Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Kitchenaid side by side KSRP25F ice maker quit prodcing ice water dispenser still working possible solutions?
  • 23 Answers
SOURCE: Kitchenaid Superba Ice Maker quit
Make sure your manual doesn't say something about inline filters, or a float that might be sticking in off position. Depending on how ice is made sometimes they have a float to where water rises so hight then gets shut off to freeze and form the ice.
Posted on Dec 08, 2007
  • 330 Answers
SOURCE: GE TFX22CR Ice Dispenser inoperative
Check the ice maker see it is in the right position, maybe you can try pull out the ice maker and clean it and push it back, make sure the position is right.
Posted on Jul 21, 2008
  • 409 Answers
SOURCE: Kitchenaid side/by/side refrigerator Model KSCS25INSS01-Auto defrost happening often and ice machine not producing ice
hi there,
the icemaker is not making ice due to the fact that the valve solenoid may need replacing.
check the water line into the icemaker, to make sure that you don't have a water leak.
the reason the fridge is running is due to the fact that it's trying to remove as much warm air out as possible.
i would have a technician look at it.
Posted on Sep 17, 2008
SOURCE: KitchenAid Superba ice maker not dispensing ice
the problem is that the bottom piece is missing from the ice maker housing. i have the same problem and im looking for that peice
Posted on Oct 31, 2008
tech master
  • 120 Answers
SOURCE: kitchenaid superba 42 side by sside water dispenser
usually when i get a kitchen side by side i trouble shoot the wtr valve first by using a cheat cord that applying volatge directly to the vlave to see if it opens but usually the wire harnes under frezeer breaks the wires so my money is on the wires under the frezerr door cut the sleve off and chec the wires one by one the one to the water is broken
Posted on Nov 03, 2008
Ice maker quit working but water dispenser still works,the reservoir to make cubes also empty.can you advise?
If the ice maker tray is empty you may have a water valve failure. usually this unit have a dual valve 1 for the dispenser the other one for the ice maker some time a side fail and the entire solenoid have to be replace. the ice maker can also be bad. an easy way for you to test if ice maker is good is by putting water manually inside the ice maker tray depending on how cold is your frig wait about 2 hrs or less if the ice maker cycles and drop ice then water solenoid is the problem if not then replace ice maker.
Dec 20, 2014 | KitchenAid Refrigerators
If you add some water there, yourself. It should make some ice for you, untill the water runs out.
Try this
http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
Sep 08, 2008 | KitchenAid Superba Architect KSCS25INSS...
I have a Kitchenaid model ksrk25 that the water dispenser does not dispense water and the ice maker that was working has stopped making ice
It is rare that both sides of the water control valve go bad at the same time, but possible. I will need someone to examine the dual water control valve on rear near floor on the back of your refrigerator. Click here for a=> KSRK25FVBL00 Parts Manual Test the dual water control valve with a multi meter set for 120 VAC and place the probes into the wires that attach to the dual water control dispenser side and have someone press the water dispense control in fountain. With the dispense water pressed look for voltage on your multi-meter. Use care not to touch probes or bare wires to prevent getting shocked while testing. If you do not already have Adobe Reader on your computer click here first=> Adobe Reader X (10.1.1) You can also check the water control valve for ice maker by testing the ohm value first by removal of the front cover on ice maker and then placing the test meter probes in to the N and V opening You should get 150 to 350 ohm's of resistance. Also if your ice maker is dry and has no water then fill with tap water and then allow to freeze. If Ice drops into ice bin and then does not refill with water will point to repacing the water valve. If the clip is not below this post click here=> Broken Ice Maker Repair You also can find parts and user manuals by clicking HERE Sometimes the ice maker is the problem with the water control valve not working on the ice maker side. 2198597 Ice Maker Assembly Watching the clip is really a great way of explaining how to test ice maker and replacing water control valve if needed. If helpful please rate this solution and if you have questions I will be here to assist you, Thanks Sea Breeze
2315534 Dual Water Control
Oct 28, 2011 | KitchenAid Superba Architect KSCS25INSS...
I just purcased a home that has a model KSRP25F Kitchenaid REFRIGERATOR built in 2004, 25.3 cubic feet. There is a red light flashing on the right wall of the freezer and the ice maker is not working. Also...
Go to the page here=> Appliance 911 at top of page and right side you will see Whirlpool Logo like this=> sea_breeze_151.jpg Click Here for this user manual=> KSRP25FNBL00_User_Manual.pdf There are many models that fall under the KSRP25F prefix so if answers to your question beginning on page 13 in user manual don't cover the answer to your question please contact me. Thanks, Sea Breeze
Apr 25, 2011 | KitchenAid Architect 25.3 Cu. Ft....
Water dispenser works, ice maker makes ice but doe not dispense
Remove the ice bucket/container from inside the freezer compartment. Examine underneath at the front of the container to see if ice cubes are lodged between the metal blades. If cubes are caught in this area, they will prevent ice from dropping into the glass/cup.
Feb 22, 2010 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid door ice and water dispensers don't work
Hi
If  the ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution as "FixYa" and revert for further assistance.
Thanks
Rylee
Mar 31, 2009 | KitchenAid KSRG22FK Side by Side...
Kitchen Aid KSRP25F Ice Maker
The ice maker is not working, no ice ice is coming in the tray on my Kitchen Aid KSRP25F Refridgerator, the red light keeps on
blinking
Del
Dec 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice maker not working
the water valve soleniod on the lower back of frig. is bad,get the model number out of the frig. top right and replace,let me know-mike
Sep 21, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice Maker not working
water dispenser works but hte ice maker does not work
Dec 26, 2007 | KitchenAid KSRS25IL Side by Side...
Nov 10, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
336 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
