Question about Zanussi ZEBF277W Bottom Freezer Refrigerator
Fridge smell There is a rancid smell inside the fridge despite washing everything
  • 269 Answers
It sounds as if you may have had a spillage at some stage in the fridge unit and this has gone onto the tray at the rear of the unit at the bottom on top of the motor.There may be some other explanation when you do pull out the fridge to access this tray.It may be easier to clean the tray in position as they can gat damaged if you try to remove them.If so get some soapy water and a sponge then clean out and dry,also some spray dissinfectant in the tray after cleaning will help.
Posted on May 03, 2010
Can I freeze a crab pie
Yes you can, but when it defrosts it will be a bit watery. If you freeze it longer than 6 months, you may find it smells like Linseed oil. If it does throw it away, because the oil in the crab has gone rancid. The smell is unmistakable and unpleasant to eat.
You can keep the pie in a cold fridge for 5 days if you want to avoid freezing.
I am a trade chef BTW :>)
Feb 06, 2016 | Cars & Trucks
Fridge smells of cheese.cleaned everything can't get rid of smell.
clean everything including the drain and pipe at the back of the fridge
It is most probably a mold build up in areas that are not readily accessible including behind the door seal
vanilla in a cup is good to absorb smells in a fridge
Sep 30, 2015 | Refrigerators
Problem is rotten smell inside GE profile fridge. I've checked for rotten food-none; taken everything out and cleaned inside plus all shelves with added bleach in water. Smell is still there. I...
Hi, pull out the fridge and remove the back panel, and clean that area. Make sure no food is stuck under the fridge also. A rotten piece of fruit or other food, once under there, will smell until it totally decomposes. You can also mix 1/3 cup of bleach and 2/3 cup of water , and pour down drain tube (rear bottom in freezer section. Too much bleach and the smell of bleach would be circulated by the fan to the room, so be sure to add water. Finally, another popular methods of removing fridge odor include washing the entire fridge out with a vinegar and water solution, placing fresh coffee grinds or boxes of baking soda on each shelf and even using trays of cat litter.
May 17, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
How do you get the rancid smell out of a freezer from defrosted meat?
HI,YOU COULD TRY WASHING IT OUT WITH 1PART BLEACH AND 3 HOT WATER,I CLEANED A FRIDGE WITH THIS, THAT HAD BEEN TURNED OFF WITH THE DOOR SHUT FOR OVER A MONTH,BRIAN
Nov 13, 2010 | Kenmore 64802 Top Freezer Refrigerator
Phillips whirlpool built in fridge /freezer smell coming from the fridge section,we have tried various things but the smell still persists
Could it be that there is degradation of the plastics due to heating of the defrosting coils or is it the smell off leaked gas.
Remove all the food stuff from the fridge and clean, wash the inside throughly. Now restart the fridge and after aboutone hour check for smell, continue this till you notice, if the smell comes in after about 10 hours then you must look into the defrosting heater for any traces of material on it causing the smell on heat.
Aug 30, 2010 | Whirlpool Refrigerators
Our lg washer model wm0642hw tub clean cycle stops
software problem. regarding smell, after wash keep the door opened for ventilation, use fabric conditioner etc. also check whether any rodent has gone inside and messed up the place
Mar 18, 2010 | LG WM0642H Front Load
My Matsui under counter fridge smells of old milk/veg really badly despite cleaning out thoroughly including catch tray at back and downpipe. It is only 1 year old - any advice gratefully received
Can you pull out the fridge and check that the plastic power cable has not been pressed against the compressor at the rear/bottom of the fridge?
Usually, overheated plastic cable smells like rotten veg!
Nov 17, 2009 | Refrigerators
Bosch classixx fridge freezer - smell coming from fridge. Can only smell when door opened.
bad eggs smell coming from behind Bosch fridge freezer. There is no bad food in fridge. Any comments appreciated. Linda
May 02, 2009 | Refrigerators
Fridge Smell
i have a whirlpool fridgefreezer and their is a very bad smell comming from the back of it what can it be
Aug 02, 2007 | Hotpoint FFM70 Bottom Freezer Refrigerator
Zanussi ZEBF277W Bottom Freezer Refrigerator Logo
159 people viewed this question
Top Zanussi Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
