Question about Hamilton Beach 48274 BrewStation 6-Cup Coffee Maker
How do you get the programmable option of my 6cup brewstation to turn on when it has been programmed for a time in the future, like in the morning? If I turn it on, it brews immediately. It it doesn't work I'll return it. Had it two days.
  • 1 more comment
  • lizknight01 May 03, 2010
    I signed into youtube. It said this video was not available. No good to me.
    I finally got the video this next morning, however I already knew about the normal
    coffeepots, however this 6cup Hamilton Beach has "NO AUTO" button. It has on/of button,
    program button and h for hours and m for minutes. NO AUTO! I programmed it as the instructions noted however it only turns on when you hit on. I'll probably take this back. I want a programmable
    coffeepot.
    I think I found the answer on my own with your assistance. Since there is no "Auto" Button I tried
    pressing the "Programmable" button. This turned green and stayed on. So this button is probably
    the button to press to program the time as well as the same thing as the auto button after the time has been set. You'd think they would put this in their instructions which is very poor. I think the
    on button must be pushed and then the program button. I will find out tonight when I try to set it
    for tomorrow morning. I'm just very unhappy with the instructions in the product. They are just
    non-existent.
  • 674 Answers
1 Press H and then M to set clock
2 Hold PROG until clock flashes
3 Continue holding PROG button,
press H and M until the desired
brewing start time is reached.
4 Press PROG momentarily to
activate automatic brewing
Posted on May 03, 2010
  • Brian Niten May 03, 2010
    Don't forget to rate my solution if it helped. Thanks.
  • Brian Niten May 05, 2010
    Just wondering if your coffee maker worked. Please don't forget to rate my solution.
    President:
  • 1,851 Answers
I made a video just for you and put it on the web on you tube.
http://www.youtube.com/watch?v=7dkk8jSClik
  • Gary Rice
    Gary Rice May 03, 2010
    Sorry about the link not being live yet. You don't even have to sign in. The video's take a few minutes to become LIVE - it is now ready.
    Please click here.
Coffee make display too bright
I have had a few Brewstations and you are right the blue display light is way to bright but no you can NOT tone it down. I placed a postit over mine and it worked great
Feb 18, 2013 | Hamilton Beach Brewstation 48464 Summit...
ERROR MESSAGE RECEIVED FOR HARD DRIVE SAVED PROGRAM
your program getting virus infected so you install a one antivirus full verion update it and scan and try
May 30, 2012 | Panasonic Televison & Video
Hi, I am having problems with the timer that controls my boiler. It is a 'Lifestyle LP522'. The hot water is set to come on in the morning for 4 hours and again at 4pm for 3 hours. The heating is...
then there must be a problem with the programmer as the boiler thermostat will call for heat only if the programme is on try setting the water side to 24 hrs it won't cost any more to run , but will prove if programmer is working .
Mar 07, 2017 | Heating & Cooling
I need an instruction booklet to set the timer for the coffee.
Go to Hamilton Beach dot com, pull down customer suppot menu, click on use and care guides, type in product and model number, click send and your manual will load. Print it out so you have it. Setting the timer is a piece of cake, Hold down the program button until the clock flashes. While still holding the program button down, set the timer for whatever time you want the pot to perk. Let go of the program button. To check if the timer is set right right, puch the prigram button just long enough to see what time it is set for. If it's right, prepare the pot the night before, push the program button to set and forget about it. It will perk at the time you set every morning. Katherine
Jul 11, 2009 | Hamilton Beach BrewStation 47214 Coffee...
Heater on when not programmed
sounds like a bad t-stat , they have a 5 year warranty on them
Dec 28, 2008 | Honeywell Programmable Thermostat Heater
Heater comes on at 5:10 am prior to the programmed setting
Access the installer setup menu (You will need the installation manual from the t'stat to do this) and turn off the "intelligent recovery" feature. This feature turns the equipment on in order to bring the conditioned area up to temp at the set time. Or you could set the "wake time" to 6:50!!!
Dec 15, 2008 | Honeywell Programmable Thermostat Heater
Hamilton Beach BrewStation 47224 Coffee maker
My coffeemaker makes the coffee just fine every morning, and we leave it on for 2-3 hours and then it turns off automatically , but later it leaks back to the water reservoir and then out the bottom all over my cabinet. What is wrong?
Oct 14, 2008 | Hamilton Beach BrewStation 47224 Coffee...
Problem with Honeywell CM67z thermostat
yes you probably program it incorectly
Mar 31, 2008 | Computers & Internet
Programming how to
there are quite a few models, but mine is the 'deluxe', and ther eis a 'program' button on the right side of the panel... .hold that down until it 'blinks' a number thru the LED screen. ...there are H and M buttons below the LED screen (one left, one right).... you can use those to program the hours and minutes.
if you are not sure what you programmed the time to be, u can always just hold down the 'program' button, and it'll flash with the set time.
when u go to sleep at night, just push the program button down, and it will light up, so u know it is 'set'.
Sep 24, 2007 | Hamilton Beach BrewStation 47214 Coffee...
WinXP can't start.
it maybe that the bios chip is faulty or stuck in a loop as what it seems to be doing is trying to run the bios flash programme. Next time the pc boots up press F2 or Del and in the cmos settings see if the time and date is correct, if not correct it and look in all the menus for something similair to bios flash utility updates and dissable it if enabled or select off, save settings and exit for a reboot. Hopefully it will stop, that's if you can get into the bios without this programme flashing up. If you cannot stop it you will need to reset the bios and the only way may be to remove the bottom compartments of the laptop and look on the motherboard for the cmos flat round shaped battery and remove it for 10 minutes or so and then replace and try again, or only other option is to speak to sony technical as a bios problem is a serious one and cannot sometimes be resolved other than a motherboard replacement i'm afraid.
Apr 26, 2007 | Sony VAIO NV170P Notebook
Hamilton Beach 48274 BrewStation 6-Cup Coffee Maker Logo
54 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
jason
80stech
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
