Question about KitchenAid KAWS750L Top Load Washer
How do i remove the top of a kitchenaid clothes washer to clean built up soap off the top of the drum
Want to remove cabinet top of Kitchenaid washer
Posted on Jun 11, 2010
My 10+ year old Maytag Neptune washer has standing water behind the drum after the spin cycle
Griffin is correct but, I took it one step further and removed the front cover and rubber gasket and used a long thin brush after spraying white vinegar with a spray bottle and cleaned all the **** from around the drum. I use white vinegar with clothes once in a while to keep the drum free of built up soap and softner.Its a little work but trust me when you see all the stuff on the drum you will understand why the machine stinks. I also leave my soap tray door open all the time to allow air inside.
Oct 29, 2012 | Maytag Neptune MAH5500B Front Load Washer
The whashing comes out with white powder like stuff. Can I clean the drum and if so how ? is it flint that gathers some where?
Hello Sir Tommis,
I understand that you are having a problem with your washing machine. When you wash clothes they come out with a white powder like substance on them. This white powder substance is the powder laundry soap that you are using.
This is generally caused by adding to much soap and clothes to the washing machine. The soap is not getting dissolved and the clothes do not have enough room to agitate in the machine. Try to put 3/4 of the amount of clothes in the washer with the same amount of soap and see if the clothes come out with the same powder like substance on them.
The clothes that currently have the soap on them will have to be hand washed with a scrub brush in oder to get the material off of them as running them though the washer will not remove the soaked in soap.
Thank you for choosing FixYa.com
Justin
Mar 26, 2011 | Whirlpool 3.2 cu. ft. Washer
How to remove the drum from a kitchen aid washing machine
hello. Unplug the washer and use a vacuum cleaner to remove the little balls. J.
please rate my answer as very helpful. Thanks.
Mar 28, 2010 | KitchenAid KAWS700L Top Load Washer
My GE washing machine has a foul odor after it has been used
Most likely caused by build up of soap scum. Fabric softeners are the major contributor to this. It causes a thick residue to build up on the outer drum.
Best to get a service technician to remove inner drum and scrape to clean it off.
Once clean Vinegar is good for disinfecting, and Descaler crystals are available, but neither of these will remove the soap sludge which would have built up over time.
Good luck
Ash
Oct 21, 2009 | GE WDSR2080D Top Load Washer
How do you get rid of the musty smell in a front load washer.
38c7a1e.jpg MNTECH
Rank: Guru
Rating: 93%, 650 votes
Here is a response I recently gave to a person posting a similar problem. You do not state your model number, so: If you have a tub clean cycle, use that, if not, use the longest, hottest cycle with no clothes and a front load washer cleaner like Ahfresh, Washer Cleaner, SmellyWasher Cleaner, Tide front load washer cleaner, or Whilaway hot tub cleaner. Clean the tub gasket area by the door and remove the filter and clean it out also before you run the clean cycle. You may have to run the cycle with a cleaner twice to remove all the built up soap scum inside the washer. Now, after the washer is clean, USE ONLY ONE TO A MAXIMUM OF TWO TABLESPOONS OF HE LAUNDRY DETERGENT PER CYCLE !!!! (and no more than one teaspoon of fabric softener per cycle, if you use it)
You could check out http://www.smellywasher.com/ for one possiblity. The big thing is that these machines use very little water, and many of the newer soaps are 2x or 3x concentrated, so you have to use very little soap. (much much less than the soap manufacturers suggest) in order to rinse all the soap residue out of the clothes and prevent it from builing up in your washer and causing odors. (oh, by the way, that one cleaner I listed as Washer Cleaner is actually " Washer Magic ") 73b1c2a.jpg fb3071a.jpg
Aug 12, 2009 | Kenmore Elite 45986 Front Load Washer
I HAVE FRONT LOAD LG WASHER - CLOTHES ARE SMELLING -- CAN WE USE 2 CUPS CLR & RUN WASHER WITH NO CLOTHES TO CLEAN WASHER DRUM & DRAIN HOSES. IS THERE A BETTER SOLUTION TO PREVENT THIS PROBLEM
Comments: Jul 21, 2009- Well, with that model I'd guess you are in the UK, and I don't have parts breakdown or service info on those models, but I'd run the front load washer cleaner through it. Not sure which ones are available over there. You could check out http://www.smellywasher.com/ for one possiblity. The big thing is that these machines use very little water, and many of the newer soaps are 2x or 3x concentrated, so you have to use very little soap. (much much less than the soap manufacturers suggest) in order to rinse all the soap residue out of the clothes and prevent it from builing up in your washer and causing odors. (oh, by the way, that one cleaner I listed as Washer Cleaner is actually " Washer Magic ") 73b1c2a.jpg fb3071a.jpg
Jul 29, 2009 | Washing Machines
My washing machine is leaving little residue on all my clothes after a complete wash, What are they? and how do you get rid of it, the washing machine is not yet a year old
Describe the residue. If it's oily (black, dk green) then the seal is out of the tranny and oil is getting into the tub. Dry cleaning is best for oil based stains. Liquid dish detergent is good also. On white it is tough to remove. Your washer will need a new transmission or replacing.
