Question about Hotpoint Ultima WF860 Front Load Washer
User manual required(hotpoint ultima wma60)
Purchased a second hand machine but has no manual has anyone any idea how to get one, would really apppreciate it.
    President:
  • 1,294 Answers
Click on your model number (below FIXYA) on this website, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, u hv your manual on line. If available that is....................
If your number is not above click on Hotpoint.
Rate me pl if helped...................
Posted on Mar 26, 2008
Hotpoint ultima washing machine wma60. Bought new belt but can't get it on
(extract from my general guidance notes for replacing belts.)
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 13, 2011 | Hotpoint Washing Machines
Can i get an instruction manual for my WF860 hotpoint ultima
You should be able to get one by going to the following site.
WWW.HOTPOINTSERVICE.CO.UK
In the menu click on >>>>
HOTPOINT USER MANUALS
Then in the search box enter your model number, and you should be able to download the instructions.
Please rate my solution.
Thankyou.
Jan 27, 2010 | Hotpoint Ultima WF860 Front Load Washer
I need to download a user manual for a hotpoint ultima wt960 please
Go to---
In the menu click on--
Ithe search box, enter your model number, and download the instructions.
Thankyou.
Jan 18, 2010 | Hotpoint Ultima WF860 Front Load Washer
I have a hotpoint aquarius ultima 1200 wm 72 but no users handbook where can I get one from
Goto;
www.hotpoint.service.co.uk
In the drop down list on left click on-----------hotpoint manuals , user guides, handbooks.
In the search box type in your model number, and download instructions.
Plz rate my solution.
Thanks.
Jan 15, 2009 | Hotpoint Ultima WD72 Front Load...
Door seal has two holes in it and leaking
Hi.
You need to remove the front console panel and then the front panel to change the door seal.
Pull the dispenser drawer out and remove the screws.
Slide the console panel to the right and support it while you remove the rfont panel.
Change the seal, and reassemble in reverse order.
Good luck.
Nov 20, 2008 | Hotpoint Ultima WF860 Front Load Washer
Re Hotpoint Ultima washing machine
this is a common fault you can get hotpoint to replace the board at a cost of £90 or buy a second hand board for about £40 sorry but this is your only option without sending your board to qer
Jul 07, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima baby icon flashes/beeps
the icon means that the child lock is on.
if you switch on the power to the appliance and hold down the child lock button untill the icon disapears the you will be able to select a program.
Apr 15, 2008 | Hotpoint Ultima WF860 Front Load Washer
Error code f08 on Wt940 ultima.
not sure if this will help but try:
First empty the machine by lowering the hose at the rear to ground level into a container. Take off the white plastic cover on rear at bottom. You will see black rubber hose connected to barrel of machine in right hand corner. Undo the silver screw on the band securing the hose. (Biggest band). You can now pull the hose down to reveal a "table tennis like" ball. Lift it out carefully and you will probably find an obstruction like a coin or similar. I found a hairgrip but it was enough to stop the ball functioning. DO NOT TAKE OFF THE WHITE HOSE CLIPS
Comment by pulmicort, posted on Feb 02, 2008 Further to my comments re clearing scrap from table tennis ball after code F4. Machine started ok but then F5 came up. Had to take the pump off and apart to reveal broken hairclip actually seized in pump. If you are handy at all this is simplicity itself.
Slide pump to left and lift and it comes clear. Take off 2 black hoses only where connected to main machine. Pull off electrical connection. Pump and hoses lift out easily. 3 screws open the pump. Clean any obstruction and reassemble. A 30 minute operation.
Apr 02, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
856 people viewed this question
Top Hotpoint Washing Machines Experts
hungoverrr
Level 1 Expert
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
