Question about Dryers
LG Dryer not producing heat
We have a High Efficiency LG dryer, that no longer is producing heat. We have checked the filter and it is clean. We have checked the vent hose and it is clear. We have reset the dryer to try and get it corrected, but it runs fine, but does not appear to be producing any heat.
  • Dryers Master
  • 43,501 Answers
If you have a gas dryerLG Dryer not producing heat - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 03, 2010
LG Dryer low heat doesn't work
It may be as simple as checking your lint filter.
If you use fabric softeners sheets, they tend to clog the lint filter holes. Washing it with soap and water will restore it back to normal and will allow the circulation that the dryer needs to properly dry your clothes.
May 04, 2014 | LG DLEX7177 Dryer
Take forever to dry
If your dryer still heats, but your clothes take longer than usual to dry, you may want to check the dryer interior cabinet and/or the entire run of the exhaust ducting from where it exits your dryer to the point where it leaves your home to ensure you have no kinks, clogs, or excessive bends. The following link explains many of the common problems that can cause poor drying efficiency and longer dry times:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. This is the NUMBER ONE cause of poor drying efficiency. A dryer that is clogged, or has restricted air flow, will not dry efficiently and will cause the heating circuits to OVERHEAT. This will eventually will lead to component failures and is the source of many fire hazards.
Exhaust ducting that runs to the attic is usually the worst configuration, because the air has to be forced up. The blower fan will meet more resistance and any lint that does not exhaust completely, ends up stuck in the vent. Water appearing in the drum is another sign that you have a clog somewhere causing condensation to develop.
FYI: There are no adjustments that can be made to any of the internal thermostats or heating element to make the appliance run at a higher temperature. All these components have a fixed setting. If the dryer still produces heat, this is generally a sign that the heating element IS working. If the dryer is clogged, however, the internal protection devices, such as the Hi-Limit Thermostat and Internal Bias Thermostat will shut the heating element off prematurely to prevent the dryer from overheating, and to prevent damage to the heating element. Eventually, the Thermal Cut-Out (TCO) or Thermal Fuse will trip and the dryer will not run.or produce heat. If you have any questions, please post back and let me know. I hope you find this information helpful.
Aug 11, 2011 | Speed Queen ADE3LR Dryer
LG DLG2524W gas dryer with check filter light on. Dryer will work but no heat. Totally vacuumed filter and filter area out. Opened cap on bottom side of dryer and vacuumed that out but still same thing....
It sounds like the high limit switch has tripped. You will need to disassemble the dryer to get to the switch to reset it. LG recommends replacing the high limit switch.
Aug 05, 2011 | LG Dryers
Dryer heats up, takes a long time to dry. vent can only go to attic, sometimes watter comes through door, cheaked lint is clear. model no. LDE8824ACE, HOW OLD IS THIS MECHINE?
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. This is the NUMBER ONE cause of poor drying efficiency. A dryer that is clogged, or has restricted air flow, will not dry efficiently and will cause the heating circuits to OVERHEAT. This will eventually will lead to component failures and is the source of many fire hazards. I know you have checked for lint, but have youi checked the ENTIRE exhaust run and the cabinet interior? Exhaust ducting that runs to the attic is usually the worst configuration, because the air has to be forced up. The blower fan will meet more resistance and any lint that does not exhaust completely, ends up stuck in the vent. Water appearing in the drum is a sure sign that you have a clog somewhere causing condensation to develop.
As far as the age of the appliance, the date of manufacture is determined by the SERIAL NUMBER, not the model number. The following link explains: http://www.fixya.com/support/r3576437-determining_the_age_of_your_whirlpool_ap The second digit in the serial number determines the YEAR it was produced. The next two numbers following that digit, represent the week in the year (52 weeks in a year) it was produced. FYI: There are no adjustments that can be made to any of the internal thermostats or heating element to make it run at a higher temperature. All these components have a fixed setting. If the dryer still produces heat, this is generally a sign that the heating element IS working. If the dryer is clogged, however, the internal protection devices, such as the Hi-Limit Thermostat and Internal Bias Thermostat will shut the heating element off prematurely to prevent the dryer from overheating, and to prevent damage to the heating element. Eventually, the Thermal Cut-Out (TCO) or Thermal Fuse will trip and the dryer will not run.or produce heat. If you have any questions, please post back and let me know. I hope you find this information helpful.
