Question about Philips HD-5661
I have recently acquired an unused HD5179 Espresso & Cappuccino Bar machine. When I turn it on and hold down the button to aerate, it works away for a few seconds then blows the house fuses. I have not attempted to make coffee as yet.
I too have the same problem wth HD5179..i took it to philips service centre...they barely looked at it and said SORRY NO SPARES for this model.It seems in INDIA philips does not have facilities to service home use exopresso machines...a sad state of affarirs
Posted on Aug 10, 2013
3 Suggested Answers
  • 17 Answers
SOURCE: one coffee cup button switch not wotking properly after 6 months
Call senseo at 866-4-736-736 866-4-Senseo and describe the problem.
if you have purchased or received it as a gift less than two years ago they will send a new one FREE.
Posted on Feb 03, 2009
SOURCE: We have a Philips Senseo
senseo now makes pods in many coffee flavors and coffee varities
can be bought via internet
Posted on Nov 16, 2009
Nespresso latisimo plus 4 lights keep flashing when switch on and just switches off?
Try pressing and holding all four buttons down, then, while still holding the four buttons down, turn the machine on with the power switch. This should return the machine to its factory settings. If you've had the machine for a year or more it may need descaling, but the Cappuccino button usually glows orange when this is necessary. Hope this helps - good luck!
Feb 16, 2015 | Nespresso Coffee Makers & Espresso...
Cappuccino and latte macchiato buttons blinking
The unit is heating the steam - the lights should switch to contant once the right temperature is reached. Make sure to always descale the machine if the cappuccino button light turns orange.
Mar 29, 2014 | De'Longhi Nespresso Lattissima Plus...
Hello. I have a Saeco Magic Cappuccino Plus machine, which should be similar to the Saeco Magic Cappuccino machine that was occasionally discussed on FixYa. My machine was working OK until yesterday. I hit...
Hi
Yes. The thermal fuse is incased in a browish/red cover and is held on to the boiler by a clamp that holds the thermostats on. Slide the fuse out from the clamp and slide the cover off the thermal fuse. Test with a ohms meter. If its bad you should get no reading. You can get a new 182c thermal fuse from Radio Shack, electronics store, or appliance store. If no luck there online espresso machine retailers like Seattle Coffee Gear, Whole-Latte-Love, 1st-Line should be able to help you. Do not try to solder the new fuse in. It has to be crimpwed on or it will blow again.
May 07, 2011 | Saeco Magic Cappuccino Espresso&Cappuccino...
I need an owners manual for the Saeco Royal Cappuccino machine? SUP016R manufactured in 6/2006
Scroll down this page:
http://www.saeco-usa.com/en/products/household-automatic-machines/1/automatic/0/royal-coffee-bar/17/royal-coffee-bar.html
You can download the manual for your Saeco Royal in a PDF format.
Hope that helped! Thanks for using FixYa.
Jun 10, 2010 | Saeco Royal Cappuccino Espresso Machine
Water button orange light appear even after descaling
I had the same problem too.
Do repeat the descaling with water only. After the descaling the Lattissima shuts down. Just wait some time after shutdown before restarting the Lattissima again. The orange light will be turned off.
Hope this helps you too!
May 01, 2010 | Nespresso Lattissima 660.R
Hi the cappuccino button pushed only goes for a few seconds and stops before you have to push it over and over again to get the job done. What can I do to correct this problem
Hi
There is a program in your menu for the cappuccino that can be turned off so it will go al long as you want.
You might try also holding the button down and see if it will go longer? Some buttons are programmable by holding the button down until you get the amount you want, then release it.
Jul 01, 2009 | Saeco Royal Cappuccino Espresso Machine
My Saeco Royal Cappuccino Coffee machine says "refill water tank' when it is already full. I only use filtered water and have descaled the machine. How can I fix this?
This sounds like the water sensor needs replaced //Also make sure the inside float is not stuck in the down posistion!
I hope this helps!
Dec 13, 2008 | Saeco Royal Cappuccino Espresso Machine
The touch lift drip tray is broken its the plastic shaft that holds it together so its unusable.. I think someone lifted the machine by the lift tray or the shipper put the box upside down and it broke.......
The entire machine need to be taken apart to repair the auto drip tray. I would reccommend a Authorized Service Center to replace the tray. It is again not a simple fix.
Saeco's First Authorized Service Center of New York
Cerini Coffee Service
718-584-6120
www.CeriniCoffee.com
Oct 08, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Selftest sign
Try to make a cup of water(tea), press the button for water.
On the old Royal Cappuccino that are the button on the right down corner and the new machine had it on the upper right corner.
Hope this will help you.
/Mirran
Aug 16, 2008 | Saeco Royal Cappuccino Espresso Machine
Are there any published example beverage settings for Saeco 8p expresso vendings Eg, Recipe for cappucino & latte
what kind of recipe do you want to know.Cappuccino is Made from Latte and Coffe.Sturbucks is not Cappuccino..Originally the name cappuccino came from COFFE(BLACK) AND MILK(WHITE).Both togheter give the color called CAPPUCCINO.In so many years the cappuccino found different way to make it work....caramel,coccoa,nutmeg....The good recipe and famus still the regula cappuccino with sweet or unsweet coccoa on the top of the foam.
Apr 19, 2008 | Saeco Incanto Classic Espresso Machine
Philips HD-5661 Logo
126 people viewed this question
Top Philips Coffee Makers & Espresso Machines Experts
Kolbrun...
Lisa
Lisa
Ross Keen
Are you a Philips Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
