Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Inputs do not work after power outage
The power in my area went off today, when it came back on I turn on my tv (model WD-65734), just a blue screen, I did get the Wii to work that was connected via the front inputs, however the picture collor was way off. none of the inputs in the back seem to work. I tried resetting, no luck. what could be the problem?
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
The set has three ways to reset---the tiny button on the front, A second is called a soft reset, and the third requires going into the tech Menu with a code via the remote.
Try the soft reset first and let me know if it helps.
With the set on hit: Menu, 1, 2, 3, and enter.
SD TECH
Posted on May 03, 2010
Power outage
It sounds that the main system control memory IC data has been currupted.
Sep 26, 2013 | RCA L32HD31 32 in. LCD HDTV
Screen went completely white but still have sound
Try with the Mitsubishi remote the soft restart, set on Menu,1,2,3, and enter.
Dec 07, 2012 | Mitsubishi WD-65734 65" HDTV
I need a code for my samsun blue ray to be used with the Mitsubishi wd-65734 remote
The Mitsubishi has a list of its codes in the owner manual and also I think has a search mode---can try all possible codes one at a time.
No owner manual? Google the model number of set with "manual" if cannot find let me know with a comment here and I will try for you.
SD TECH
Apr 24, 2012 | Mitsubishi WD-65734 65" HDTV
Mitsubishi wd-65734 65 in. Tv shuts off on its own and red lamp light comes on. after a few minutes i can turn it back on and works fine for a few min to an hr before doing it again. anyone no wat the...
Same thing on my tv after replacing lamp. Lamp manufacturer advised me that after changing bulb, tv must be reset or tv will go into safety mode and will not turn on. To do this on my model WD-65734 you must hold reset button in with a pen or paperclip for about 10 secs.The LED will start blinking for a few mins. When itstops you need to unplug tv set for about 1 hour. After this the tv will be reset.
Apr 22, 2012 | Mitsubishi WD-65734 65" HDTV
WD-65734 Mitsubishi TV won't turn on. System reset
Are there any lights lit on the front of the TV? Have you checked for a bad lamp? When you reset the TV the timer/power light should flash on and off rapidly for 60-70 sseconds. Does that happen?
Aug 26, 2011 | Mitsubishi WD-62526 Projection TV
I have a apex 32-inch tv model (AT3208S), This tv was connect to a converter box, the other day electric power went out in our area for about 8 mins or less, once the power was back on the tv screen was...
OK, I have one of these TVs, and here's a thought: There's nothing wrong with the TV nor with the cable converter box. Please bear with me. Since I don't know how much you may know about TVs in general and this one in particular, I'm going to assume you know nothing and go from there.
This TV has several different "inputs", which are ways a signal can be transferred from its source to the TV, where it "outputs" the video image. I believe this particular TV has 5 different inputs: In descending order of the quality of the video signal, there're one S-video input (a 4-pin video connector plus red & white audio), three composite video inputs (3 connectors each: yellow video and red/white audio--audio connectors are the same for both s-video and composite), and one coax connector (a single large screw-on connector with a little wire sticking up through the center of it) for a total of five different inputs.
The problem with these Apex TVs is that they always default to the Antenna/coax input first when they are restarted. Most people use the TV to display an input signal (like the cable box or a DVD player) connected either to the S-video or to one of the 3 composite video inputs, not to the coax input, which just displays the channel numbers from 1-125 when it's set to do that (hit the "display" button on your remote to toggle showing the channel numbers for the coax input). If there's no signal coming into the coax input, the screen with appear blue. (If it's blue, it simply means it's not getting a signal via the input to which the TV is currently set. You can turn off the blue screen in the menu settings, but then you'll just get a blank screen. It's probably better just to leave the screen blue; at least you can tell the TV's actually trying to display something that way.)
You have to manually select the proper input by pressing the "video" button either on the remote (lower right corner) or the "video" button directly on the TV (hidden control panel under the middle of the margin around the bottom of the TV screen. You'll have to press on the door, and the whole control panel rolls open to reveal another set of composite inputs and some buttons. The video button is the one farthest to the left.)
Anyhow, by pressing the video buttons, you'll cycle through the various inputs. Assuming your cable converter box is functioning properly, powered on, receiving a signal from the cable company, and connected to the TV via a(n) appropriate wire(s) connected correctly, you should see the output from the cable box on the screen when you cycle through to display the proper video input.
Another possibility: the power outage fried the input to which your cable box was connected on the back of the TV. If that's the case, your cable box would probably also have sustained damage. You can check to see if the various video inputs on the TV are working by connecting different source inputs (like a BluRay/DVD/VCR player, video game console, video camera, etc.) to one of the other inputs and see if you get a picture when the TV is set to the appropriate inputs. (Remember, the "video" button is what selects/changes/cycles through the various video inputs.) One of the sets of inputs went bad on my TV. I just use the other ones.
May 18, 2011 | Televison & Video
When you turn the TV on it stops at the blue Mitsubishi screen and the power button just blinks. You have to then unplug the TV to power down. Pushing the power button on the TV or remote will not power...
There is a software update that is available for some Mitsubishi dlp models. The wd-65c9 is one of them. When I experienced your problem, I went to the website, downloaded the update, and installed it on my tv and boom, its fixed. It's super easy, free, and takes a few minutes.
Jan 31, 2011 | Mitsubishi WD-65C9 65" DLP HDTV
Mitsubishi WD-52525
Normal 0 The Mitsubishi WD-52525 has a serious capacitor problem as discussed in this forum overseen by a Mitsubishi certified repair technician: http://www.hometheatershack.com/forums/mitsubishi/11703-problem-mitsubishi-wd-52525-scrambled-picture-no-picture-2.html. There has been a worldwide problem in computers and TVs over thepast several years with faulty electrolytic capacitors (from Taiwan) thatdecay, dry out, swell and die. The power supply is often the firstcomponent to go bad, but other systems also degrade over time. As theforum explains , this problem is widespread in these sets causing multipletypes of display problems after several years of use. On my set, I also got a blue screen with a lighter blue ball in the middle. Mitsubishi is awareof the problem and will cover most of the cost of repairing the chassis, evenyears out of warranty, but apparently ONLY if you get an estimate from aMitsubishi certified repair station and contact their customer support BEFOREdoing any work on the set. I just followed the recommended procedure onthat forum and Mitsubishi is covering half the cost of my $700+ repair when my3+ year-old set recently died and showed only this blue screen on all inputs.
Mar 31, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Blue Screen & inputs dont work.....capacitors?
I had the same problem, I called Mitsubishi and they with trouble shooting help, they told me to get a new lamp. Well I got a new lamp and but nothing happens, the tv screen is black no sound, no picture. I went to this site http://servicemanuals.vstore.ca/product_info.php/pName/v26-dlp-fmt-pwb-repair-kit/cName/repair-kits/osCsid/5ac56adb48ff3afdd7ff25c1f1f5cbf2 and with their help, and troubleshooting help, said this kit would work, I just got it today,and I am going to install it now, I will be back to let you know. But I do suggest you go on that site, and try to get some assistance, they sell the service manuals for 16.99$, but if you buy a kit, it includes the manual. Well let us know what happens, and I will be back.
Aug 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
153 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
