Question about Pyle PLMRA420 Car Audio Amplifier
Always in Protect Mode
I have a Pyle PLMRA420 1000w marine amp. It's practically brand new.I have never abused it or overloaded it. Even with all the RCA cables removed and speaker wires removed it's permanently in "protect" mode... I've changed the fuse and also tested the power source for 12v... it all checks out...
Any ideas on what I can fix on this thing to make it work again?
KaeZoo
  • 156 Answers
SOURCE: Protect light will never go off
Unfortunately, it sounds very likely that you have a defective amplifier. Usually you see a protect light on an amplifier because of an internal short, supply voltage too high, voltage too low, or speaker connections of too low impedance or grounded. If your speaker wires are completely disconnected, that eliminates the most common external cause of a protect light. Also, a protect light from the voltage being too high is very unlikely without the engine running (and an alternator problem). The "other positive cable" you're referring to is the remote input, and it won't cause a protect light no matter how it's connected. You'd need a voltmeter to do much more troubleshooting; a protect light can be caused by a very poor ground connection, or it's possible that a poor connection at the battery or fuseholder, or a defective fuse, is causing a severe voltage drop. However, based on what you've described, it seems most likely to me that your amp is defective.
Posted on Jun 07, 2007
  • 631 Answers
SOURCE: car audio amp in protection mode
If you power up the amp with the RCAs plugged in, does it go into protection mode.
If you power up the amp with the RCAs plugged in, does the woofer pop?
Posted on Oct 26, 2008
  • 5 Answers
SOURCE: amp goes into protect mode after volume is turned up
Not enough juice, check the power and ground connections, another possibility is to have dc in the input, try to use in line filter available from radio shack to cut the dc, also test the with one speaker at the time, you could have a bad speaker (shorted) too.
Posted on Apr 10, 2009
etirbynnor
  • 655 Answers
SOURCE: Trouble connecting marine amp to stereo
Hello lizskates814,
You can use either the high level (speaker) or the low-level (RCA's) inputs to the amp, but not both. Choose whichever one sounds the best or is more convenient to install and leave the other disconnected.
Hope this helps.
Posted on May 24, 2009
  • 77 Answers
SOURCE: Pyle PLMRA 400watt marine amp.
I'm assuming you mean channels 2 and 4? If you tried new cables and you know they work then you might wanna check to see if there is a 2,3,or 4 channel switch on the amp or just a switch that reads bridged. If a switch on an amp is set to bridged or 2 channels, whatever type of switch there is, then it would make the amp only run 2 channels. If there is'nt a switch and you have a signal on the cable your using then you may have some shorted transistors. Make sure you definately have a signal first before thinking some transistors are shorted. Take the rca's from the 2 channels that work and put them into the inputs cause you know those channels are working. Let me know what you find, I would like to help you more if you still have problems after this. I also do amplifire repair cheap. I have my own business and most of my customers are from this site, so if you need it repaired then I can help you out on this as well. Just send me a private message. Good luck
Posted on Aug 20, 2009
Pyle 2210 how to test the amp when it keeps goin
when the amp goes into protect mode, it is more often than not a problem with the speakers or the speaker wiring.
Sep 01, 2014 | Car Audio & Video
What cables will I need to properly install a pyle PADh212 1600w speaker cabinet with my pyle PD3000A 3000w receiver/ pre amp?
rca cables connectors and use an 1/2 inch jack like a guitar lead. that will do it. i have my sub woofer set up the same way via a bass rig head to receiver
Apr 08, 2014 | Audio Players & Recorders
Amp on but no sound
Double check all of your fuses and make sure they are the corrects AMP. Other than that it sounds like the speaker wires came loose somewhere along the line. check on the subs and behind the deck. hope this helps
Apr 22, 2013 | Pyle PLA2678 POWER SERIES BRIDGED MOSFET...
The OVERLOAD on my Marantz PM 44-SE is tripping out even at very low volume setting - using any of the inputs with either speakers connected or disconnected. I can even hear it tripping when no inputs or...
Overload is another form of protect mode. See the link below for an explanation of protect. Also, in your specific case, the problem is definately internal to the amp rather than an external cause. Expect a parts cost in the $40 range. Feel free to post additional questions.
Thanks,
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
May 01, 2011 | Marantz Audio Players & Recorders
Hooked the damn thing up power my subs wonderfully for that evening, and all day today, got in this evening and nothing, checked the amp and red light, ok, fine, checked the manual, says the light protects...
probably something corssed in your speaker wiring. be sure that you did not exceed the ohmage capabilities of the amp, and that no speaker wires are crossed, or shorting out on the frame. if you have too many speakers hooked up, that can reduce the ohmage, and your not supposed to go below 2 ohms -per channel, or 4 ohms bridged mono.
Mar 13, 2011 | Pyle PLA2200 Car Audio Amplifier
My Pyle PLMRXT33WT marine radio keeps turning itself off.
This could be due to a short in one of the speaker connections or a bad/blown speaker which is shorting out.
Jul 31, 2010 | Pyle AMFM CD DET MARINE RADIO R/C
Radio keeps going on & off all wires are connected
hi and thank you for using fixya:
please check all cable connections for looseness. even they are connect it they might be loose. if this is not the case. then inside you might have a bad connection on a circuit board
Jul 09, 2010 | Pyle AMFM CD DET MARINE RADIO R/C
Pyle Academy 2300 watt amp not working =(
wrap a striped speaker wire around the back of the rca out put on your cd player and for the record that aint a 2300 watt amp its like a 300 watt amp
Mar 30, 2010 | Pyle PLAM2300 Car Amp
Amp problem
why, why, why, that is the question here.
Sep 30, 2009 | Pyle PLA1200 Car Audio Amplifier
Pyle PLMRA420 Car Audio Amplifier Logo
67 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
