Question about Sharp EL-2196BL Calculator
Paper/tape jam I was using my calculator not realizing that the tape was going back into the ink roller and it has rolled in three time around the ink roller. I cannot take the three layers of tape out. It almost looks like someone has to somhow take the roller out in order to pull the paper jam out.
  • 168 Answers
Get a pair of scissor and cut through the tape. IF it is rapped up too tight where you can't get a pair of scissor through it, then get an exacto knife or razor blade to cut the paper. Just remember not to press too hard so you don't cut through the rubber roller beneath it.
After cutting the paper, then press the paper advance and start taking the pieces of paper out.
Good luck.
If you still have problems, feel free to repost again.
Have a good day.
Mac =)
Posted on Mar 26, 2008
  • 5 more comments
  • Ace Hart
    Ace Hart Apr 12, 2014
    i have the same problem but the paper has electrical tape on it (don't ask) and it is jammed not rolled around. please help.
  • Mac Gyver Apr 13, 2014
    If you can see the tape, I would still try to use an exacto Knife and try to slice through the tape and then press advance and try to remove the pieces one by one.
    If the tape is stuck with the adhesive side on the roller, (UNPLUG THE MACHINE FIRST BEFORE WORKING ON ITI would get a chemical called "Goo Gone" (NOT to be mistake for GOOF OFF). Apply with a Q-tip and this should help loosen up the adhesive. Hope this works. Let us know. thanks
I need to order printing tape or paper for the P1-DH V. What is the item number for that? Thanks.
There is no specific item number for the printing paper for this model. You can buy any brand of paper rolls, but it must be 2 and 1/4" or 57mm wide. Just go to OfficeMax or Staples and just look for the paper rolls that are 2 and 1/4" wide. If you need a lot of them I would go to Costco, great deal on paper rolls
If you need a new to replace the ink roller the item number is CP-16
This should help you out
Jan 24, 2011 | Canon P1-DHV Calculator
Tape wont register on this after we changed the tape
U.S. Office Machine Co., 5722 N. Figueroa St., Los Angeles, CA 90042. 323-256-2111. "We specialize in the repair and restoration of all your old typewriters, and we have a very large selection of parts and supplies. We have been in business since 1962 and have had many satisfied customers." One customer writes: "The guy who owns the place is a WW2 veteran named Jesse Flores. He's been there 46 years. His son Danny handles most of the repairs now. They also repair the old fashioned adding machines and mechanical calculators. Around Christmas, he gives out toys to needy children and has helped organize the local Christmas parade in the past and such. The building he is in used to be a theatre back in the 1910s, and the fellow has photos of him with every coucilman and mayor, as well as Senators and national politicos from the early 60s to the present, on his walls."
Mar 25, 2008 | Sharp EL-2196BL Calculator
Paper jam
To fix this kind of error, remove the ink cartridge and turn the printer upside down and gently shake it.Check if anything comes out.If nothing goes, or you can't hear anything rattling around, get a piece of card stock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there. Open up the printer and clean the insides with a soft cloth and a brush. That should remove all the bits of paper inside.The teeth on the roller sides may have some dirt stuck on them which does not allow the rollers to roll freely and hence is as bad as paper jam. The idea is that the rollers do not roll whether because of paper or some dirt on the roller teeth. They have to be cleaned.
Thank you !!
Jul 16, 2010 | Kodak Esp 3250 Allinone Multifunction ( ...
I replaced the roll of paper and now it will not
The Casio DR-T220 does not use regular adding machine tape, it requires a thermal tape since it is a thermal printer. There is no ink or ink ribbon in this caculator, it is heat activated and it is the special paper that make the numbers appear. Thermal tape is available at all office supply stores.
Oct 05, 2009 | Casio DR-T220 Calculator
We have a TI-5045 11 calculator. It won't print
Yes it can. Go to "Office Max" look for Porelon 11203 calculator black ink roll.
Aug 27, 2009 | Texas Instruments Office Equipment &...
Paper rolling up with the thermal film
The best thing you can do, short of launching the thing into inter-galactic travel, is to clean all of the plastic parts of the machine with an anti-static cleaner. Particularly, the roller that feeds the paper and the carbon roll. Remove all paper and carbon film and unplug the machine. Clean inside the paper housing and the feed rollers before turning it back on. It sounds like a build up of static electricity, a common problem on such thermal based fax machines. Remember, the paper has the propensity to curl because it is on a roll, so any extra help it gets will send it curling like mad. Good Luck.
Jul 20, 2009 | Panasonic KX-FP141E Plain Paper Thermal...
I have one PIXMA MP150 with proble paper jam message, and I could not find any jammed paper inside,how shouls I do to make this printer available?
GGONG644, Try this fix. TURN OFF PRINTER wait ( 10 or 15 seconds) turn it back ON and listen for
paper ROLLERS to be turning and FORCE FEED A single sheet of paper through print rollers until it PULLS it through the printer and SEE if a scrap of paper comes out with sheet ? Let me know if this works ? Phil at palcando@yahoo.com
GOOD LUCK !!
Apr 29, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Ribbon installation
I searched this online, and have found the following instructions:
1) Set the power switch to OFF
2) Remove the printer cover
3) Remove the ink roller by turning it counterclockwise and pulling it upward.
4) Install the correct color new ink roller and press it in the correct position. Make sure that the ink roller is securely in place.
5) Put back the printer cover.
May 30, 2008 | Sharp EL-1801P Calculator
Paper tape in my TI 5045, please.
Feed the paper in the back press the paper advance button while pushing the paper in the rear slot, and it should feed the paper through.
Hope this helps.
Good luck.
Mac
Feb 08, 2008 | Texas Instruments TI-5045 SVC Calculator
Sharp EL-2196BL Calculator Logo
618 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