If it is powdery I'd guess a soap buildup, especially if you've recently changed detergents. The new detergent is breaking up the old soap scum in the outer drum and it is redepositing onto your clothes. This should wash out/off.
Tip: If it's a soap residue, fill washer full without clothes with hot water. Add 1 gallon white vinegar and more hot water until the unit if as full as possible. Agitate 15 minutes and drain. Rinse with a full level and drain.
Jan 24, 2009 | Samsung SW62ASP Top Load Washer
My husband was washing a load of clothes and as our front load maytag washing machine started to spin, a shirt wrapped itself around the rubber part that is at the front of the washer and pulled it out and...
you will have to take off the front off washer to put it back correctly.
remove the top panel 3 screws in top rear
remove the bottom panel 3 screw in bottom front
remove the top led control panel 3 screw or more along front lip
if you disconnect any wiring mark it well .
now the front of washer can be removed with or without the door (your choice)
careful with the door lock wiring.
be sure to unplug the washer.
while you are in the innards its a good time to wipe around the drum any buildup of soap etc..
and to clean the filter trap in the bottom access tube below drum.
Mar 31, 2008 | Washing Machines
Clothes coming out dirty.
A solution from the internet: Make a boil wash (with no clothes and detergents), put into the soap dispenser a cup of bicarbonate of soda.It should clean the machine and remove the bad smell. Another: I have a front loading machine also and am not willing to constantly clean out the machine -- the soap and fabric softeners you use are building up between the inner and outer drums (and on the drum itself sometimes). Because the machines door is so tightly sealed (to prevent water leakage) the smell from this buildup is awful. I finally found a solution. MAGGIE'S SOAP NUTS -- they are all natural (grow on trees) and will remove the grime from your drum and also clean your clothes (you won't even need fabric softener anymore). Stop using commercial detergents and fabric softeners and start using Maggie's Soap Nuts. They are not very cheap but they work great -- I have found that making a liquid out of the soapnuts and storing it in a bottle works better than putting them in the sack cloth they come with (because front loaders do not agitate constantly like regular machines, the cloth bag sits on the clothes and sometimes leaves a stain -- the liquid will not leave a stain. YOU WILL SOLVE YOUR PROBLEM AND HAVE SOFTER CLOTHES TO BOOT (without fabric softener so you save some money there). They are also better for septic tanks, the environment and your health! I believe Whole Foods sells them and they are also on the internet at www.Maggiessoapnuts.com Note: Also go to www.newstarget.com -- they are going to buy these in bulk to cut the cost in half but don't have them yet. You should be able to buy them there soon. Note: Forgot to tell you to run some of this thru your machine with hot water before washing your clothing to clean out the buildup that is already in the machine. Fixya is real cool.....
Sep 12, 2007 | Whirlpool Ultimate Care II GSQ9669L Top...
KitchenAid KAWS750L Top Load Washer Logo
413 people viewed this question
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
gbob59
Mike
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
