Question about Fuji FinePix J10 Digital Camera
Hello my barely used fujifilm fine pix J38 camera zoom error mess
Hello my barely used fujifilm fine pix J38 camera will not work, when turned on the the lense pops out and the message on the screen says zoom error and the lens quickly goes back in. Hoping you can help
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 03, 2010
FujiFilm fine Pix A 345. Lend won't open upon turning on camera. Camera makes a buzz noise and then the display reads zoom error.
Those things get stuck.
You have to mess with it until it comes unstuck, if it even does.
Try hitting it while you are turning it on. Tap it from all sides and directions.
You might get lucky.
I got mine to come back to life temporarily.
Please don't give me a thumbs down just cause its bad news.
Aug 31, 2011 | Fuji FinePix A345 Digital Camera
I have a Fuji finepix j38. I went on the beach and it got a little wet and it wrote zoom error and now it isn't charging either.
Welcome to Fixya. Having a "zoom error" message is a camera malfunction, in this issue you can try to turn off and then turn it on again but this time you have to take care not to touch the camera lens or try not to blocked the camera lens while retrackting. If you still have the same issue you can try to visit this site for some steps you can do before sending your camera to your Fujifilm center.
In regards your issue about the charging of your battery,as you said before that you bought your camera to the beach. Try to clean the terminals with soft and dry cloth. Also, possible that the battery has reached the ends of its charging life. Purchase a new battery. If the battery still fails to charged, you have to contact your Fujifilm center.
Please let me know if you have any question.
Thank you for using Fixya.
seancarlisle
Apr 27, 2011 | Fuji Cameras
Fujifilm finepix j38 series reads zoom error and wont take a pic.
If you have some skills, you can open the camera and cline your zoom lens with toothbrush and compressed air. Try to separate zoom lens from the electric motor. usually is 2 or 3 screws. You will see a lot of sand inside the camera and lens. And next time when you will go to the beach, you will take more care about your camera.
Solution 2, and more easy is to buy another zoom lens from ebay.Or another camera same model with broken LCD or other technical problem than zoom lens.
May 31, 2010 | Fuji Cameras
My fujifilm finepix j38 has a zoom error
Were you able to fix this?? My camera has had this error for over a week now and I cannot figure out how to fix it...
Feb 09, 2010 | Cameras
Finepix j38 zoom error
I Fixed mine a few times what i did was turn it on it would scope out and back hold it and keep it from going to back in then go to pictures then exit it should be working fine now
Oct 09, 2009 | Fuji FinePix S304 Digital Camera
Fuji finepix s8100fd zoom error message
I'm npt sure if this will work as I have yet to try this for my self. But according to others who have had this problem pulling lens out while camera is off and then restarting camera works. If this does work please notify. Or just tell me what happens when this is done
Oct 15, 2008 | Pix FUJIFILM Fine S1500fd Digital Camera
Zoom Error
I'm not sure if this will work as I have yet to try this for my self. But according to others who have had this problem pulling lens out while camera is off and then restarting camera works. If this does work please notify. Or just tell me what happens when this is done
Aug 03, 2008 | Pix FUJIFILM Fine S1500fd Digital Camera
Fuji finepix displays zoom error
Jul 09, 2008 | Pix FUJIFILM Fine S1500fd Digital Camera
Menu button and Zoom buttons not working
Yes im having the same problem ,however i open/disassembled my camera and my results was a broken ribbon connector from the Rear Button Board to the Main circuit board.....
The only problem is i can not find any parts list information or where i can get this part....
can any one help me with this??
FUJIFILM F460 Camera
REAR BUTTON CIRCUIT BOARD
Rear Button Assembly
Thanks
Wooker
NOKTURNAL CAR CLUB
BALDWIN PARK, CALIFORNIA
Jan 14, 2007 | Fuji FinePix F460 Digital Camera
Fuji FinePix J10 Digital Camera Logo
399 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