Apr 04, 2011 | Dryers
Our new dryer seems to run longer than it is supposed to
Clean out your dryer ducting, unhook the dryer from the vent and clean the vent from the back of thedryer to the out side of the home. If you can take the cover off of the outside and you can use a leaf blower to blow out all of the lint, if you cant do that you will need to take the ducting apart and clean it out by hand
Dec 23, 2010 | Kenmore Dryers
Dryer is taking much longer to dry clothes than it once did. Took 3 hours to dry clothes last night and had an unusal odor. Dryer is 3 years old, the dryer vent is not clogged up.
If your dryer is STILL heating, but your clothes still won't dry, you may want to check the dryer interior cabinet and/or the entire run of the exhaust ducting from where it exits your dryer to the point where it leaves your home to ensure you have no kinks, clogs, or excessive bends. The following link explains many of the common problems that can cause poor drying efficiency and longer dry times:
FYI: There are no adjustments that can be made to any of the internal thermostats or heating element to make it run at a higher temperature. All these components have a fixed setting. If the dryer still produces heat, the heating element is working. If the dryer is clogged, however, the internal protection devices, such as the Hi-Limit Thermostat and Internal Bias Thermostat will shut the heating element off prematurely to prevent the dryer from overheating, and to prevent damage to the heating element. Eventually, the Thermal Cut-Out (TCO) or Thermal Fuse will trip and the dryer will not run.or produce heat.
Nov 03, 2010 | Frigidaire GLEQ2152ES Electric Dryer
I have a newer but not brand new kenmore dryer. I have to run it twice to get a load dried. Serial number of dryer is ML4641775. Where is the heating element and how do I replace it?
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. This is the NUMBER ONE cause of poor drying efficiency. A dryer in a clogged state, or having improper air flow, will not dry efficiently and will cause the heating circuits to OVERHEAT. This will eventually will lead to component failures and is the source of many fire hazards.
Oct 08, 2010 | Dryers
Our Kenmore HE2 dryer seems to be taking a very long time to dry clothes (120 minutes on Medium High to dry towels/jeans) . It is producing heat, but it also seems to be producing water/steam. The filter...
you need to clean out the vent line and the dryer.unplug the dryer,pull out the filter,remove the bottom panel and then remove the duct that the lint filter slides into and clean it out,vac out the inside of the dryer,if you have a shop vac you can blow all the lint from the back and then vac it up,make sure you blow off the motor,alot of lint gets built up around and inside it,pull out the dryer and pull off the vent line,if it's a long run i use a leaf blower to blow out the vent line,first go outside and make sure the vent is clear so when you blow out the vent line nothing is blocking the lint from coming out.this will take care of your problem,do this once a year and your dryer will last longer,you'll need less parts changed out over the years because the dryer won't over heat,you'll save on electricity,your clothes willl dry on time and most of all you won't have any fires
Sep 26, 2010 | Kenmore Dryers
Lg dlg2522w check filter flashing, motor spins,no
Did you put a load of wet clothes in the dryer and run it?
You can't change the setting while it's running.
The sensors won't let it heat up if there is nothing in the dryer.
This is not your grandmas dryer, this is a high tech machine.
There is probably nothing wrong with it.
Oh and the filter light flashes like that, it is supposed to, it is telling you to check the filter for lint.
Nov 24, 2009 | Zanussi FJD1666W Front Load Washer
LG Gas Stacking Dryer
The check filter light comes on every load to remind you to clean the lint filter. Cooling only happens when that light is flashing not when it's on solid. If this is a gas dryer check the exhaust hose and vent on the outside of the house. If it is blocked it will not let the unit get to the correct temp due to cycling.
Dec 16, 2007 | LG DLE2514 Electric Dryer
Dryers Logo
107 people viewed this question
Top Dryers Experts
