Question about Sharp EL-2196BL Calculator
Tape wont register on this after we changed the tape
We change the tape on our sharp EL-2196BL calculator & now it turns on & adds but the tape wont work & we hear no noise for the tape to grab and pull through. Can you please help us? thanks The tape has circled back inside the machine and three layers of tape are around the ink roller and I cannot get the paper out. it is totally stuck. I need a shop where I can take it too and have them take the ink roller out in order to pull the paper jam out.
any suggestions, I am located in West Los Angeles Ca 90064
310-453-1901 x203
  • 3,037 Answers
U.S. Office Machine Co., 5722 N. Figueroa St., Los Angeles, CA 90042. 323-256-2111. "We specialize in the repair and restoration of all your old typewriters, and we have a very large selection of parts and supplies. We have been in business since 1962 and have had many satisfied customers." One customer writes: "The guy who owns the place is a WW2 veteran named Jesse Flores. He's been there 46 years. His son Danny handles most of the repairs now. They also repair the old fashioned adding machines and mechanical calculators. Around Christmas, he gives out toys to needy children and has helped organize the local Christmas parade in the past and such. The building he is in used to be a theatre back in the 1910s, and the fellow has photos of him with every coucilman and mayor, as well as Senators and national politicos from the early 60s to the present, on his walls."
Posted on Mar 25, 2008
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri Mar 25, 2008
    you could also try
    Star Office Machines,
    11351 Santa Monica Blvd.,
    Los Angeles, CA 90025.
    (310) 477-6091 tel,
    (310) 479-6644 fax.
    "We have been in business in Los Angeles since 1969. We have a very
    qualified service department that specializes in repairing and
    restoring old and antique office equipment like manual typewriters and
    calculators. Our technicians are all factory trained and some have over
    40 years experience that started in Europe with company like
    Lagomarsino-Totalia, Olivetti, Addo-X, Olympia, Adler-Royal, Hermes,
    Remington, etc."
  • Benjamin Patri
    I hope this helps, please let me know if you need anything else. Please don't forget to rate this solution, have a great day.
  • Benjamin Patri
    otherwise a printer repair shop could also help you out
SOURCE:
Sharp el-2630piii calculator setting to two decimal points
Slide the "F 6 3 2 1 0" switch to the "2" position.
Feb 28, 2013 | Sharp EL-2196BL Calculator
We have a SHARP EL-2196BL printing calculator, but no user manual. We can't get it to print the answer when we are adding. It shows on the screen, but not the paper. Also, it just keeps adding up...
You can download the manual from the manufacturer's web site at
http://files.sharpusa.com/Downloads/ForHome/HomeOffice/Calculators/Manuals/cal_man_EL2196BL.pdf
Feb 26, 2011 | Sharp EL-2196BL Calculator
HOW DO I SET THE TAX ON THE SHARP EL-2196BL?
You can get the manual on link below it will tell you how to set the tax.
http://dl.owneriq.net/2/2f5de9b8-0a25-e1f4-d9c2-132001ba18e5.pdf
Good luck and please rate 4 thumbs for the free answer
Mar 12, 2010 | Sharp EL-2196BL Calculator
Want to replace ink roller on Sharp EL-2196BL -
http://www.gorillapaper.com/univ-cal-spool-br-12-per-box.html
Universal Calculator Spool 12pk
Thank you
Oct 08, 2009 | Sharp EL-2196BL Calculator
How do I replace the printer paper in my sharp EL-1192BL calculator
Feed the paper into a VERY thin slot on the back side of the calculator. This thin slot is below the removable clear plastic paper guide and is very inconspicuous.
Apr 10, 2008 | Sharp EL-2196BL Calculator
Setting time & Date
I copied this from another post & it worked for me:
To enter the date
1. Be sure to switch to "rate set" from GT
2. Enter the month
3. Press the decimal point
4. Enter the day
5. Press the decimal point
6. Enter the year
Example 3.09.2007
7. Press the button that look like a clock/calendar
To enter the time
2. Enter the hour (please use military time)
4. Enter the minutes
Example: 13.24 or 9.24
5. Press the button that look like a clock/calendar
Then change the "rate set" back to the GT setting.
Mar 10, 2008 | Sharp EL-2196BL Calculator
Make sure that it is installed properly ... going under not OVER. Does the paper feed when the paper feed key is depressed ??
1. Lift the paper holder up.
2. Fold the leading edge of the paper roll 3 to 5 cm. (Do not fold it slantwise.)
3. Insert the paper roll from the left side of the paper holder and make sure the paper
roll is set in the proper direction (with the paper feeding from the bottom).
4. Insert the leading edge of the paper into the opening directly behind the print
mechanism.
5. Press the paper feed key and feed the paper under the edge of the paper cutter.
Dec 07, 2007 | Sharp EL-2196BL Calculator
Sharp EL-2196BL
mechanism.
Sharp EL-2196BL Calculator Logo
259 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
