Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Door always opens, intermittant stopping when the door is closing. Sometimes it closes all the way, other times it stops repeatedly and you must press the close button many times to get the door to close. Just replaced both sensors, did not mitigate the problem.
  • 8,457 Answers
Sorry to say,u should of replaced the whole control box.This is not a sensors problems,it the control box problems.U know basic electronic's and soldering?Take the control box aparts,check for these bad capacitors leakages,these capacitors alway have the top of it bulges or puff up.These capacitors not giving it max power that why it work sometimes,sometimes don't.Replaced these leakage capacitors,ur power should return yo normal.
Posted on May 03, 2010
Runs when door is closed,stops when open!Checked the three door switches;all good.The mw is 5 years old so anyone have suggestions as i would be thanking U in advance
It is possible that a relay on the control board has stuck in the closed position. You can try tapping the relays on the main control board and this sometimes breaks them free. It still may be one of the door switches but I would suspect the control board or possibly a stuck start pad on the touch panel.
Apr 24, 2015 | Cuisinart CMW-100 Microwave Oven
I have a LiftMaster garage door opener. It has started to act up a bit, and I can't seem to locate the problem. It opens just fine, but when we try to close it, with either the remote or the wall control,...
If the opener feels any resistance it will act like this.Make sure that the rollers on the door to frame are oiled well and turn easily, move in and out easily as well, you can also turn the screw to increase the resistance stop pressure.Oil the rollers well
Jan 22, 2011 | liftmaster Chamberlain Garage Door Opener...
Garagedoor intermittantly will not close. moves one or two inches, stops, then backs up. other times it works fine. when it fails to close, I unhook, manually close the door, rehook by pressing the power...
If the main light is flashing 10 times when the door reverses to the open position it is a door sensor problem. Make sure the small light on each sensor is not flickering ever so slightly. This will cause an intermittent problem like you have. Tweak the sensors just a bit.
If the main light is not flashing 10 times you may just need to increase the 'down force' just a tad. This control is on the rear of the motor unit near where all those white wires go.
Mar 23, 2010 | Sears Craftsman LiftMaster Chamberlain...
As I close my garage door, I like to leave it open about a foot. I used to be able to stop it with my remote, but now I have to push the remote repeatedly to get it to stop. I have checked the batteries...
Newer openers have always been designed to reverse to the open position when a button is pressed during closing. This is a safety feature. To do what you want you must press the button while the door is opening. That will stop it where you want.
Oct 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
Microwave continues to run when the door is closed
Did you pressed the stop/clear button? or disconnect the micro.. for a couple of hours and try again?
Apr 04, 2009 | Microwave Ovens
Garage door closing
HAVE YOU ADJUSTED THE SENSITIVITY??
ALSO SPRAY THE SPRING WITH A LITTLE WD-40 SOMETIMES THEY BIND AS THE DOOR CLOSES.
Mar 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
OTR Microwave Magnetron Fan and Interior Light Run with Door Open
Could be a defective door interlock or control board.
Mar 06, 2017 | Ovens
Craftsman 1/2 HP door opener bounces back open
There should be 2 sensors on the bottom of your door on the inside, 1 on the right side and 1 on the left side.
These sensors serve 1 purpose to send a beam or reflection to each other.
If something is blocking this reflection or is in front of the sensor the door will always come back up.
It is a safety feature so nothing or no one gets hurt when the door is closing!
Sep 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
Whirlpool Washing Machine Quitting during rinse cycle
I would say that based on your problem description that the lid /door switch has a loose or faulty contact .. If you open and close it a few times..it starts to spin and yet when you open it.. it doesn't always stop the spinning.. It is either the switch or the actuator that bumps that switch.. That is where I would begin diagnosing the problem... Hope that helps..
Aug 30, 2008 | Washing Machines
Self start when door closes
if electronic control, one of two things come to mind. 1)your toutch pad is defective.replace it. 2)you electronic board has a leaky component.not very likly though. believe it or not, ive seen it start before by itself then i noticed a large quantity of bugs inside the glass which i realised triggered the microwave 0ff.
Jul 23, 2007 | GE JVM1460SA Microwave Oven
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
109 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
