Question about Porter Cable 18 - Gauge Brad Nailer and Compressor Combo Kit
Pressure switch dows not shut off motor when
Porter cable 6 gallons.
Pressure switch does not shut off motor when compressor reaches.
Pressure switch cut-out to high!
    President:
  • 512 Answers
Pressure switch has gone bad and needs to be replaced. Part runs around $25. Go online and put in model number, pressure switch. You will find companies that sell replacement parts. I had to replace mind, it did the same thing.
Posted on May 03, 2010
Testimonial: "Thanks for help, many appreciated."
Porter cable pancake compressor will not shut off replaced manifold, still the same.
I would look at the pressure switch which shuts the electric off when the air pressure reaches its limit also check all wires going to and from this switch. Best checked with a multi-meter.
Feb 07, 2015 | Porter Cable Air Tools & Compressors
My 6 gallon porter cable compressor stop working, how can it be fixed?
Check the voltage at the pressure switch and be sure the connections that are there are tight. check the voltage to the motor. If you have voltage to the motor then replace the motor.
Aug 22, 2014 | PorterCable Oil-Free Pancake Compressor...
My Porter Cable Job Boss compressor won't shut off. It builds up pressure but just continually runs.
Pressure switch - replace as soon as possible
Overpressure would be possible in that tank - it is dangerous !
Oct 20, 2012 | Porter Cable 4 5 Gallons 150PSI Job Boss...
On my porter cable 6 gallon air comnpressor need to know where the red black and yellow wires get plugged into
there always three wires in the power cord, the green/yellow stripe wire is for ground connection,which doesn't needed to modify.
One of the other two wire is directly connected to the power plug , and the other connects to the contact point at the pressure switch and returns back to the power plug.
if this pressure switch is not working, you have to install another kind of switch of on and off the compressor.
Sep 13, 2012 | Porter Cable C2002 150 Psi 6 Gal...
A porter cable 135 psi 60 gallon upright
If the motor doesn't shut off at the desired pressure then your pressure switch is either set too high or is broken/stuck. The pressure leak at 150 psi is the safety valve doing its job opening when the pressure gets to an unsafe level in the tank.
Aug 27, 2012 | Porter Cable Air Tools & Compressors
I have a porter cable 6 gallon compressor. The motor used to cut out at 150 psi, but now it cuts out at 135. Is this a faulty tank pressure gauge misreading the pressure or a motor cutting out too early
it could be your air pressure adjustment knob, where your air line hooks up, which controls the psi to a lower or highist seting to adjust for different tools and uses.
Aug 26, 2012 | Porter Cable C2002 6 Gallon 2 Compressor
Why my air compressor want shut off after building up pressure
If it is building up to the full rated pressure and there are no air leaks in the hoses then it is most likely the pressure switch. It is item 111 in this parts diagram.
Porter Cable C2002 diagram
Aug 25, 2012 | Porter Cable C2002 150 Psi 6 Gal...
Porter Cable 18 - Gauge Brad Nailer and Compressor Combo Kit Logo
895 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
