Question about Samsung S1050 Digital Camera
Samsung s1050: camera lens blurry
Samsung s1050: camera was dropped accidentally while being passed from one person to another. the lens view is now blurry & when i zoom in the camera shuts off
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 03, 2010
My samsung s1050 keeps locking up intermitantly. beem stays on.lens freezing.have to re insert batterys over and over to get working. any ideas?
The Samsung S1050 is very battery hungry - make sure you use very fresh new batteries, rechargeable are great - the higher the mAh rating the better. I use Intec rechargeable batteries which are rated at 2900 mAh. If you do use rechargeables, you will have to set the appropriate menu setting for battery type to reflect the type of batteries used.
Jan 25, 2011 | Samsung S1050 Digital Camera
Taking close ups
you have to put the camera in macro mode. that camera has 3 different macro settings. auto macro, macro, and super macro. here is a link to the manual if you dont have it. macro stuff is on page 24
http://www.pandigital.net/userfiles/file/Downloads/UG_E-FRC_PAN80XXT_V2_5_01-14-09.pdf
May 26, 2010 | Samsung S1050 Digital Camera
Samsung L50: I get a very blurry - near white image when taking pics outside. Inside the pics look ok, a little blurry though. Movie recording works fine. Help please. Tried changing batteries, reseting...
Check if you are using Auto settings. It seems you are using Manual (M) and the exposure time is too long for outside conditions (inside there is less light).
Switch the camera to Auto and it should work fine. Please let us know how it went.
Apr 11, 2010 | Samsung Genuine Digital Camera Digimax...
Camera frozen with lens extended
Is it cocked to one side? I have one like this . It needs a lens.
Oct 09, 2009 | Samsung S1050 Digital Camera
Samsung S1050 -out of focus - beeps twice and switches off
The drop indicates that you have damaged the lens tube (housing). This damage will prevent the lens from moving properly and will cause the camera to shut itself off after a few seconds. If the lens is damaged the camera will require professional repair. If the lens is not damaged, the problem may be battery related. Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Sep 14, 2009 | Samsung S1050 Digital Camera
S1050 frozen
Today (2009/11/21) have the same problem with the black model of s1050, sometimes ear the motor running but the lents dont move and the cam still dead.
Source problem : Photos whith ASR+Macro+5xZoom and switch to AUTO+Macro+5xOptical+3xDigital
Aug 03, 2009 | Samsung Digimax L830 Digital Camera
When I view my pics on camera, I cannot view back (left)
janet
when you are view your pictures you have taken you are hitting the little movie camera button which is at the top of where you are pressing the arrow back and forth. just hit that button again and the
microphone will go away. I have had this happen to me. the button are small and our fingers are to big. once the microphone goes off you will be able to push the arrows to view your pictures forward
and backwards.
hope i have helped you
connie
Jan 18, 2009 | Samsung S1050 Digital Camera
S1050 Samsung crashed?
ok, i had a similar problem I had normal batteries in there... cheap ones... and accidentally set the battery type to NiMh in the camera settings... it wouldnt turn on after that. Make sure you try NiMh batteries in case that might be your problem. Another thing i have noticed (may be just my camera) is that it doesnt want to work if its cold....
Aug 22, 2008 | Samsung S1050 Digital Camera
Samsung S1050 Digital Camera Logo
250 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
