Question about Dishwashers
Our Maytag dishwasher has all of the sudden stopped rinsing the dishes. The machine sounds like it is running but no water is flowing. The wash cycle runs but not the rinse. Any clues as to why
  • 901 Answers
Check inlet water supply for free flow. check strainer for blockage. Strainer is located at the machine body water inlet tube entry side.
Posted on May 03, 2010
The dishwasher runs through it's cycle but does not clean the dishes properly and leaves a cloudy film and smears on the inside of the machine and the dishes
    Common Problem
  1. Confirm the wash water is hot
    1. Try heated wash(sani wash) if available
    2. Run hot water in sink to warm up before starting
    3. At least 120 degree Fahrenheit water temperature
  2. Open door check wash arm position start washer for a minute
    1. Confirm wash arm has rotated
    2. Check for plugged spray tips at either end of wash arm.
    3. Use small tweezers to remove
    4. Check for rack and dishes interfering with arm rotation
  3. Place cup in upper rack with opening up cycle washer.
    1. Confirm that cup quickly fills with water
    2. Not washing check water level in tub mim 1 1/2 inch
  4. Discontinue use of rinse/dry liquid additive.
    1. Confirm rinse/dry additive not leaking from dispenser into tub
    2. Washer detergent contains sparkle additive and too much sparkle/rinses/dry additive will coat dishes
    3. Try alternative wash detergent that contains minimal rinse/dry additive and use without liquid rinse/dry additive.
  5. It will take several wash cycles after the elimination of rinse/dry to purge the oily film from dishes and machine..
  6. If success "joy" is achieved with no additives then cautiously add back wash detergent with additives. Additives are important to facilitate drying and protecting the glassware china from leaching. The leaching process permanently etches the surface of glassware leaving a cloudy appearance.
Jan 03, 2016 | Dishwashers
How do I turn up the heat to remove most condensation after washing?
As part of the current ecological, energy-saving, environmentalist-wacko movement, dishwasher makers have cut back on the heating used to dry dishes. In fact in many dishwasher designs, they have eliminated the drying vent altogether, and instead use a condensate or condensation-drying system. In this system, the last rinse cycle is heated to a high temperature, to heat the dishes. The water is then pumped out, and the dishwasher shuts down. The theory is that water will evaporate off the hot dishes, condense on the sides of the dishwasher, and run back down into the sump area. Bosch was one of the first diswashers to do this, and it works fairly well for them. Other manufacturers have tried this, with varying results. Here's what you can do to improve drying:
1. It is imperative that you use rinse-aid (Jet-Dry). This allows more water to flow off the dishes and what flows off does not need to evaporate.
2. If the dishwasher has the options, turn on high-temperature wash and sani-rinse. This gets the dishes hotter for better evaporation.
It is possible that the heater may not be working at all, and that will cause poor washing performance and no drying. This is very rare in dishwashers less than 3 years old. Most likely, poor drying in a new dishwasher is caused because you are not using rinse-aid.
Sep 21, 2014 | Whirlpool Dishwashers
Why dishwasher started making growling sound all of a sudden?
Possibly something stuck/jammed in the wash or drainpropeller, remove filter mesh at the bottom of the dishwasher. Remove any debris jammed near the propeller caution there may be glassor debris near or where the water drains-out.Removeand clean the spray arms, they may have food debris jammed, rinse in hotrunning waterMaintainerWash Runa wash with a tablespoon of powder, without any dishes on the hottest settinge.g. intensive, 65C, if you have a 70C this will be more effective.Loaddishes and re-check
Apr 09, 2012 | Maytag Dishwashers
Dishes not coming out clean
Hello
There are some things you can try, however, if your Maytag dishwasher is not getting your dishes as clean as you would like. Maytag recommends several processes for fixing this issue with your dishwasher.
Do not run your Maytag dishwasher while hot water is being used in other parts of your home, such as washing clothes or showering. Hot water is needed for your Maytag dishwasher to properly clean dishes.
Run water in the sink in your kitchen until it gets very hot. Then, turn on your Maytag dishwasher. This will ensure that the water cleaning your dishes is the hottest possible temperature.
