Question about Asko 24 in. D3530FI Built-in Dishwasher
Dishwasher runs even tho the door is open - Asko 24 in. D3530FI Built-in Dishwasher
  • 128 Answers
The door interlock switch is jammed in the closed position.
There is a metal tab on the inside top of the DW frame that engages a lock just behind the handle on the inside of the unit. The lock tells the machine the door is closed and it is OK to run. If that jams the unit thinks the door is closed.
Open the door.
Look for the latch inside the door behind the handle.
Try to release it with a screwdriver.
If you need to you can remove the handle and repair from inside. It is usually a simple jam that requires you to gently pry the latch open.
REMEMBER TO TURN THE POWER OFF FIRST.
Hope this helps. Please rate this if it helps you.
Thanks,
Adrian
Posted on May 03, 2010
My dishwasher runs but door is in locked position. it will now run with door open and the door wont close/lock
It sounds like your door latch got tripped into the closed position (even though your door is open). You MIGHT be able to use a screwdriver or some tool to be able to pull the latch lever back out to the open position, but it might also be necessary to take the door apart to get to the latch to be able to reset it. The real problem is that if it happened before, it will probably happen again. So the real solution is to replace the latch assembly.
May 31, 2015 | Jenn-Air 24 in. JDB2100AW Dishwasher
Zanussi zdt6053
Something wrong with Brake System of your Dishwasher. Contact Authorized Customer Service Center.
Mar 29, 2014 | Dishwashers
Smeg dish washer wont stop even when the door is opened,
I never heard of a smeg DW but you can bet the door interlock is hung up in some way. Ususally its micro switches on the latch assy. Then again, could be a bad relay on the control board. I would dis connect the switch first and see what happens. The way I would do that is disconnect power at your circuit box and dis connect the switch, tape off the wire, latch the door and return power. Bet it doesn't run. Most likely the switch assy. Would help to know the right brand name tho...
Oct 16, 2013 | Smeg Dishwashers
Bosch shv46c03uc
I would check the latch on the door..When you shut the door it makes contact telling the washer it's closed
Aug 17, 2013 | Dishwashers
Bosch SHU runs even when the door is open, what do i need?
Hi Jeffrey,
This depends what you mean by "runs". If the dishwasher continues with a wash cycle - i.e. circulating water - with the door open, the simple answer is that you have a defective door microswitch.
However, I suspect what you perceive to be the dishwasher running, is actually the drain pump running continuously. This happens when the anti-flood protection system has been activated and continues even when the door is opened. The simplest way to check is to open the door (while it's "running") and pour some water into the tub. If the water drains away immediately, this shows the drain pump is running and the anti-flood protection has been activated.
This may be due to water having leaked into the base of the dishwasher, but it could be as simple as a stuck or defective float-switch.
Please try the simple test above then post back for further assistance. If you're planning to investigate or repair this yourself, you're going to need a Torx T20 screwdriver and a multi-meter would be useful as well.
Regards, BElectric
May 25, 2011 | Bosch SHU9915UC Dishwasher
Water leaking under floor when dishwasher runs
check the water to the unit it is locate under the door open the panel 2 -4 screw take flash light turn the unit on and see where the water come from ... it might be also from under your sink.
Jan 01, 2010 | Dishwashers
My Bosch SHV46C dishwasher keeps running, even when the door is open, unless you turn the control switch off. Then, when you turn the switch on, it starts running again.
I have a Bosch that was stuck in pump down mode even when the door was open.
The problem ended up being too much water in the drip pan below the unit. There is a float in the drip pan that actuates the same limit switch as the internal overfilled float.
I had recently cleaned the incoming water filter and must have loosened the water line tube.
Nov 20, 2009 | Bosch SHV46C03 Built-in Dishwasher
My BF162 runs with the door open. I also cannot
Yup, could be that pesky door latch, or even the control panel board. This could be a case for a repair man or replacement, depending on the cost.
Sep 25, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Kenmore dishwasher. The upper rack is not getting clean. Even very light residue remains. And, detergent is left in door at end of cycle. The bottom is filling up, so I don't think it's the intake valve....
I find it odd that the dishwasher is filling with cold water if the water is hot at the sink. It sounds like the dishwasher is connected to the cold water line rather than the hot. Check under your sink; if you've got standard plumbing, the dishwasher supply line should be connected to the left water pipe.
Regardless, the water temperature doesn't fully explain the symptoms, especially the detergent left in the door (assuming you're using fresh detergent and it's not caking in the door prior to washing).
I would check the blades again. Even thought they may appear clean, there may be debris in them that get forced into the openings during operation, but fall away from the openings when the water flow stops. Remove the blades, run water into them, then invert them to drain while rocking back and forth. If there's crud in them, you may need to do this several times.
Sep 14, 2009 | Dishwashers
Dishwasher running with door open
most dishwashers will stick on pump if there is water in he base of the dishwasher . If you tilt the washer back only about 45 degs and water runs out of the back at the bottom the you have a leak but it could come from any where. But when there is no water in the base then your washer should start to work again until it fills back up
Dec 11, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Asko 24 in. D3530FI Built-in Dishwasher Logo
297 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
