Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Have cold water but no hot water
I turned on the washer hot water only a little hot water came out then it just stop
  • 1 more comment
  • labcab Mar 26, 2008
    I am having the same problem. I have checked the screen in the inlet valve for the hot water connection on the back of the washer. Everything is clear of obstruction and the screen is in good shape. I have also checked my hot water valve at the wall, and everything looks works fine there as well.
  • Anonymous Mar 29, 2008
    I have similiar problem. Hot water will not enter washer. Only cold water. I checked inlet screens for any obstructions and they are clear. No problem with hot water from tap to washer.
    Temperature Control switch allows cold only. When turned to the hot/cold position, hot will not enter. Nothing happens.
    Don
  • labcab May 11, 2010
    Both taps are on. All I get is cold water. No warm, or hot, water during any part of washing the load. I am thinking it might have to do with the solenoid that controls that hot and cold water intake. Any thoughts?
    Sergeant:
  • 351 Answers
Try turning on both taps and see what happns,some of these whirlpool machines need both taps on but mainly when running on cold.
Posted on Mar 26, 2008
SOURCE:
Washer starts and then stops
Just in case it is waiting for water-
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Sep 04, 2011 | Frigidaire ATF8000F Front Load Washer
Ge front loader hold start button the cam dial starts to turn and the drum turns a little but no water and then stops help
'...but no water'.
John C
Sep 01, 2011 | GE WSXH208A Front Load Washer
Washer don't get the cold water only the hot cold water won't enter and the hot enter extremelly hot
(this covers both hot and cold but please read for cold! Your hot water supply provides the extremely hot water and is normally mixed with cold in the washer for the correct temperature.)
John C
Aug 27, 2011 | Frigidaire FWS833A Top Load Washer
Hot water won't run into washer
G'day. The hoses from your laundry taps hook up to your machine onto what are called solenoids. These are like electrical taps. The machine decides when to turn these on and off and in what order via the timer and depending on what modes are selected. Generally there is a hot and cold solenoid. If you have both hot and cold hooked up to your machine, you can simply swap these hoses around (put the hot tape on the cold solenoid and vis-versa) Then when you select cold, you'll actually be getting hot. Some new machines heat water internally like dishwashers, and they only have one solenoid. Again if you put the hot tape only on, you will get hot water with cold selected. In both solutions you are losing the option for cold or hot cycles with a click of a button - now you must swop hoses...
Aug 17, 2011 | Maytag Legacy MAV208DAWW Top Load Washer
I have a frigidare washer and after a few minutes the cold water stops coming in too the washer but the hot water still works we have undid the cold water hose it is a constant stream it does not stop...
(check all of these things but for 'cold' only!)
John C
Jul 24, 2011 | Washing Machines
No hot water going in
your water inlet valve is probably bad or stopped up with debris. some valves have screens that can be cleaned. you can swap the cold line and the hot line and check it that way. (you should get hot water when set on cold this way and cold for hot) be sure to turn the water off before swapping the hoses or you may get a little wet.
if the valve needs replacing you will need to remove the cabinet from the machine.
May 25, 2010 | Kenmore 24872 Top Load Washer
Our temperature control isn't working. If we put
You must have water to both inlets. Even with cold/cold, Your washer will mix the water some. Detergent will not activate if your water is extremely cold as it comes straight from the ground.
Nov 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Front Load Intellisense 6.5kg
washer may not be detecting water temp but water flow ..if you never use hot water may try hooking cold water to a Y-connector and then hooking to both hot and cold inlet valves ..however it is also possible washer is detecting inlet temps in which case you're out of luck ..i suspect the latter
Sep 01, 2008 | Washing Machines
Ge washer
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 26, 2008 | Whirlpool GST9679P Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
517 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
