Question about LG DLE2516 Electric Dryer
Connecting a 4 wire plug and only three connections
  • LG Master
  • 43,501 Answers
This tip will show you just how to do that...
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
heatman101
Posted on May 03, 2010
Tip
Electric Dryer power connections
The supply cord on an electric dryer can be 3 wire or 4 wire,
depending on the existing receptacle. All new construction
must have 4 wire receptacles for dryer hook ups.
At the back of the dryer you will see a set of three
terminals. The outside terminals are for connecting the
outside wires of the cord. In a 4wire hook up, the center
terminal is for the center, insulated, white wire, the
neutral. The bare copper or green wire of the 4wire cord
gets connected above these terminals to a lug or stud on
the body of the dryer. There may be a strap there. For a
4wire cord connection this strap is connected to the stud
only.
The change for a 3wire connection is that the center green
wire of the 3wire cord connects to the center of the three
power terminals along with the grounding strap from the
dryer body above.
on May 05, 2010 | Washing Machines
What is wiring to convert a 4 wire power plug to a 3 wire plug/
This is a tip i wrote about connecting 3 and 4 wires dryer cords http://www.fixya.com/support/r10097207-connect_yournew_dryer_cord
open and look at it to see how to connect the 3 wire cord
Gene
Aug 21, 2011 | Dryers
Hello, I have 33-990 10" Radial Saw and loss the conection of voltage 230 115 switc selector , they have 4 wires to conect, I need the order. Thanks.
If you are connecting up to three phase the black wire is the neutral, Connect the other three and if the motor runs the wrong way change over two of the wires - not the neutral.
Feb 08, 2011 | Delta Machinery 10" Professional Radial...
My plug for my wall is a 4 prong outlet but the dryer is a three prong plug. The cable to by is a 4 prong plug but the back attachemnet only has three slots for the cable to plug into. What do I need to...
The 4 wire cord will connect as follows.
Red and Black wires connect to the 2 outside terminals on the back of the dryer.
The White wire connects to the center terminal.
The Green wire connects to the grounding screw just outside the terminal cover on the rear of the machine.
Sep 13, 2010 | Roper REX4634KQ Electric Dryer
I am connecting three switchs to control one light. how do i connect using a 4 way switch
The wiring method is power into the first 3-way switch, 3-wire to the 4-way switch, 3-wire to the second 3-way switch and 2-wire to the lamp. The way you terminate the wires on the switches is only important on the black terminals of the two 3-ways. Power and load go on these, the rest are just travelers.
Nov 15, 2009 | Leviton Decora Gray Rocker 4-Way AC Quiet...
I have a new 4 prong plug to replace a old 3 prong on dryer
On a three wire configuration, the ground and the negative are tied together at the center position, using the dryer ground strap. Following is a description of the difference between three and four wire. Hope it helps you.
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top/left is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom/right.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Sep 15, 2009 | Westinghouse WWS833ES Super Capacity Top...
My dryer has a 3 pronged connector but the new house has a 4 pronged receptical. I took the old cord off and purchased an new 4 pronged cord. My problem is that the dryer has three connecting points for...
to a screw on the rear of cabinet there may already be a wire connected there if so remove it and tape it off install green ground wire there
Aug 05, 2008 | Dryers
Wiring 4 wird dryer plug to 3 wire 10/3 for 220 welder
the four wire plug seperates the neutral and ground. the three wire just piggybacks the ground to the neutral. so just get a three wire cord that fits the 220 plug on the generator and install it on your dryer make sure to attach the ground correctly for your three wire setup
May 07, 2008 | Dryers
LG DLE2516 Electric Dryer Logo
51 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
