Question about Garden
JOHN DEERE SST18 PUSH ON PEDAL TO GO FOWARD MOWS OK FOR APROX 10 FEET THEN WONT PULL ITSELF .BELTS OK GUESSING DRIVE CLUTCH UNDER ENGINE IS THIS A REPLACEABLE PART OR WILL IT COST MORE THAN MOWER IS WORTH MOWER IS APROX 7 YEARS OLD 400 HOURS
  • 142 Answers
SOURCE: John Deer riding mower
http://www.deere.com/specsapp/CustomerSpecificationServlet?sbu=CCE&pciModel=L120%20GX&displayModelName=L120%20Lawn%20Tractor&tM=HO&pNbr=SKU20346
Here is a link to John Deere website for this model, it states that it has a 16 amp charging system. It also has the phone numbers listed for contact, and requesting the manuals for this mower.
Posted on Sep 20, 2008
  • 86 Answers
SOURCE: John Deere riding mower SRX95 - Steering wheel is sticking
You need to replace your Ball Joints! On the front steering rods There are two sometimes three !
Posted on May 09, 2009
  • 246 Answers
SOURCE: john deere stx 46 wont move just howls
Hello carpenter552:
Check for the Belt being Off 1 of the Pulleys.
>>From your Description it Sounds like the Belt is Caught and Screaming and Not the Transaxle.
>>You can View a Breakdown/IPL of the Engine and Mower at this Site Addy, http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt and Enter the Model Numbers STX46 and Click Find. Then Select your Model from the Search Results Area. Then Select the Sectional File. Then Select the Section of the Mower you Wish to View Online. *You can Drag the View Windows for Better Viewing.* Select the Power Train File.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 14, 2009
SOURCE: john deere 111 mower deck. Lift is in stuck in highest position
Looked up detailed isometric diagram w/ parts denoted on John Deere website. FixYa website was a litele misleading. I did not realize that accessing a question posted "for free" would cost me something to get the answer. It's kind of like askin a neighbor as a neighbor to give you a hand and then he sends a bill.
Thanks but no thanks
Posted on Jun 26, 2009
wireguy212
  • 1627 Answers
SOURCE: I have a Deere LX188 mower, while mowing the
you need to check the seat switch first then have the park brake switch looked at.is there power to the starter relay?
Posted on Jul 23, 2009
Wiring diagram for a john deere sst18 lawn tractor
Russell if you truly want to figure out this problem you need to look at the wires and ware they connect .And what they connect to then drew your own wiring diagram its not that difficult if you break down and do a few tests with an OHM meter to see what is connected and what happens when you through a switch or run a jumper wire to a ground .
If you think about its not really that complex .
Jun 08, 2016 | John Starter Deere Sst18 Spin Steer Deere...
L120 cuts great but wont pull up a hill
replace the drive belt .they do wear out
May 07, 2016 | John Deere L100 Series
What makes a john deer rx75 mower buck in fowerd not reverse? belts are new
An RX75 bucking as you describe is usually caused buy one of several things. #1 make sure brake pedal returns to disengaged position.Check the brake linkage and add or change a spring as needed. Check for debris clogging the brake pad assembly too.
#2 the speed control linkage roller cam attachment bolt has loosened over time. To correct, drive unit foward in 5th gear and stop with clutch pedal while on level ground. Kill the engine.Lift seat and find on left side the black rod with a funny U cut into it at the end. Its below the red throttle handle. There is a roller cam which rides in the U cut. Looosen the bolt holding the roller cam, let it find its own new position ( maybe just a couple mm ) and re-tighten bolt again. (One side of the U cut cam controls your speed in foward, the other side, while in reverse. Hope this helps.
Jul 20, 2014 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
My john deere push mower starts fine mows for 10 min quits wont start so I took the the gas cap off looked at it put it back on push the prime bulb 1 time it started ran for 10 min quit did the gas cap...
I'm not sure of the model number of your mower or engine to know the fuel and carburetor set up. I do have one easy thing to try though as it sounds as if a vacume is building up in the tank. Try putting a half of tank of gas in it, leave the gas cap off, and see if it continues as it was or if it runs ok. If this stops the issue your cap vent is pluged up. I hope this helps
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steve_f5a6ca85b5d1ffc9
Oct 03, 2013 | John Deere Garden
I have a JD LA110 2007 engine runs fine was cutting lawn and it just coasted to a stop and won't move now. I did smell a burnt smell chked belts look ok.
Sounds like you may have a belt that popped loose. While the belts may look intact, they can sometimes jump out of their groove. Check to make sure the drive belt is routed properly, and that it is tight when the clutch/brake pedal is out (in the drive position). If the belt is routed properly, and the belt is not tight in with the pedal in drive, chances are your tension pulley assembly may have broken, or something else is amiss in the drive pulleys. Also make sure to try all the gears.
Sep 16, 2013 | John Deere Garden
Clutch problem
Hello:
It Sounds like the Clutch Idler is Bent and Requires Replacing.
A Homeowner can Replace the Clutch Idler Arm and Pulley with Little to No Worries.
You can View a Breakdown of this Unit at the Following Site Addy.
Enter the Model Numbers 2020 and CLick Search. Now Select your Model and then Select Sectional Index.
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Why would my sst18 john deere zero turn steer in
there is a servo under the main body on the right side win sitting in seat thats broken from the_w4ezv@yahoo.com
Apr 18, 2009 | Garden
Garden Logo
226 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
