Question about LG WM-2277HW Front Load Washer
Washer won't drain and sounds like it is stuck at that mode. So it will not go to the spin mode. If I drain manually and all water is out of washer it will go to the spin mode. Easy fix or is this a service call?
  • 3 Answers
Most probably the pump filter is blocked or the pump motor is faulty. Access the pump filter via the small door at floor level. Clean it out and check that a coin isn't stopping the pump from turning....... If the pump motor is faulty, (and this is not uncommon), it need to be replaced....Not a big job for a tech, but awkward if you're not experienced...Good luck....Nomess
Posted on May 07, 2010
Washer stuck in drain and spin mode
Hello. I need the model number to help you accurately. When the unit drains, can you verify water *is* actually being pumped out? This is important because no washer will spin if it can't pump all the water out--modern electronic washers have to balance the load and water is an unknown, shifting quantity. I need the model number to assist you in initiating the diagnostic mode and explaining the possible error code(s) you might be getting. I hope I helped you!
Sep 15, 2015 | Kenmore Washing Machines
Machine stuck in drain mode, beeps, can only turn off at powerpoint.
Your motor controller board is faulty
needs repair or new/recondition board.
May 06, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
GE WSXH208V1WW
Usually when you have a washer that will not drain, first check if the drain hose is kinked or too high above the washer (8 ft is the limit of the washer pump). Next check if there is a blockage in your drain (often a stand pipe) or if the air can't get into the stand pipe. The final thing to check is for foreign objects in the pump to drain hose area that block the drain. (This requires getting into the pump and disconnecting the hose. Keep a bucket ready to catch the water that will pour out of the washer.)
GE has the manuals for many of their appliances on their support site: http://www.geappliances.com/service_and_support/literature/ . Enter the model number and click submit. The direct link to the manual for the WSXH208V1WW is http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-90256.pdf .
I hope this helps.
(at least my washer won't spin if the water can't pump out. On a few washers (non-high efficiency) the solenoid has failed to open for the pump to drain the water.)
Nov 22, 2011 | Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Maytag Neptune Washer MAH8700AWW will not spin. It will fill, drain, tumble ect but will not spin. i tried a quick spin test and it sounds like it is trying to drain after all the water drains. I went...
You may have tried this, but check the door switch, and the pressure switch(water level switch) to see if either could be bad. both of those affect whether the washer spins or not.
Jun 12, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Water doesn't drain
you could have a bad drain pump.
have you checked the hoses that come from the bottom of the tub to the drain pump for anything that might be stuck in there,also check the hose that comes off the drain pump to the wall and look for an obstruction.
Jan 31, 2010 | Asko W6021 Front Load Washer
Whirlpool washing machine won`t spin or pump out
if youre handy with tools , check out the DRAIN MOTOR PUMP , usually located at the bottom on a side of the washer , it could be clogged with lint or debris , need to open washer , remove the DRAIN MOTOR , inspect inside to remove and clean it , be ready with rags , theres a lot of water that will come out once you remove it . good luck AJ
Jun 08, 2009 | Washing Machines
Fisher Paykel GWL10US Washer won't spin
Look at my issue on "eco smart won't drain, smells hot". You could have same issue and your motor just hasn't burned up yet.
Oct 16, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel GWL10US won't spin
hi
if the pump works fine in diagnostic mode then it has tobe a module problem
cheers grant
Oct 15, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel GWL10 US spin cycle issue
check out another website. ths.gardenweb.com/forum/laundry for other fix it tips on FPaykel.
Oct 12, 2008 | Fisher and Paykel GWL11 Top Load Washer
LG WM-2277HW Front Load Washer Logo
128 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
