SRT...
The green light on the motor unit is an LED and random flickering is normal. Your problem is most likely caused by an electrical storm or power surge. You will need to remove the logic board from the motor unit and check for burnt or missing traces on the printed circuit board especially around the small transformer. Your holding that button in will most likely have erased the memory of the unit and all your remotes will need to be programmed once you find your problem. I really suggest you call an technician at this point.
Oct 13, 2010 | Sears Craftsman LiftMaster Chamberlain...
After a lightning storm, my LIftmaster Formula 1 garage door opener will not close without continually holding down the garage door button on the wall. If you push the button once and then let go it will...
If when the door reverses the main light flashes 10 times you have a problem with the door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flickering. They must be pointed at one another for both lights to be on. If you cannot get the lights to come on you have a bad logic board.
Jun 13, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman GDO 1/2 HP - Remotes not working after storm
sounds like it blew the reciever crystal buy another and return the motor thats fried 4 refund
Jul 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garrage door opener not operating after thunder storm
If you had an lightning storm you most likely have a bad logic board. That is not a reset button you are pressing.
Jun 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Changed the gears in my garage door opener: now its dead
RE READ THE INSTRUCTIONS VERY CAREFULLY AND MAKE SURE EVERY STEP WAS DONE IN ORDER.
YOU MAY HAVE A BAD CIRCUIT BOARD - WAS EVERYTHING NORMAL BEFORE THE GEAR STRIPPED?
Apr 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
OLDER SEARS GARAGE DOOR OPENER WONT OPEN GREEN LIGHT FLASHING
do you have the sensors at the bottom of the door? if so they might be out of alignment. all you have to do line them up by getting the green light solid. let me know if this helps you.
Dec 18, 2008 | Sears Craftsman LiftMaster Chamberlain...
Refrigerators Logo
16 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