Clean your Maytag dishwasher to improve the cleaning results for dishes. Run your dishwasher on a short wash cycle and wait for it to fill up with water. Stop the cycle and add about 1/3 of a cup of rust remover to the dishwasher and finish the cycle. Run your Maytag dishwasher through one normal cycle with regular detergent to finish the cleaning process.
Check your detergent. Old detergent or those that have been exposed to moisture can be clumpy. This detergent will not clean your dishes as well when loaded into your Maytag dishwasher. Purchase fresh detergent.
Use extra detergent when washing dishes that have a lot of built-up grease or food particles. The extra amount of detergent is needed to get your dishes clean. Choose a long cleaning cycle to clean these dishes.
Fill your Maytag dishwasher properly. Dishes should not be stacked on top of each other or excessively crammed into your dishwasher. This will keep the dishwasher from adequately cleaning all areas of your dishes and from rinsing them thoroughly.
Sep 13, 2011 | Maytag Dishwashers
My dishwasher is 12 years old. We have hard water but we use a water softener. I have to rinse the dishes completely clean before I wash them. Is my dishwasher just getting old?
A couple things can be happening here.
1) Make sure the holes in you rotating arms are not clogged up with food particles. If they are clean them out so water will flow freely. Then run an empty dishwasher with a cup of white vinegar, this should clean it real good.
2) The water may not be getting hot enough. The water is heated with the element at the bottom of the dishwasher. A simple way to check this is by stopping the dishwasher at mid wash cycle and touch the water at the bottom of the tub. If it's not very hot, than the element is bad and needs replacing. Just weigh the cost of replacing the element to the cost of a new more efficient dishwasher.
Hope this helps.
Nov 10, 2009 | Maytag 24 in. MDB5600A Jetclean II...
My maytag dishwasher doesn't seem to be rinsing
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Oct 25, 2009 | Maytag 24 in. MDB8600AW Jetclean II...
Dishes have filmy finish
hello. this will help a great deal.
First of all empty out your dishwasher, toss in two cups of plain white or cider vinegar and run it on the highest and longest cycle.
Always run the hot water in the sink first and start the dishwasher only when the water is as hot as it will get.
This wash will clean out your dishwasher thoroughly.
Then always do your dishes after you have rinsed any residue off of them before placing them in the dishwasher and I always recommend the pot scrubber cycle if you have one.
Jul 07, 2009 | Dishwashers
Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
Mar 14, 2009 | Dishwashers
White film on dishes
Experience : 30 years in dish washing as a professional instructing hospitals and restaurants.
It is not necesaasry to cover the heating element as long as sufficient water is present so as to not STARVE the water pump.
Listen to the sound of water serging with the machien running. If it is contant you have enough water if the sound comes and goes then the pump is serging . either lyou have a low water level or CLOGGED strainer in the bottom of the machine (inside).
you might also open the door real fast during the wash and check for water splashing and flows---- you might get wet but this way works .(wear protective eye shields)
water levels can be raised by BENDING the tab on the bottom of the float which controls water level...much like a toilet tank float.
Also finally if soap levels are too high the soap will not rinse off regardless of the amount of "rinse fluid you use.
Visit www.soapman.com
regards
soapman Bruce
Dec 30, 2007 | Dishwashers
Quick Wash cycle restarting
Aestaie, On the quick wash cycle the machine goes through a heated rinse at 160 degrees. I think what's happening here is that the board checks the thermistor and is finding that the water is not hot enough and say's, hey, I need more time to heat this water and resets itself. The element in the dishwasher will only heat the water 1 degree every 3 to 5 minutes. So after the initial wash, there is a 2 minute drain, it fills again and there is the heated rinse. If the water is 120 and the final rinse needs to be 160, we have some heating to do here. Therefore the reset. Sounds like the dishwasher is working OK, Catriver..post back
Apr 24, 2007 | Maytag MDB9600A Jetclean II Built-in...
Dishwashers Logo
49 people viewed this question
Top Dishwashers Experts
